HARDWARE I2C SAMPLE CODE question
Results 1 to 3 of 3
    Lightbulb HARDWARE I2C SAMPLE CODE question
    Hi! I just found some nice code from microchip showing a simple write/read sequence to an I2C EEPROM using MSSP in mastermode. The code is well documented so I feel I will be able to use parts of it to replace PBP statements
    even though I don't speak assembly language... Unfortunately I'm not at a computer where I can test, and I have a simple question...
    In the code there are certain define statements-and it looks
    like they are in some other compiler language....or are these in assembly?
    ; I2C connected to 24C01C (or similar) EEPROM.
    ; Write to location 0x12, data 0x34 and read it back.
    ; The MSSP module is used in I2C MASTER mode.
    #define LC01CTRLIN H'A0’ ; I2C value for CONTROL BYTE when!!!!!!!!!!!!!!!!!!!!!!!!!CONTROLBYTE for write
    ; INputing data to the EEPROM
    #define LC01CTRLOUT H'A1’ ; I2C value for CONTROL BYTE when!!!!!!!!!!!!!!!!!!!!!!!!CONTROIBYTE for read
    ; requesting OUTput from the EEPROM
    #define LC01ADDR H'12’ ; Sample value for ADDRESS BYTE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Address byte
    #define LC01DATA H’34’ ; Sample data to write to EEPROM!!!!!!!!!!!!!!!!!!!!!!!!!!!!Data to write to Address
    #define BAUD D'100’ ; Desired Baud Rate in kbps
    #define FOSC D'4000’ ; Oscillator Clock in kHz
    #include <p16F877.inc> ; Processor Include file, for standard names
    __CONFIG _CP_OFF & _DEBUG_OFF & _WRT_ENABLE_OFF & _CPD_OFF & _LVP_OFF &
    _BODEN_OFF & _PWRTE_ON & _WDT_OFF & _XT_OSC
    ORG 0 ; Start of code (location 0)
    ; *** Setup I/O ***
    clrf PORTB 		; PORTB pins set to drive low when enabled
    BANKSEL TRISC 		; BANK 1
    movlw B'00011000’ 	; RC3, RC4 are inputs for PORTC
    movwf TRISC 		; Remaining PORTC I/O lines are outputs
    clrf TRISB 		; all PORTB pins configured for output mode
    			; (enables all PORTB drivers for driving LEDs)
    ; *** Setup Registers for I2C ***
    ; Configure MSSP module for Master Mode
    BANKSEL SSPCON
    movlw B'00101000’ 	; Enables MSSP and uses appropriate
    			; PORTC pins for I2C mode (SSPEN set) AND
    			; Enables I2C Master Mode (SSPMx bits)
    movwf SSPCON 		; This is loaded into SSPCON
    			; Configure Input Levels and slew rate as I2C Standard Levels
    BANKSEL SSPSTAT
    movlw B'10000000’ 	; Slew Rate control (SMP) set for 100kHz
    movwf SSPSTAT 		; mode and input levels are I2C spec,
    			; loaded in SSPSTAT
    ; Configure Baud Rate
    BANKSEL SSPADD
    movlw (FOSC / (4 * BAUD)) - 1 ; Calculates SSPADD Setting for
    movwf SSPADD ; desired Baud rate and sets up SSPADD
    ; *** Begin I2C Data Transfer Sequences ***
    I2CWrite
    ; Send START condition and wait for it to complete
    BANKSEL SSPCON2 		; BANK 1
    bsf SSPCON2,SEN 		; Generate START Condition
    call WaitMSSP 			; Wait for I2C operation to complete
    ; Send and Check CONTROL BYTE, wait for it to complete
    movlw LC01CTRLIN 		; Load CONTROL BYTE (input mode)
    call Send_I2C_Byte 		; Send Byte
    BANKSEL SSPCON2
    btfsc SSPCON2,ACKSTAT 		; Check ACK Status bit to see if I2C
    goto I2CFail 			; failed, skipped if successful
    ; Send and Check ADDRESS BYTE, wait for it to complete
    movlw LC01ADDR 		; Load Address Byte
    BANKSEL SSPCON2
    ; Send and Check DATA BYTE, wait for it to complete
    movlw LC01DATA 			; Load Data Byte
    BANKSEL SSPCON2
    ; Send and Check the STOP condition, wait for it to complete
    BANKSEL SSPCON2
    bsf SSPCON2,PEN 		; Send STOP condition
    ; The WRITE has now completed successfully. Begin the Read Sequence
    I2C READ
    ; Send RESTART condition and wait for it to complete
    BANKSEL SSPCON2
    bsf SSPCON2,RSEN 	; Generate RESTART Condition
    movlw LC01CTRLIN 		; Load CONTROL BYTE (input)
    ; Now check to see if I2C EEPROM is ready
    BANKSEL SSPCON2
    goto I2CRead 		; ACK Poll waiting for EEPROM write to complete
    movlw LC01ADDR 			; Load ADDRESS BYTE
    BANKSEL SSPCON2
    ; Send REPEATED START condition and wait for it to complete
    bsf SSPCON2,RSEN 		; Generate REPEATED START Condition
    ; Send and Check CONTROL BYTE (out), wait for it to complete
    movlw LC01CTRLOUT 		; Load CONTROL BYTE (output)
    BANKSEL SSPCON2
    ssful
    ; Switch MSSP module to I2C Receive mode
    bsf SSPCON2,RCEN 		; Enable Receive Mode (I2C)
    ; Get the DATA BYTE and wait for it to complete. Data is in SSPBUF when done.
    ; The receive mode is disabled at end automatically by the MSSP module.
    ; Send NACK bit for Acknowledge Sequence
    BANKSEL SSPCON2
    bsf SSPCON2,ACKDT 		; ACK DATA to send is 1, which is NACK.
    bsf SSPCON2,ACKEN 		; Send ACK DATA now.
    ; Once ACK or NACK is sent, the ACKEN is automatically cleared by the MSSP
    ; Send and Check the STOP condition and wait for it to complete.
    ; I2C Write and Read have both finished, the value is output on LEDs.
    BANKSEL SSPBUF 			; BANK 0
    movf SSPBUF,W 			; Get data from SSPBUF into W register
    movwf PORTB 			; Output W register to LEDs on PORTB
    ; Program has finished and completed successfully.
    goto $ 				; Wait forever at this location!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!CHANGE THIS
    ; *** SUBROUTINES & ERROR HANDLERS ***
    ; I2C Operation Failed code sequence - This will normally not happen,
    ; but if it does, a STOP is sent and the entire code is tried again.
    I2CFail
    BANKSEL SSPCON2
    BANKSEL PORTB 			; BANK 0
    movlw 0xFF 			; Turn on all LEDs on PORTB
    movwf PORTB 			; to show error condition
    goto $ 				; Wait forever at this location!!!!!!!!!!!!!!!!!!!!!!!!!!!!!CHANGE THIS
    ; This routine sends the W register to SSPBUF, thus transmitting a byte.
    ; Then, the SSPIF flag is checked to ensure the byte has been sent successfully.
    ; When that has completed, the routine exits, and executes normal code.
    Send_I2C_Byte
    movwf SSPBUF 			; Get value to send from W, put in SSPBUF
    retlw 0 			; Done, Return 0
    ; This routine waits for the last I2C operation to complete.
    ; It does this by polling the SSPIF flag in PIR1.
    ;!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!BUT HOW TO DO THIS CODE IN THE BACKGROUND???
    WaitMSSP
    BANKSEL PIR1 			; BANK 0
    btfss PIR1,SSPIF 		; Check if done with I2C operation
    goto $-1 			; I2C module is not ready yet
    bcf PIR1,SSPIF			; I2C module is ready, clear flag.
    Retlw 0 			; Done, Return 0
    What you see is Microchip Assembler.
    Talking
    thanks Mel!
  1. I2C Slave with a PIC
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 21st August 2016, 17:44
  2. Making Program Code Space your playground...
    Last Post: - 19th July 2008, 08:26
  3. PIC16F877 I2C programme
    By cooqo in forum mel PIC BASIC
    Last Post: - 21st April 2008, 10:02
  4. Hardware I2C
    By Kamikaze47 in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 13:24
  5. Sample code for ML2036 DDS
    By Tim in forum mel PIC BASIC Pro
    Last Post: - 7th February 2004, 02:08
