LCD - Blocks at Start-up/Initialisation
Results 1 to 5 of 5
    Feb 2005
    Essex, UK
    Question LCD - Blocks at Start-up/Initialisation
    I am using a PIC16F877A to output to an LCD in 4 bit mode. For the 1/2 second start-up time needed before instructions can be sent to the LCD, I have blocks on the screen. I have noticed this when using other PICs as well and I realise that it is the test routine for the LCD and not the PIC. I am wondering if there is any way to eliminate this from being visible at start-up?
    disable the Vo line of your LCD. Vo is the contrast pin. Usually when you tie this pin to VCC you'll see Nothing
    Feb 2005
    Essex, UK
    Thumbs up
    I was wondering about using the contrast line to achieve this.
    Thanks very much
    Rob
    Rob, Just tie the one side of a 10k pot to a spare micro pin of choice and the center of the pot to the VO line and the bottom of the pot to ground. Now with the pin outputing a high state adjust the pot for the correct contrast. Now during startup your code will output a low on the pin untill you want the display to be enabled and then just set it to a high state for display.
    HTH,
    Dave Purola,N8NTA
    Feb 2005
    Essex, UK
    HTH,
    Dave Purola,N8NTA
    Thanks for that - it works perfectly!
    Rob
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. Need help with LCD number display.
    Last Post: - 27th June 2007, 00:07
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
