Even Parity Check, How?
Results 1 to 2 of 2
    Mark Scotford's Avatar
    Mark Scotford Guest
    Default Even Parity Check, How?
    I'm slowly getting there, got HPWM, ADC, I2C to work. Now I am getting to Serial, I have to follow somebody else's protocol and they have specified that I use a Block Check at the end of the data string. They want "Even Parity Check (exclusive -OR)" is there anywhere I can find information on explaining to a non-maths person what this means, in very simple terms?
    It depend on how your data in transmit.
    Some will use send serial 8 bits as
    7 databits + parity bit + stop bit.
    In this case you just have to test the 8th bit
    Some other will send serial 9 bits as
    8 databit + parity bit + stop bit.
    In this case you just have to test the 9th bit
    tell us more about your hardware and what you plan to do.
  1. HARDWARE I2C SAMPLE CODE question
    By Michael Wakileh in forum Code Examples
    Last Post: - 16th June 2009, 22:07
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  3. PIC16F877A - Timer0 won't interrupt
    By WishMaster^ in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 09:25
  4. Code check -- button not working
    By docwisdom in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2006, 23:43
  5. Debug with parity?
    By cmolson in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2005, 01:23
