Aren't all the commands just OPCodes, ie each command "name" is assigned a constant value at the beginning of the program, like:
SIN CON $47
COS CON $48
A workaround would be to simply rename the SIN and COS to SINUS and COSINUS and assign the correct OPCode to that name instead, like:
SINUS CON $47
COSINUS CON $48
Then you use SINUS and COSINUS in the Shiftout statment instead of SIN and COS
Another workaround is to simply replace the the constants SIN and COS in the Shiftout statement with their respective OPCodes.
