+ Reply to Thread
Results 1 to 4 of 4
Thread: Ultrasonic distance sensor with PIC16F84A
    Dec 2008
    Default Ultrasonic distance sensor with PIC16F84A
    All
    I used the code below to light a LED if the distance is less than 12 inches, the code runs , but for only 3 iterations, some time 4 iterations, I cannot seem to find out why, can anyone help.
    I am using the parallax ping sonar sensor
    code
    SYMBOL Ping = 7
    ' -----[ Constants ]-------------------------------------------------------
    SYMBOL Trigger = 1 ' 10 uS trigger pulse
    SYMBOL Scale = 10 ' raw x 10.00 = uS
    SYMBOL RawToIn = 889 ' 1 / 73.746 (with **)
    SYMBOL RawToCm = 2257 ' 1 / 29.034 (with **)
    SYMBOL IsHigh = 1 ' for PULSOUT
    SYMBOL IsLow = 0
    ' -----[ Variables ]-------------------------------------------------------
    SYMBOL rawDist = W1 ' raw measurement
    SYMBOL inches = W2
    SYMBOL cm = W3
    ' -----[ Initialization ]--------------------------------------------------
    Reset:
    ' -----[ Program Code ]----------------------------------------------------
    GOSUB Get_Sonar ' get sensor value
    inches = rawDist ** RawToIn ' convert to inches
    'cm = rawDist ** RawToCm ' convert to centimeters
    if inches < 12 then pushd
    Hi, we are pleased to see that you are using our forum.
    We'd like you to become a member of our community. Membership is FREE, please REGISTER and view our forums without these annoying reminders!
    Once registered you may post on the forums, download from the file areas and use the WIKI without interruption.
    'DEBUG CLS ' report
    'DEBUG "Time (uS)..... ", #rawDist, CR
    'DEBUG "Inches........ ", #inches, CR
    'DEBUG "Centimeters... ", #cm
    PAUSE 500
    GOTO Main
    ' -----[ Subroutines ]-----------------------------------------------------
    ' This subroutine triggers the Ping sonar sensor and measures
    ' the echo pulse. The raw value from the sensor is converted to
    ' microseconds based on the Stamp module in use. This value is
    ' divided by two to remove the return trip -- the result value is
    ' the distance from the sensor to the target in microseconds.
    Get_Sonar:
    LOW Ping ' make trigger 0-1-0
    PULSOUT Ping, Trigger ' activate sensor
    PULSIN Ping, IsHigh, rawDist ' measure echo pulse
    rawDist = rawDist * Scale ' convert to uS
    rawDist = rawDist / 2 ' remove return trip
    pushd:
    high 1 'high RB 1
    LOW 1
    PAUSE 500
    HIGH 1
    PAUSE 1000
    LOW 1
    PAUSE 500
    One problem is that your have a GOTO PUSHD...
    ... but your have a RETURN at the end of the PUSHD code.
    Change your code to read...
    if inches < 12 then GOSUB pushd
    Dec 2008
    Default Loop terminates on its own
    Thank you, but thats not the problem, there must be something inherinant to the ultrasonic sensor that wont let it infinite loop without being reset or something,
    Can anyone tell me why after four object detects it goes off based on the code I provided?
    If you have added the GOSUB, then your code is now good.
    You could always check if RawDist=0 then light an Error LED, that way you can check if you are actually getting sensible results back from your Sensor.
+ Reply to Thread
  1. Questions on ultrasonic distance finder
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 20th April 2010, 21:19
  2. Distance Measurement Chips
    By sayzer in forum Off Topic
    Last Post: - 2nd February 2007, 20:57
  3. Serial Communication Using PIC16F84A
    By fazan83 in forum GSM
    Last Post: - 22nd January 2007, 02:56
  4. ultrasonic sensor
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 9th May 2006, 20:26
  5. GPS waypoint distance in Km
    By Art in forum Code Examples
    Last Post: - 28th August 2005, 01:59
Members who have read this thread : 7
