comp music with pic Sounds - Aka BeepMaster
Results 1 to 19 of 19
    Jul 2007
    Default comp music with pic Sounds - Aka BeepMaster
    Ok, here's one little thing I came to spend time on and turned out to be quite funny, so for the musician, here you go:
    I wanted an easy-er way to create tunes with the sound command, else than testing/programming over 40 times to get the notes right.
    Initial plan was to create everything from a windows apps, then output notes to pic, but finally I was tempted to use the PIC as a sound card...
    Result is, a small application running under windows, showing you a virtual music keyboard and notes supported by the PB sound command.(I did my best to match the real frequencies with the ones emitted by a PIC, but they are not all 100% accurate).
    You can clic the keyboard, and notes will be sent on the serial port to the PIC for playback.
    Of course you can record/delete clicked notes to a list, and in the end ask the software to output a PBasic command line to put into a program.
    not 100% bulletproof tested, but functionnal over here.
    Made at least 6 tunes in less than 15 minutes with it.
    It come pre-loaded with JS Bach Minuet =)
    program EXE is here:
    http://www.flipperdesign.com/BeepMaster.rar
    Code required in the PIC to get the notes is here:
    ; sound generator PIC12F683, @20Mhz
    ; testing Sounds, and they wait for Data from seial to play more..
    ; For use with BEEPMaster.exe Program to create tunes
    ' PIC12F683
    ' PIN  NAME     USE/CONNECTION
    '  1   Vdd      +5VDC
    '  2   GPIO.5   XT
    '  3   GPIO.4   XT
    '  4   GPIO.3   N/C, MCLR
    '  5   GPIO.2   LED OUTPUT
    '  6   GPIO.1   SERIAL INPUT
    '  7   GPIO.0   SPEAKER OUTPUT, with a small caps
    '  8   VSS       GROUND
    DEFINE DEBUG_REG GPIO
    DEFINE DEBUG_BIT 1          ' GPIO.1
    DEFINE DEBUG_MODE 0         ' 1 = inverted, 0 = true
    DEFINE DEBUG_BAUD 38400     ' test 38400(fonctionne pas toujours sur le INTOSC)
    DEFINE DEBUGIN_REG GPIO
    DEFINE DEBUGIN_BIT 2          ' GPIO.2
    DEFINE DEBUGIN_MODE 0         ' 1 = inverted, 0 = true
       DEFINE OSC 20
       CMCON0 = 7 'Analog Comparators OFF
       ANSEL   = %00000000   ' Set A/D OFF, necessaire pour SOUND!
       ADCON0 = %00000000 'Analog converter OFF(test)
       WPU = 0  ' Internal pull-ups = off, maybe REQUIRED for MCLR_OFF
    INPUT GPIO.2
    OUTPUT GPIO.1
    Speaker var GPIO.0
    output Speaker
    Freqtest var Word
    Duration var byte
    curNote var byte
    ;LedPort var GPIO.2
    ;Output Speaker
    dlzic var byte
    curNote=0
    ;High LedPort
    Pause 200
    dlzic=40
    sound Speaker,[105,dlzic,99,dlzic,102,dlzic,90,dlzic*2,0,15,90,dlzic,102,dlzic,105,dlzic,99,dlzic ]
    ; Super Cool warp!
    for Freqtest= 200 to 600
       FREQOUT Speaker,10,Freqtest
       next Freqtest
    ;High LedPort
    ; NOW that fun is over, lets wait for client input
    waitforkeydata:
    pause 1
    DEBUGIN [WAIT("DT")]
    DEBUGIN [HEX2 curnote]
    DEBUGIN [WAIT(",")]
    DEBUGIN [HEX2 duration]
    DEBUGIN [WAIT(13)]  ; wait carriage return
    pause 2
    sound Speaker,[curnote,duration ]
    ;High LedPort
    GOTO waitforkeydata
    note: The windows BEEP option to have sounds played under windows does not work with all computers... here.
    Now that is an interesting project!!!
    Wink nice jewel ...
    Hi, Flipper
    Ha que voilà une application des plus sympas !!!
    Merci encore.
    PS: dis m'sieur ... on pourrait aussi avoir le bruit Blanc, histoire d'étendre le domaine d'utilisation aux bruitages ??? ...
    Merci d'avance.
    PS: Sous XP SP3, les touches du clavier et la légende des cases à cocher n'apparaissent pas ...
    Jul 2007
    Salut Alain
    oh, no keys appearing?
    could you send a snapshot of what it looks like on your PC?
    flipperdesign at gmail ... dot
    this is hard to imagine as i'm forcing colors...but will check back what could cause that.
    White noise, yes it could be. Maybe on another piano bar.
    I've just added it for a quick test but it's not implemented with recording.
    you can redownload from the same link
    Thanks for the idea!
    Dec 2008
    Ploiesti, ROMANIA
    Wonderfull project ! It is possible to use 12F675 instead 12F683 ? Thanks !
    Jul 2007
    any PIC will do
    it just we to wait for the correct data to come in, which is set by the sending program.
    the only real important part is here:
    waitforkeydata:
    pause 1
    DEBUGIN [WAIT(",")]
    pause 2
    ;High LedPort
    GOTO waitforkeydata
    Dec 2008
    Ploiesti, ROMANIA
    Merci beaucoup !
    Jul 2007
    a quick note to let you know that there is a visual bug under any OS that is set to use the fancy windows themes, like rounded buttons and fades...
    to get things right, you new to switch into Perfomance mode under XP, or set the theme to "Classic" in Win7. Yah, it will reminds you of the good old Win2000 days
    that is until I find a way to set colors properly into that fancy world.
    thanks goes to Brad for help finding this out.
    Jul 2007
    Default new version
    You can now re-download from the same link, and a newer version is there. Look in the top right corner options if you can't see the interface.
    try barbie pink interface!! it's NIce
    also fixed a bug with noise notes code, that would try to send data even if PIC option was not selected.
    Default Wow
    Hi Flipper
    WOW this really is something !
    You know anyone could (with some tweaking to a Jean Michel Jarre with a PIC !
    Combine your PIC code with something Skimask was busy on [HTML]http://www.picbasic.co.uk/forum/showthread.php?t=5407&highlight=finger+touch[/HTML] and maybe a few Led's and a laser pointer or two and whammo you have a hit !
    In fact , interface your Windows proggie with a media player, feed it to the same sound source and you have an LED touch DJ panel with sound to light !
    I will keep an eye out for it !
    Many thanks
    Kind regards
    Dennis
    Jul 2007
    agreed that possibilities are totally endless
    I already hooked a frequency bargraph on my board right aside, since I needed a frequency analyser to catch the sounds emitted by the pic in the first place.
    here is a newer Beta version, with Basic MIDI output, and some other tweak.
    http://www.flipperdesign.com/BeepMaster_midi.rar
    watch out, it could be pretty loud and there no volume control
    But i do like the midi sounds...a bit more than the PC beeper LOL
    Default some food for thought :-)
    Hey Flipper
    Awesome !!
    Will give it a shot and feedback when I can :-)
    Maybe a light organ ??
    .....Or touch-sensitive :-)
    Think the light-organ would be something even more quite unique as an add-on or option for your code (or new code!)
    Would love to try it out if ever you get to do it !
    Dennis
    Jul 2007
    Hi Dennis
    I'm not too sure on how things would get hooked between light sensor/program/ and another pic making sound?, but if you can describe the loop I might check into it.
    I would hope to add multitrack capability one day, or maybe easier and more powerfull, a plain Midi track importer/converter.
    Then a whole bunch of 12f683 would share the data, singing along
    here is a light organ, sort of
    [HTML]http://www.youtube.com/watch?v=aOZEpP_zzaw[/HTML]
    i've just added it into my program, as default sample track.
    Jul 2007
    updated program recently, some added functions and checks.
    and created a new utility to process midi files for import(work ok with clean tracks, ie no multi-tones as the pic can't do that)
    more info in this web page:
    http://www.flipperdesign.com/projects_beepmaster.html
    Sep 2008
    Stockholm
    Very cool, except that I can't get it to work, if I press any key (on the little piano-keayboard) that has a decimal point I get the error message "xxx.xxx is not a valid floating point value"
    I GUESS that this can be due to that the official floating point marker in Sweden is comma (,) and not a dot (.) (even if many people use a dot anyway).
    Would it be possible to fix this bug ? probably by reading that info from windows in some way ? ..it's actually the first time I seen this problem.
    Jul 2007
    thanks for reporting this error Glenn
    I believe you have pinpoint the bug. my programming didn't checked for coma or point separator.
    Now it will update the frequency list at startup, after checking system settings.
    (a message will appear in the application title area)
    please redownload BeepMaster_midi.rar and let me know.
    Sep 2008
    Stockholm
    Sorry for the late reply, but it works much better now
    But I still cant get it to convert a MIDI file, but since I'm not very good at MIDI files and you make some notes about what's supportet I guess it's my file that is the problem..
    Jul 2007
    good!
    check back on my website(scroll way down), as I updated some information about midi stuff.
    If you have other question on un-explained stuff just ask, I will try to update the info.
    DS
    Jul 2007
    updated version with some more control is now available
    http://www.flipperdesign.com/BeepMaster2010grid.rar
    don't be afraid to Right Click over grids and buttons, they will often reveal magic functions
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
    Last Post: - 12th March 2005, 00:14
