Multiple RETURNS within a single subroutine
Results 1 to 4 of 4
    Default Multiple RETURNS within a single subroutine
    I am not sure if this is a programming style question a potential stack overflow issue.
    Is it OK to have multiple RETURN statements within a single subroutine? Is there a depth limit? I have tested the multiple return subroutine up to 10 deep with no apparent problems.
    /code
    SubCheck: 'this is the dummy subroutine
    if a = 0 then
    b = 1000
    if a = 1 then
    c = 12*a
    if j = 6 then
    d = 255
    'This is the calling code
    code, code, code
    gosub subcheck
    morecode, morecode
    /endcode
    Cheers
    Brian
    Bombay, India
    Feb 2005
    Kolkata-India
    Default I use it always
    Since any logic validation executes the return it is as good as only one return.
    Sougata
    Apr 2009
    Pittsburgh, PA
    Default It is a question of style
    Having multiple return statements like that has no effect on the stack, the return statement only comes into play when it is executed.
    However it's a programming style question that comes up now and again and one I contemplate again and again.
    When I see horrible code like this:
    IF A THEN
      IF  B THEN
        IF C THEN
          IF D THEN
            do something
          END IF
        END IF
      END IF
    END IF
    I want to change it to
    IF NOT A THEN
    IF NOT B THEN
    etc
    because from a debugging and comprehension standpoint I find it easier to be able to get out of the processing chain as soon as possible. I don't want to have to work through all those nested IFs wondering what's going to happen next.
    It's easier for me to read, write and test.
  1. Using "END" in a subroutine?
    Last Post: - 13th February 2010, 16:32
  2. Multiple PICS from Same Crystal?
    By WOZZY-2010 in forum General
    Last Post: - 6th February 2010, 15:18
  3. Multiple Pics accessing single EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 17:22
  4. subroutine with hserin
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 19th December 2007, 02:56
  5. Replies: 0
    Last Post: - 28th May 2004, 17:25
