PBP code to read R/C signal from receiver
+ Reply to Thread
Results 1 to 10 of 10
    malc-c's Avatar
    malc-c Guest
    Default PBP code to read R/C signal from receiver
    Guys,
    Have tried searching the net and this forum, but nothing comes up, and as I'm a bit rusty on PBP, I'm after some pointers as to how to read the PPM signal from a normal RC receiver (1 -2ms repeated every 20ms).
    I've got some ASM code that already does this, but really want to learn and develope PBP a little more. One search did turn up something on RC groups, but Alain has removed the source code
    Wink So simple a question, the answer could be ...RTF...
    Hi, Malc
    What are you looking for exactly ???
    The basic reading is simply achieved only with a PULSIN Command ....
    Short example:
    @ DEVICE PIC12F683, MCLR_OFF
    @ DEVICE PIC12F683, INTRC_OSC_NOCLKOUT
    @ DEVICE PIC12F683, WDT_OFF
    @ DEVICE PIC12F683, BOD_ON
    @ DEVICE PIC12F683, PWRT_ON
    OSCCON  = %01110000    ' Internal 4MHz osc
    ADCON0 = 0             ' A/D off
    CMCON0 = 7             ' Comparators off
    ANSEL = 0	           ' Set all digital
    WPU = 0                ' Internal pull-ups = off
    OPTION_REG = %10000000 ' Pull-ups = off, GPIO.2 = I/O, prescaler to Timer1
    GPIO = %00000000       ' All outputs = 0 on boot
    TRISIO = %00001000     ' GPIO.3 input, GPIO.0,2,3,4,5 output
    signal VAR GPIO.3
    pulse  VAR BYTE
           PulsIn signal, 1, pulse ' reads signal from receiver
           IF (pulse >= 148) AND (pulse <= 152) Then
              Low GPIO.0 ' turns LED off
           Else
                High GPIO.0 ' turns LED on
           EndIF
           GoTo main
    malc-c's Avatar
    malc-c Guest
    Default thanks
    Thanks for the code example. I'll hook up a receiver to my Easypic5 board and have a play... I'll also have a read of the online manual
    malc-c's Avatar
    malc-c Guest
    Dan,
    I've tried the following with a 12F675 and whilst it compiles and loads OK it doesn't do anything
     @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON
     __CONFIG
     _INTRC_OSC_NOCLKOUT
     _WDT_ON
     _PWRTE_ON
     _MCLRE_OFF
     _BODEN_ON
    signal VAR GPIO.3
    pulse  VAR BYTE
           Else
           EndIF
           GoTo main
    GPIO.0 is high all the time. GPIO.3 glows faint on the Easypic and brightens when the switch on the TX is activated indicating the PPM signals are being received on GPIO.3
    I've also loaded some hex generated from assembly that works so the connections are sound. Any ideas ???
    malc-c's Avatar
    malc-c Guest
    Edit:
    This seems to work
           IF (pulse >= 100) AND (pulse <= 160) Then
           Else
           EndIF
           GoTo main
    seems the range between >= and <= was the issue
    Wink
    There was no issue, Malc
    Led OFF for Neutral , ON for everything else.
    a bit surprising, but ... it is !
    malc-c's Avatar
    malc-c Guest
    No issue, just the the original range didn't work. Once I changed the values between the <= and >= then it worked !
    I'm glad the code worked for you... Wish there were more threads about R/Cs electronics... I own 25 R/C trucks from Traxxas and now a heli clone of the Trex500 and many of them have PICs turning on/off lights, flashers, blilnkers, neons, sirens, and a few more things... PICs are great for R/C projects!!!
    malc-c's Avatar
    malc-c Guest
    Dan, have to agree with you. It would be nice to see some more RC related PIC / PBP stuff.
    Maybe we could start a thread and request the mods to sticky it in the code examples section ????
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 10:02
  2. R/C receiver to PIC16F84
    By tech in forum mel PIC BASIC Pro
    Last Post: - 12th September 2008, 17:45
  3. Making Program Code Space your playground...
  4. Timer PIC16F57
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 09:14
  5. can someone post example to code a bootloader using pbp?
    By nimonia in forum mel PIC BASIC Pro
    Last Post: - 9th May 2005, 17:28
