18LF14K22 AD Converter Problem
Results 1 to 4 of 4
    Nov 2008
    Default 18LF14K22 AD Converter Problem
    Hi all,
    i have the following problem:
    I use Aanalog 2 (RA2) and Analog 3 (RA4) to measure DC Voltage on a PIC18LF14K22.
    The uP is configured to run with internal oscillator:
    OSCCON = %01110010 ' configure internal OSC @ 16MHZ
    OSCTUNE = %00000000
    While OSCCON.2=0 : wend ' wait until OSC is stable
    After that i configure Port A to use RA0 to RA3 as ADC:
    TRISA = %111111
    ADCON1 = %00000000
    ADCON2 = %10000111 ' Right justified, Frc
    ANSEL = %00001111
    ANSELH = %00000000
    Then in two subroutines i read back Aanalog 2 and Analog 3:
    1:
    ADCON0 = %00001011 ' Start the conversion of ad channel 2
    WHILE ADCON0.1 = 1 ' Wait for it to complete
    i = 0
    WEND
    adc2_value = (adc2_value + ((ADRESH * 256) + ADRESL)) / 2 ' get result from AN2 with avg by two
    2.
    ADCON0 = %00001111 ' Start the conversion of ad channel 3
    i = 0
    WEND
    adc3_value = (adc3_value + ((ADRESH * 256) + ADRESL)) / 2 ' get result from AN3 with avg by two
    The result vars are defined as word.
    Now the problem:
    1. Always delivers correct values
    2. Brings always the same value (50), but it should vary between 50 and 200...
    Don't know the reason why Analog 3 is always same value, can somebody help!?
    Ralf
    Nov 2008
    Read the Errata Datasheet :-(
    http://ww1.microchip.com/downloads/e...Doc/80437B.pdf
    1. Module: ADC (Analog-to-Digital
    Converter)
    ADC conversion on AN3/OSC2 will have large INL
    error up to approximately 8 LSb.
    Work around
    None for the AN3 pin. For better accuracy, use
    another analog pin.
    This PIC is a Big Bug Chip !
    Ralf
    Wink
    Hi, Ralph
    May be you also could leave some sampling time to both channels ... ( you've set it to ZERO Tad) ...
    Results would be ... less false !!!
    Nov 2008
    thanks for the answer.
    But: No effect. AN3 on this chip seems to be absolutely not useable.
