Probe to read quadrature encoder with DT_INT need help
Results 1 to 12 of 12
    May 2007
    Republic Serbia
    Unhappy Probe to read quadrature encoder with DT_INT need help
    When I compile MCSP return next error's (compile with MPASM).
    PBP 2.50C
    Procesor 16F877 @ 20MHz.
    ERROR's:
    error[128]877 qei.asm 87 : Missing argument(s)
    error[118]877 qei.asm 87 : Overwriting previus address contents (2007)
    @ __config & _WDT_ON & _PWRTE_OFF & _BODEN_ON & _LVP_OFF & _CP_OFF & _DATA_CP_OFF
    '@ Device pic16F877, HS_OSC, BOD_ON, PWRT_OFF, WDT_ON, PROTECT_OFF
        Define osc 20
        DEFINE HSER_SPBRG 64  ' 19200 Baud @ 20MHz, 0.16%
        ADCON1 = 7
        old_val VAR BYTE
    	new_val VAR BYTE
    	direction_bit VAR BIT
    	enc_counter VAR WORD
        enc_counter = 10000
    	new_val = PORTB & %00000011
        TRISB = %00000011
        INCLUDE "DT_INTS-14-0.bas"     ' Base Interrupt System
        INCLUDE "ReEnterPBP-0.bas"     ' Include if using PBP interrupts
            INT_Handler    INT_INT,  _QEI,   PBP,  yes
    @ INT_ENABLE   INT_INT     ; enable external (INT) interrupts
    rs232:
        pause 1
        goto rs232
        QEI:
    	old_val = new_val
    	IF new_val = old_val Then again
    	direction_bit = old_val.bit0 ^ new_val.bit1
    	IF direction_bit = 1 Then
    			enc_counter = enc_counter + 1
    		enc_counter = enc_counter - 1
    		hserout [dec enc_counter]
    	again:
    @ INT_RETURN
    May 2008
    Italy
    _QEI label ; PBP and yes not correctly allined. Change as per the following
    Al.
    May 2007
    Republic Serbia
        Define osc 20
        ADCON1 = 7
        old_val VAR BYTE
    	new_val VAR BYTE
        enc_counter = 10000
        TRISB = %00000011
            INT_Handler    RBC_INT,         _LED,   PBP,  yes
        rs232:
        pause 1
        goto rs232
        LED:
    	old_val = new_val
    	again:
    @ INT_RETURN
    PBP 2.47 , 250 or 250C in all version same errors ???
    can you edit and post my code full please sir?
    Lightbulb
    Your error is double ...
    1)
    do not use " & " before the first data : WDT_ON ...
    2)
    You have to comment the CONFIG lines already existing in your 16F877 .inc file ( PBP folder ) if you want custom ones ... see FAQ for details.
    May 2007
    Republic Serbia
    Acetronics your help is 100% work.
    Thank's many thanks man.
    And one question more...how DT interupt can be fast ?
    Quote Originally Posted by phoenix_1 View Post
    I do not know exactly ...
    but it's roughly the time to save and restore all the PBP variables in use, added to the "classic" ASM interrupts time ...
    You can Use the MPLAB SIM ... You will have a very good idea !
    May 2007
    Republic Serbia
    DT_INT with TIMER_1 and led blink work 100% on 16f877 when I test it but:
    define OSC 20
    ADCON1 = 7
    TRISB = %00000011
    INTCON = %10001000
    LED1 VAR PORTA.0
    LED2 VAR PORTA.1
    LOW LED1
    low LED2
    INCLUDE "ReEnterPBP.bas"
        INT_Handler RBC_INT, _TEST, PBP, yes
    @   INT_ENABLE RBC_INT
    PAUSE 1
    GOTO Main
    '---[RBC_INT - interrupt handler]------------------------------------------
    TEST:
    high led1
    high led2
    @       INT_RETURN
    Dont want to work for me...why ?
    Lightbulb
    Just try PortB.7 and PortB.6 ...
    and read the '877 Databook , Interrupts section :
    WHICH are the 4 pins that create "interrupts on change" ???
    HOW to avoid the " Mismatch condition " ???
    May 2007
    Republic Serbia
    These code count pulses from one pin of quadrature encoder good and fast.
    It use RB0 INT very good.
    Now I need idea to implement full reading quadrature encoder A and B inputs with count of pulses and direction indication..
    Encoder is with 500 pulses per full revolution.
    How - need idea..?
    define OSC 20
    ADCON1 = 7
    TRISB = %00000011
    a var word
    a = 0
    INTCON = %10010000 ; Enable INTE RB0 interrupt $90
        INT_Handler INT_INT,    _TEST,  PBP, yes
    if a >= 5000 then
    a = 0
    hserout [ dec a ]
    GOTO Main
    '---[INT_INT - interrupt handler]------------------------------------------
    TEST:
    a = a + 1
    @   INT_RETURN
    Regards Robert
    May 2008
    Italy
    Connect encoder channel A to portB.0 (I assume you already have it) and channel B to portB.1. Since channel A is out of phase on channel B turning your encoder CW channel A will be high before channel B and turning it CCW channel B will be high first.
    In your interrupt handler check the above conditions
    If portB & %00000011 = 1 Then
    a = a + 1
    CW = 1
    Else
    a = a - 1
    CW = 0
    Endif
    If variable CW is 1 then your motor is turning clockwise if CW = 0 then is turning counterclockwise, while word variable a will contain the updated count.
    Al.
    May 2008
    Italy
    I have forgotten to say, in my previuos post, that the code snippet is not a quadrature count, and it counts only channel A, while Channel B is used only for direction. So total count per encoder turn will be n/2.
    To get a quadrature count you need to detect the rising and falling edges of the square waves, thing that is not possible with the pic you have in use. To obtain the quadrature count you either need additional external logic or you have to choose a pic with the quadrature counter. (Much easier)
    Al.
    May 2007
    Republic Serbia
    Al.
    Yes I was buy today 18F4431 for start...
    But there is 400 pages of datasheet and I need to be a WIZARD to SETUP that PIC
    Regards Robert
  1. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 14:45
  2. Cleaning up code
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2009, 07:14
  3. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 11:20
  4. Write and Read from eeprom
    Last Post: - 9th June 2007, 14:56
  5. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 21:56
