hi everyone, i'm back again...
I'm still having trouble with my RPM counter... it's still giving me stupid readouts...
i've got PWM1 linked straight into RC0/T1CKI and runing at 50% duty and 1KHz.
TMR1 is therefor set to counter mode and 1:1 prescaler...
However, it hapily runs my pulse motor so the control side is fine... but the RPM counter seems to stay at 5727 or 6136 which i don't understand... even when i slow the rotor down by hand it stays at those readings...
I just don't get why it's doing that... Can someone take a look at my program?
include "bs1defs.bas"
Define CONF_WORD = 0x3F3A
Define OSC 24 ' Set clock speed
SEROUT2 PORTB.5,16390,[10,13,10,13]
DEFINE SER2_BITS 8 ' Ser2 number of data bits
ADCON0.7 = 0 ' ADC clock set to Fosc/2
ADCON0.6 = 0 ' ADC clock set to Fosc/2
ADCON1.6 = 0 ' ADC clock set to Fosc/2
INTCON = 0 ' Disable all interupts
'RCSTA = %10010000 ' Enable serial port and continuous receive
'TXSTA = %00100100 ' Enable transmit and asynchronous mode with BRGH 1
'SPBRG = 20 ' Set baud rate to 57600 with 20mhz clock (BRGH = 1)
ADT1 var word ' Create ADT1 to store curent ad conversion for AD channel 0
ADT1MAX var word ' Create ADT1MAX to store curent ADC0 max val
ADT1MAX = 0
ADT1VAL var word
ADT1VAL = 0
ADV1 var word
VOLT1H var word
VOLT1L var word
C1N var bit
C1N = 0
C1S var bit
C1S = 0
PCOUNTER var byte
PCOUNTER = 0
PTICK var bit
PTICK = 0
RPM var word
RPM = 0
TMR1_VAL var word
TMR1_VAL = 0
cycle var word
'aveadc1 var word
'averpm var word
TMR1EXT var byte
rpm0 var bit
rpm0 = 0
'datalog var word
'datalog = 0
'TRISE = 255 ' Set PortE to all inputs
TRISD = 0 ' Set PortD to all outputs
TRISC = 0 ' Set PortC to all outputs
TRISB = 0 ' Set PortB to all outputs
TRISA = 255 ' Set PORTA to all input
ADCON1 = 0 ' PORTA is analog
PORTB = 0
PORTC = 0
PORTD = 0
HPWM 1,127,1000
SEROUT2 PORTB.5,16390,["INITIALISED",10,13]
gosub TMR1setup
TMR1setup:
PIE1.0 = 0 ' Disable TMR1 interupt (double check)
T1CON.5 = 0 ' Setup TMR1 timings
T1CON.4 = 0 ' Setup TMR1 timings
T1CON.3 = 1
T1CON.1 = 1
T1CON.0 = 1
FOR cycle = 1 to 3000
gosub getadc
gosub control
gosub backemfreuse
gosub rpmcounter
'gosub avecounter
NEXT cycle
gosub adcvonvert
gosub telemetry
getadc:
ADCIN 0, ADT1
ADT1 = ADT1 / 64
'write datalog, adt1.highbyte
'write datalog+1, adt1.lowbyte
'datalog=datalog+2
'if datalog > 255 then
'datalog = 0
'endif
adcvonvert:
VOLT1H = ((48 * ADT1) / 10000) ' calculate voltage above decimal place using FP
VOLT1L = ((48 * ADT1) - (((48 * ADT1) / 10000) * 10000)) / 100 ' calculate voltage below decimal place using FP
'avecounter:
'aveadc1 = (aveadc1/2) + (ADT1/2)
'return
rpmcounter:
if PCOUNTER = 4 then ' wait for 4 pulses befor doing RPM calc
T1CON.0 = 0 ' Pause TMR1
if PIR1.0 = 1 then ' if TMR1 has overflowed we set the RPM to 0
TMR1L = 0
TMR1H = 0
rpm0 = 1 ' Set RPM overide
PIR1.0 = 0
TMR1_VAL.lowbyte = TMR1L ' Load TMR1 Low end byte
TMR1_VAL.Highbyte = TMR1H ' Load TMR1 High end byte
if rpm0 = 1 then ' RPM overide
RPM = 0 ' if RPM overide set RPM to 0
'averpm = 0 ' if RPM overide set aveerage RPM to 0
rpm0 = 0 ' if RPM overide RESET rpm OVERIDE
ELSE ' If their is no RPM overide...
RPM = ((100 / TMR1_VAL) * 60) / 10 ' RPM calculation using simple floating point calculations
'averpm = (averpm/2) + (RPM/2) ' calculate average RPM
PCOUNTER = 0 ' reset pulse counter to 0
TMR1L = 0 ' reset TMR1 low to 0
TMR1H = 0 ' reset TMR1 high to 0
gosub TMR1setup
T1CON.0 = 1 ' restart TMR1
telemetry:
'HSEROUT ["V1:",DEC5 VOLT1H,".",DEC5 VOLT1L," RPM:", DEC5 RPM,10,13]
SEROUT2 PORTB.5,16390,["V1:",DEC VOLT1H,".",DEC VOLT1L," RPM:",DEC RPM,10,13]
rpm = 0 ' reset average RPM
control:
IF ADT1 > 128 then ' wait for positive voltage from trigger coil
LOW PORTD.7 ' make sure backemf re-use is off
high PORTB.0 ' commence pulse
C1N = 1
IF PTICK = 0 then ' if this is the first run to power the dirve coil
PCOUNTER = PCOUNTER + 1 ' increment the pulse counter
PTICK = 1 ' makes the tick 1 to stop pcounter being incremented untill drive turns off
IF ADT1 < 128 then ' if trigger voltage is low
LOW PORTB.0 ' turn off drive puls
C1N = 0
IF PTICK = 1 then ' if pulse tick is high
PTICK = 0 ' set pulse tick to low
backemfreuse:
if C1N = 0 then
High PORTD.7
Else
LOW PORTD.7
