Strangely behaving 16F877a
Results 1 to 5 of 5
    Question Strangely behaving 16F877a
    Hi
    I am using an external oscillator 4MHz. My program simply toggles one pin every 30ms.
    Problem is that I see sometimes the toggling if I touch the PIC,leg of the capacitor (earth) or touch the bench the circuit is left on and sometimes it works fine and sometimes the led is just on constantly.
    What could be the reason for this???
    ___________________
    WHY things get boring when they work just fine?
    Quote Originally Posted by financecatalyst View Post
    Hi
    My first impulse would be stray capacitance. Pins should be pulled high or to ground with resistors and never left floating.
    Question
    You mean all the remaining 36 Pins? If you do then please can you also advise me suitable values.
    ___________________
    any resister from 1K to 100K... anything to pull the pin to ground...
    You could just wire them straight to ground, but you need to remember to set all the pins to input...
    Red face
    thanks for the input to all. The problem was that my MCLR pin was not made high and was left floating. Its working now.
    ___________________
  1. 16F877 vs. 16F877A
    By DavyJones in forum General
    Last Post: - 11th April 2009, 18:22
  2. help my bluetooth and PIC 16F877A?
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 06:52
  3. Read the newbee threads, 16F877A no go.
    By BobbyA in forum mel PIC BASIC Pro
    Last Post: - 31st December 2006, 03:09
  4. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 18:52
  5. 1st 16F877A program in PICBasic
    By Borisw37 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2005, 04:46
