need help for APR6008 SPI interface
Results 1 to 6 of 6
    Mar 2007
    Mumbai-INDIA
    Talking need help for APR6008 SPI interface
    Hi All,
    I am making VHF repeater interface for amateur radio, 2m band. I need help to control APR6008 using SPI. I have tried reading datasheet but didnot understand much, google search didnt help much. I want to be able to record and play 16 messages of 30 sec each, or 8 msg. of 1 min.
    Any help would be very much appreciated.
    See my exsisiting simple repeater interface http://www.vu2bbb.blogspot.com/
    Thanks in advance
    regards
    Mahesh
    vu2iia
    vu2iia
    See PIC iPod wav player
    Plays CD quality 44k (8 bit stereo or 16 bit mono) wav files from an SD card.
    Up to 512 files or 2 GB.
    Project specific parts are about $14.00 (less speaker, 5v regulator, caps, pot, etc.)
    Presently in Proton but am porting to PicBasicPro.
    Norm
    Bombay, India
    Hi Mahesh
    I've not used this particular part, but have used the APR48000 and another similar one. The code is in 8051 C, but if it helps, I have attached it here.
    		APR48000 voice record/playback IC routines
    /* Send a command to the APR48000
      Cmd is the APR Opcode
    	Adr is the parameter for the opcode
    	Send order is Msb-Lsb
    	   First the Cmd (Lower 6 bits), then Adr (Lower 15 bits)
    	PWRUP (4) (0x2)
    	REC   (9)
    	PLAY  (D)
    	FWD   (3)
    	STOP  (6)
    void	CommandAPR(byte Cmd, uint Adr) {
    byte BitCnt;
    	Cmd <<= 3;
    	Adr <<= 1;
    	APRcs = 0;
    	for (BitCnt = 0;BitCnt < 5;BitCnt++){
    		APRdi = Cmd & 0x80;
    		APRclk = 1;
    		Cmd = Cmd << 1;
    		APRclk = 0;
    	for (BitCnt = 0;BitCnt < 15;BitCnt++){
    		APRdi = Adr & 0x8000;
    		APRclk = 1;
    		Adr <<= 1;
    		APRclk = 0;
    	APRcs = 1;
    Mar 2007
    Mumbai-INDIA
    Smile
    Thank you norm for your reply. Its an interesting project.
    Dear Jerson can I request you to help me convert the code into PBP. Trust me it will help many others like me. Hope u will find some time for it.
    regards
    Mahesh
    Bombay, India
    I think it is quite straight forward. Anyway, here goes. Unchecked, untested, use at your own risk and consequence
    ' Send a command to the APR48000
    '       APR_Cmd is the APR Opcode
    '	APR_Adr has the parameter for the opcode
    '	Send order is Msb-Lsb
    '	   First the Cmd (Lower 6 bits), then Adr (Lower 15 bits)
    '	PWRUP (4) (0x2)
    '	REC   (9)
    '	PLAY  (D)
    '	FWD   (3)
    '	STOP  (6)
    APR_cs         var  PORTA.0  ' define your own
    APR_di         var  PORTA.1   ' define your own
    APR_clk        var  PORTA.2   ' define your own
    APR_Cmd     var  byte
    APR_Adr       var  word
    BitCnt:          var  byte
    CommandAPR:
            APR_Cmd = APR_Cmd << 3
            APR_Adr = APR_Adr << 1
    	APR_cs = 0;
            for BitCnt = 0 to 5
    		APR_di = APR_Cmd.7
    		APR_clk = 1;
                    APR_Cmd = APR_Cmd << 1         ' remove the bit we transferred
    		APR_clk = 0;
            next
            for BitCnt = 0 to 15
    		APR_di = APR_Adr.15  'unsure of this instruction
    		APR_clk = 1
    		APR_Adr <<= 1                            ' remove the address bit transferred
    		APR_clk = 0
            next
    	APRcs = 1;
    Mar 2007
    Mumbai-INDIA
    Smile
    Dar Jerson,
    Thank you for helping me getting started, appreciate your time.
    mahesh
  1. Master SPI interface to LCD/OLED??
    Last Post: - 20th September 2009, 00:44
  2. Weird SPI interface: VIH to VIHH for CS?
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 18:25
  3. 16-bit SPI problem
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 16:42
  4. Help with MicroMag3 SPI interface to PIC
    By kaan in forum mel PIC BASIC Pro
    Last Post: - 1st June 2006, 00:20
  5. How to read a SPI serial interface
    By Sharky in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2005, 05:14
