4 serial inputs 1 chip
+ Reply to Thread
Results 1 to 10 of 10
    Nov 2007
    Default 4 serial inputs 1 chip
    I am beginning a new project. I want to connect 4 Parallax RFID readers to a PIC 16F877.
    I have already have the code written for one reader, but now I need to expand to 4. I know I will need to use ports other than only the internal USART.
    Does anyone have an idea how I might "scan" the 4 ports, and when an input is found on one of them collect the data?
    It seems like I am asking for an interrupt routine, but maybe there is some simpler method using IF, Then statements. Has anyone got an idea?
    Dan
    Dec 2005
    What baudrate?
    Quote Originally Posted by nukte View Post
    Do you have a spare MCU pin on the reader's pics? If so you could hook the readers all to the usart with a series resistor on each, then when a reader sends data it could pull that spare pin low which signals the other readers to standby, (all spare pins hooked together). Just make sure the reader's output pins Idle in the High state.
    Dec 2005
    The datasheet for the reader says it is 2400 bps. I would not use a PIC. The ZX-328n from ZBasic can support up to 4 software UARTS that are full duplex, buffered, and operate in the background (with 4 UARTs, the max speed is 9600) . The ZX-328n has a built-in bootloader (uses the highspeed hardware UART) and the ZBasic compiler is free. The ZX-328n costs $10. You will to add the crystal, caps and an inverter for the hardware UART but this project will be child's play using it while it will be difficult with a PIC & PBP.
    Nov 2007
    Default Wish to stay with PIC
    Thanks Dave but the design must be implemented with PIC. But I will check on your chip recommendation for future designs
    Nov 2007
    Default No PICS on the reader
    Quote Originally Posted by Joe S. View Post
    Almost perfect and a very good idea, but I don't have any pics on the reader boards, just the RS232 (MAX 232) chip. So I can only receive the card data at the PIC.
    Dec 2005
    Then you'll need to look at Darrel's Instant Interrupts.
    Or, if you don't have to worry about simultaneous inputs, look at a DG409 and http://www.maxim-ic.com/appnotes.cfm/an_pk/588.
    They have CTS and RTS lines that work pretty much just that way.
    That looks like his solution Dave.
    Nov 2007
    Smile Good answer Dave
    Think that's the answer, I like having lots of control, and it's easy to know just which port will be working. Thanks to everyone (Again).
    You're a great bunch and I'm proud to know you
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Displaying messages with only 7 (or 4) LEDs on a stick...
    Last Post: - 20th May 2007, 09:35
  3. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 18:42
  4. Code check -- button not working
    By docwisdom in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2006, 23:43
  5. New member
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 28th February 2004, 23:44
