Sure Electronics 0832 Dot Matrix Display
Results 1 to 11 of 11
    Feb 2007
    Default Sure Electronics 0832 Dot Matrix Display
    I bought 1 of these 8x32 display modules from ebay
    http://cgi.ebay.co.uk/0832-LED-Dot-M...d=p3286.c0.m14
    spent quite a lot of time looking at the datasheet and google, and put this piece of code together to demonstrate how to send data to the module.
    this simply sends a smiley face to the display.
    Feb 2008
    Quote Originally Posted by wellyboot View Post
    Hey wellyboot,
    Looks cool. I saw your led clock using 4 times the sure electronics displays. I recently bought one of those displays. They are pretty cheap and looking good.
    Do you share your code for making this clock?
    Thanks in advance.
    Feb 2007
    Hi there
    still a work in progress at present, code is in a right state!
    am working on building a slot machine, and this large display will simulate the reals spining in led graphics.
    I rewrote the code from the smaller clock to make the bigger clock and now rewritting this for the slot machine
    so havnt really kept the clock code, but to be honest its not very difficult to write especially when you look round this forum for bits and pieces of code.
    Feel free to ask me if you need any help.
    Feb 2005
    Im about to make a slightly larger matrix (11x11) what happens with brighness?
    lets say for example, if you lit 2 leds in one row and 6 in the next, is the brightness the same? if there is indeed a difference in brightness, is it noticeable?
    Feb 2007
    I usume you are going to have 11 x 11 display modules.
    as far as i can tell the brightness remains constant, on my 2 x 2 display module (64x16 Leds) clock the brightness of the leds looks the same regardless of what is being displayed.
    each module can draw upto 220mA (all leds on)
    Jun 2005
    Germany
    Smile Please give me a scrolling example for the Sure Electronics 0832 Dot Matrix Display.
    Hello wellyboot,
    I have built up the example. Sure Electronics 0832 Dot Matrix Display with the sure.txt code. It works well.
    How can the smile be taken to scroll on the Display? Please give me a scrolling example for the Sure Electronics 0832 Dot Matrix Display.
    Many thanks in advance
    SWITZERLAND (french speaking)
    Default Brightness control
    Hi wellyb00t,
    Can you please tell how you control the led's brightness?
    Roger
    Feb 2007
    Hi wellyb00t,
    In the code (post 1) change this line:
    address = %10101111 'pwm 16/16
    bits 0,1,2,3 control brightness
    the above line is for max brightness
    address = %10100000 'pwm 1/16 min brightness
    address = %10100111 'pwm 8/16 mid brightness
    This can be found in the datasheet 'PWM Duty' in the command summary (3.3)
    gid2010's Avatar
    gid2010 Guest
    Default Scrolling the Smiley
    Quote Originally Posted by vtt-info View Post
    Hello wellyboot,
    Hello,
    You can scroll the Smiley (left or right) by doing the following, in the main loop of the code:
    while(1)
    for(j=0;j<32;j++) // for scrolling 32 times
    for(cnt=0; cnt<8; cnt++) // for Smiley
    dataB = dataA[cnt];
    datsend(address, dataB);
    address = address+2;
    // control the speed of scrolling
    delay_ms(400);
    // scroll the message left or right
    address = address-2; // '-' for left shift, '+' for right shift, #2 means shift by 1 column
    // clear the matrix by writing 00's
    for(i=0;i<32;i++)
    datsend(i,0x00);
    xyzabcpqr's Avatar
    xyzabcpqr Guest
    Default Re: Sure Electronics 0832 Dot Matrix Display
    Hello,
    Currently I am working on Sure Electronics 0832 Dot Matrix Display (DE-DP10XV110) which is having HT1632 Holtek IC. I want to interface it with PIC 16F1937.I am using MPLAB and HI-TECH C compiler as a software platform .
    I tried lot but nothing happened. My connections are as below:
    CS1 - RB1
    WR - RB2
    DATA - RB3
    OSC - Vcc(+5v)
    VCC
    GND
    Herewith I am attaching my code.Please help to make it running.
    Apr 2012
    Ptolemaida
    Hello friends I am new with led controlling and i bought a 32x8 led display from sureelectronics.
    My question is: Does the HT1632C has any decoder on it ?? for example for ABC characters, or ALL letters and ALL graphics are designed by "me" ??!
    I've read the datasheet of H1632C but there were some parts that i don't understand.
  1. Hdsp 21xx display
    By Original in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 20:07
  2. SureElectronics LED Dot Matrix Display
    By DanPBP in forum Off Topic
    Last Post: - 4th October 2009, 20:10
  3. Replies: 14
    Last Post: - 26th September 2007, 05:41
  4. Flashing!! LED Dot matrix problem
    Last Post: - 4th December 2006, 09:45
  5. 4x16 Dot Matrix LCD control is possible?
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 1st September 2005, 09:56
