High Power Consumption in Sleep Mode
Results 1 to 10 of 10
    Feb 2005
    GREECE
    Default High Power Consumption in Sleep Mode
    Hello boys and girls,
    I use for a first time sleep mode with my 16F627 pic after searching and reading to the forum.
    I manage to send my pic to sleep mode and I can wake it up with interrupt on portb.0.
    My problem is the big Consumption in sleep mode.It is about 370uA
    That is my code:
    @ DEVICE  PIC16F627, XT_OSC
    @ DEVICE pic16F627, WDT_OFF
    @ DEVICE pic16F627, PWRT_ON
    @ DEVICE pic16F627, MCLR_OFF
    @ DEVICE pic16F627, BOD_OFF
    @ DEVICE pic16F627, LVP_OFF
    @ DEVICE pic16F627, CPD_OFF
    @ DEVICE pic16F627, PROTECT_OFF
    DEFINE  OSC 4
    DEFINE NO_CLRWDT 1
    CMCON = 7  'Turn off comparators
    VRCON=%01101100 'VRCON bit7 is OFF for no current drain
    OPTION_REG.7 = 0 ' 1=DISABLE INTERNAL PULLUPS,0=ENABLE
    LED VAR PORTA.2
    INTCON=%00010000 ' Interrupt Control Register
    ' 7=0 - GIE - Global Interrupt Enable
    ' 6=0 - PEIE - Peripheral Interrupt Enable
    ' 5=0 - TOIE - TMR0 Overflow Interrupt Enable
    ' 4=1 - INTE - RB0/INT Enable
    ' 3=1 - RBIE - PORTB change interrupt Enable
    ' 2=0 - TOIF - TMR0 Overflow Flag
    ' 1-0 - INTF - RB0/Ext Interrupt Flag
    ' 0=0 - RBIF - PORTB Interrupt Flag
    OPTION_REG.6=1 ' 1=RB0 Rising-Edge Trigger, 0=Falling-Edge Trigger
    CYCLE:
    INTCON.1=0 ' Reset RB0 Flag
    INTCON.0=0 ' Reset PORTB change Flag
    ' Sleep
    LOW LED
    @ SLEEP
    @ nop
    @ nop
    @ nop
    Pause 100 ' Needed for system Wake-Up
    HIGH LED
        PAUSE 5000
        LOW LED
    GOTO CYCLE
    My hardwarev is simply a resistor from porta.2 with a Led to GND and XTL with 2capasitors.NOTHING MORE
    Please advice
    Nikos
    Hi Nikos,
    Check this thread out, same problem, different chip.
    http://www.picbasic.co.uk/forum/showthread.php?p=75528
    Hi Nikos,
    using this code:
    ;@ DEVICE  PIC16F648A, INTRC_OSC_NOCLOCKOUT
    ;@ DEVICE pic16F648A, WDT_OFF
    ;@ DEVICE pic16F648A, PWRT_ON
    ;@ DEVICE pic16F648A, MCLR_OFF
    ;@ DEVICE pic16F648A, BOD_OFF
    ;@ DEVICE pic16F648A, LVP_OFF
    ;@ DEVICE pic16F648A, CPD_OFF
    ;@ DEVICE pic16F648A, PROTECT_OFF
    @ __CONFIG _INTOSC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _LVP_OFF & _BODEN_OFF & _BOREN_OFF
    DEFINE  OSC 4
    DEFINE NO_CLRWDT 1
    PORTA=0
    TrisA = 255
    trisb = %00000001 'RB0 as  input
    CMCON = 7        ' Turn off comparators
    'VRCON = %01101100  ' VRCON bit7 is OFF for no current drain
    OPTION_REG.7 = 1 ' 1=DISABLE INTERNAL PULLUPS,0=ENABLE
    OPTION_REG.6 = 1 ' 1=RB0 Rising-Edge Trigger, 0=Falling-Edge Trigger
    LED VAR PORTA.2
    INTCON = %11010000 ' Interrupt Control Register
    on interrupt goto cycle2
    CYCLE:
    LOW LED
    'pause 500
    @  SLEEP
    ;@ nop
    ;@ nop
    ;@ nop
    disable
    cycle2:
    HIGH LED
        PAUSE 500
        LOW LED
        PAUSE 500
    INTCON = %11010000
    enable
    GOTO CYCLE
    Which is a derivitive of your code, I fought with the interrupt a bit.
    By setting port a as all inputs the sleep current dropped from 3.71 ma to 0.12 ma
    The 16F648A was as close a chip to yours as I have.
    Feb 2005
    GREECE
    Thanks Joe for your code...
    I have just test it with the same results.
    The Consumption is still 0.37 ma or 370uA.
    I do not understand what is wrong.The setup is the minimal it ca be...
    Feb 2005
    GREECE
    I find it.....
    Now it sleeps with the minimum current...just 0.1 ma or 100uA.
    The pin MCLR was flatting and I add the 4.7k to Vcc.
    Many Many thanks joe for your code.
    Nikos
    Quote Originally Posted by ngeronikolos View Post
    I find it.....
    Nikos
    You are welcome. I had turned MCLRE off in my config.
    Sep 2014
    Default Re: High Power Consumption in Sleep Mode
    Quote Originally Posted by Archangel View Post
    I added & _BODEN_OFF to __CONFIG and reduced the current from 120uA to 5uA
    Sep 2010
    Las Vegas, NV
    Just looking at your code and decided to ask a question or two.
    Why do you set the same configs twice? I think either will accomplish the task but they may be contradictory also.
    Why are some configs spelled differently from one to the other? PWRT/PWRTE, INTRC_OSC_NOCLOCKOUT/INTOSC_OSC_NOCLKOUT and MCLR/MCLRE are the ones I see as different.
    Which code is that exactly? I'm sort of guessing here so if I'm referring to the wrong one please disregard this.
    The only code in this thread, which could be interpreted as if that's happening is in the third post, by Archangel, but he's not setting the same config twice. One set is commented out:
    My guess is that one set (the ones that are commented out) is/was targeting the now obsolete PM-assembler which came bundled with PBP while the other is for Microchips MPASM assembler.
    Sep 2010
    Las Vegas, NV
    My bad. I sincerely apologize for any confusion I might have generated. In the future I'll cut and paste the code to which what I refer to eliminate any obfuscation.
    Sorry for using your time but thanks for a possible explanation and pointing out my error.
  1. Replies: 4
    Last Post: - 9th October 2009, 08:01
  2. Battery powered applications
    By NavMicroSystems in forum Off Topic
    Last Post: - 22nd June 2009, 07:12
  3. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 20:08
  4. Old and beyond help ?
    By DavidFMarks in forum mel PIC BASIC Pro
    Last Post: - 11th December 2008, 15:23
  5. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 02:37
