+ Reply to Thread
Results 1 to 11 of 11
Thread: Problem displaying data from GPS module & using 16f877a
    Exclamation Problem displaying data from GPS module & using 16f877a
    Hi, I am having problem showing data on hyperterminal using my GPS module and 16F877A
    GPS module EM406A DEFAULT TO BAUD 4800
    GPS is working as I connected it to PC without uC and I am getting the data. Problem is displaying it using PIC
    Hi, we are pleased to see that you are using our forum.
    We'd like you to become a member of our community. Membership is FREE, please REGISTER and view our forums without these annoying reminders!
    Once registered you may post on the forums, download from the file areas and use the WIKI without interruption.
    Connections are as follow -:
    PortC.4 ----Gps Tx (TTL 0-5V)
    PortC.6 ----- MAx232 pin11
    Max232 pin14 ----- Rs232 pin 2 (Pc Rx)
    Gnd common
    FOLLOWING IS THE CODE:
    All pins digital, comparator off, analog channels off.
    sms var byte[35]
    Include "modedefs.bas"
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 6
    DEFINE DEBUG_BAUD 4800
    DEFINE DEBUG_MODE 0
    ab:
    HIGH RED
    serin2 portc.4,4800,[WAIT("$GPRMC"),STR sms\35]
    DEBUG STR sms\17,13
    pause 3000
    LOW RED
    goto ab
    Is somthing wrong with the code or the hardware? Thanks
    ___________________
    WHY things get boring when they work just fine?
    Dec 2005
    If the GPS works connected to a PC, it means its output is inverted.
    You need to modify your
    Reread the manual for SerIn2 - your mode value is incorrect.
    Exclamation
    Thanks for the input but could you help me advising what baud should I use, I am little confused about this. The datasheet of the module does says 4800 is default (Datasheet attached) and manual also has only one option for 4800 baud.
    I also want to say that I connected the gps module via MAX232 to the PC.Thanks
    ___________________
    I always wondered why the manual does not list all of the modes??? Save some paper???
    http://www.melabs.com/resources/ser2modes.htm
    http://mackrackit.cambs.net/
    Question
    Thanks for the info. I added the statement:
    baud1 con 16572
    and changed the following statement:
    serin2 portc.4,baud1,[WAIT("$GPRMC"),STR sms\35]
    Still no luck. Please help.
    ___________________
    May 2008
    Italy
    Which is the value of baud1?
    When you use wait string, remember that they are case sensitive "$GPRMC" is different from "$gprmc"
    I already suggested you, in another thread, to use a timeout sequence. Your serin2 instruction will wait for the identifier and then it will wait for a string of 35 characters. If your GPRS will send only 34, serin2 will remain there waiting forever.
    One turn around is the use of the timeout:
    GPRSLoop:
    sms[0]=0
    serin2 portc.4,baud1,500,GPRSTest,[WAIT("$GPRMC"),STR sms\35]
    GPRSTest:
    If sms[0]<>0 then goto label ??     ' here you check byte[0] for data presence
    goto GPRSLoop
    Al.
    Quote Originally Posted by financecatalyst View Post
    baud1 con 16572
    If a RS232 chip was needed to talk to a PC then baud1 should be 188.
    Talking
    Thanks guys. Itīs up and running now. Love this Forum
    ___________________
    In case someone else has a similar problem... What was the fix?
    Red face
    The array was too small to hold the sequence of characters and code was kinda stuck there. I changed it to the following :
    Baud con 188
    sms var byte[65]
    start:
    serin2 portc.4,baud,500,start,[WAIT("$GPRMC"),STR sms\65\13] ' added 13 as well
    If sms[0]<>0 then goto display
    goto start
    These are the only corrections I have done and it fired up.
    ___________________
    Apr 2010
    Could u please provide the full program ?
+ Reply to Thread
  1. Using Nokia LCD
    By BobP in forum mel PIC BASIC Pro
    Last Post: - 27th February 2013, 08:05
  2. Read/Write Problem
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 10th February 2010, 01:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    By Don Mario in forum mel PIC BASIC Pro
    Last Post: - 28th November 2004, 23:56
Members who have read this thread : 4
