PIC18F1220 RA4 using PULSIN ?
Results 1 to 6 of 6
    Nov 2007
    Default PIC18F1220 RA4 using PULSIN ?
    Is there any good reason that I can't get the RA4 input to work with PULSIN? I am using a PIC18F1220 with a 20MHZ resonator. PULSIN works fine on any PORTB pin, but won't fly on RA4. RA4 works as a simple digital input; slow on/off transitions; but when looking at the output from a R/C receiver (digital proportional signals), it counts zero pulses. Like I said, all the hardware/software works fine on port B.
    I went through two days of hell trying to configure this thing, but apparently that is now working (CONFIG statement in the P18F1220.INC file, which gives warning errors). I have experience using this same code and logic on three other PICs. I am just trying to convert it over to this one.
    Any help would be appreciated. And yes I have searched and searched and read all of the config links, PIC data sheets, etc. Thanks in advance.
    sinoteq's Avatar
    sinoteq Guest
    Default Input buffer
    Hi
    This problem have been up before in the forum. http://www.picbasic.co.uk/forum/showthread.php?t=11236 I bet the reason that RA4 does not work is because the Schmitt trigger buffer on that pin. The easy explanation is that your R/C receiver is a 3V device and you run your PIC on 5V. You can solve this in many different ways depending on what you feel like doing. The easiest is a pull up resistor on the RA4 input to boost the voltage. This will however feed a higher voltage into the R/C receiver and that might be a problem. Or you change the voltage to 3V.
    Where in the datasheet is this? Under DC Characteristics datasheet page 250 under 22.3
    By the way I think the datasheet for PORTA has a big misstake in it.
    Nov 2007
    Yes indeed! That is my problem. RA4 is a Schmitt trigger input and my Rx puts out 3V pulses with the PIC running at 5V. Thank you very much for saving me a bunch more time and headache.
    Unfortunately, a pull-up won't fix it, so time for a hardware design change.
    Sep 2005
    Campbell, CA
    When I have to do level shifting I find that a 74HCTxx gate does a good job. Power it from 5V.
    Charles Linquist
    sinoteq's Avatar
    sinoteq Guest
    What do you have on RA1? If it is empty make a solder bridge and you have your hardware change.
    Nov 2007
    Problem was resolved by reassigning I/O. Good tips though. Thanks to all. I learned something (always a good thing).
  1. Replies: 17
    Last Post: - 12th April 2014, 02:17
  2. Better understanding PULSIN
    By Wirecut in forum mel PIC BASIC
    Last Post: - 29th June 2008, 10:17
  3. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 08:02
  4. Pulsin 16F819 problem
    By rekcahlaer in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 13:52
  5. PULSIN and RCTIME
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 14:45
