Can't ID interrupt source with this IntHandler??
Results 1 to 8 of 8
    Mar 2009
    Colorado
    Unhappy Can't ID interrupt source with this IntHandler??
    I have attached my code below. My application requires sensing an external interrupt from a contact limit switch closure which I am sensing as an On-change interrupt at the RA3 pin of my 16F690. I am also counting pulses from an external interface to a Hall-effect sensor using a TMR0 interrupt when it overflows. I think I have all the register setting correct, but in my attempts during testing to isolate which interrupt occured, I have to If-Then blocks in the code to test the interrupt flags to determine which one occured. I know that neither of these IF-THEN blocks are being triggered in this current code, because of the specific placement of different write statements in the code. The only Write statement that is actually being triggered is the Write 7, low_bat statement right before the first IF-THEN block...none of the others are writing anything which confirms the IF-THEN blocks are not being triggered. Yet when I activate the RA3 switch closure the code is actually triggering the Interrupt Handler.
    Can anyone tell me why my code is not triggering the first IF-THEN block to detect the RA3 On-change interrupt?
    ' This Program uses the PIC16F690 and simulates control of a solenoid operated
    ' water valve and measures the volume of water flowing through a flow meter.
    ' This program places the MCU in sleep mode most of the time until it receives
    ' an interrupt from the activation of the flush handle that closes a
    ' contact limit switch that grounds an input pin of the microcontroller as an
    ' interrupt.  I/O pin connections to the PIC16F690 MCU are as follows:
    ' RA0...is connected as ICSPDAT when used for ICSP and also to a low battery
    '       monitor R/C circuit.
    ' RA1...is connected as ICSPCLK when used for ICSP.
    ' RA2...is connected to the external Flush contact limit switch as TMR0 input.
    '       During testing it is connected to a momentary switch on the PICkit2
    '       board as a clock input for TMR0 counting of pulses as interrupt.
    ' RA3...During testing it is connected to a momentary switch on the PICkit2
    '       board as a manually simulated On_interrupt from the FLUSH switch.
    ' RA4...is connected to pin 6 of the ICSP header for use during programming.
    ' RC0...is connected as an output to an LED and is on when the valve
    '       is open.
    ' RC1...is connected as an output to an LED and is flashed when battery is low
    ' RC3...is connected as an output to the latching solenoid that opens or
    '       closes the valve.  During program testing with the PICkit2 demo
    '       board it is connected to an LED to show when the pulse is sent.
    ' RC4...is connected to pin PDN on the TRM-XXX-LT transceiver.
    ' RC5...is connected to pin DATA on the TRM-XXX-LT transceiver.
    ' RC6...is connected to pin RSSI on the TRM-XXX-LT transceiver.
    ' RB4...is connected via a 10 ohm resistor to provide power to Wireless option.
    ' RB5...is connected to Hall Effect sensor circuit #2.
    ' RB6...is connected to Hall Effect sensor circuit #1.
    ' RB7...is connected to pin R/T SEL on the TRM-XXX-LT transceiver.
    '       the PICkit2 board momentary switch to simulate Meter pulse inputs.
    ' -----[ Device Declaration ]----------------------------------------------
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    '@device pic16F690, intrc_osc_noclkout, BOD_OFF, PWRT_OFF, wdt_off,mclr_off,
    ' protect_off   ' For PM assembler only
    ' -----[ Revision History ]------------------------------------------------
    ' -----[ Variables & Aliases Intitialization ]-----------------------------
    led1  VAR PORTC.0   ' Set RC0 as LED indicator of valve open..water flowing
    led2  VAR PORTC.1   ' Set RC1 as LED indicator of low battery
    valve VAR PORTC.3   ' Set RC3 as valve solenoid open/close command
    low_bat VAR PortA.0 ' Set RA0 as battery low power monitor
    meter VAR PORTA.2   ' Set RA2 as input for Hall Sensor meter pulse Interrupt
    flush VAR PORTA.3   ' Set RA3 as input for sensing flush switch closure Int
    bat_mon VAR Byte    ' bat_mon value when Vtrh multiplied by low_bat
    dummy VAR Byte      ' For read of on-interrupt port & clear mismatch condition
    ' -----[ Constants Initialization ]----------------------------------------
     k             CON 10   ' Calibration factor for flow meter...# pulses per gal
     i             VAR Byte ' Index used in Gallon counter loop
     Vthr          CON 4    ' Low Battery Monitor threshold
    ' -----[ Initialization ]--------------------------------------------------
    'EEPROM PRESETS
    'DATA @0,0
    'OSC DEFINE
    'DEFINE OSC 4
    ' Setup Timer0 as an 8-bit counter with the clock input on RA2.
    ' 1:1 TMR0 prescaler
    ' TMR0 counts on high-to-low transitions
      OPTION_REG = %0111000    ' PORTA pullups disabled, TMR0 clock source is RA2,
                               ' high-to-low transitions, prescaler to TMR0
    'Register Settings
    Init:
    PORTC = 0           ' LEDs off, PULSOUT RC3 provides a high-going pulse
    PORTA = 0
    TRISA = %11111111   ' Set all PORTA pins to inputs...RA0, RA2 & RA3 are used
    TRISB = %00000000   ' Set all PORTB and PORTC pins to outputs
    TRISC = %00000000
    PORTC = %00000000	' Pre-set PORTC pins low, turning LEDs off
    TMR0 = 256-K        ' Preload TMR0 to overflow after k counts
    'A/D & Comparators disabled
      ADCON0 = %01110000  ' Set PORTA to digital I/O & FRC (clock derived from a
      ADCON1 = %00000000  ' dedicated internal oscillator)
      ANSEL=0             ' Set PortA to digital I/O
      ANSELH=0            ' Analog module disabled
      CM1CON0=0
      CM2CON0=0
    ' Initialization of inputs/outputs
      TRISC.3 = 0       ' Set RC3 as output port for valve latching solenoid control
      Low Valve         ' Initialize RC3 (valve) at Low value
      TRISA.2 = 1       ' Set RA2 as input port for clock to TMR0
      TRISA.3 = 1       ' Set RA3 as input port for sensing METER switch closure
      High meter        ' Initialize RA2 (meter) at High value for METER pulse inputs
                        ' RA2 = TMR0 clock input for simulated meter pulse inputs
      High flush        ' Initialize RA3 (flush) at High value for flush interrupt
    'Interrupts Settings
    FLUSH_INT_FLAG VAR INTCON.0  ' RA3 (FLUSH) On-change-interrupt flag bit
    TMR0_INT_FLAG VAR INTCON.2   ' Timer0 overflow flag bit
    INTCON = %10101000           ' Enable global, TMR0 & RABIE (RA3 on-change-INT)
    IOCA = %00001000             ' Enable RA3 as on-change-INT
    ' -----[ Main Code ]-------------------------------------------------------
    'Set INT Handler
    ON INTERRUPT GOTO Int_handler
    'Start...normal code here
    MAIN:
        PORTC = %00000000   ' Turn all LEDs off
        SLEEP 30     ' Put MC in Sleep state at power up for 30 secs
        ' Microcontroller is in Sleep State waiting for external FLUSH Interrupt
            ' Valve should be closed at this point and no water flowing
        ' Put code here to test if flow meter has stopped as an indication that
        ' no water is flowing...is a double check on valve closure.
      GOTO Main        ' Loop to Main to wait for next Flush interrupt on RA3 change
      DISABLE
    Int_handler:
      PULSOUT valve,1000  ' Generate required 10 msec pulse to RC3 to open valve
      High led1           ' Light indicator that valve is open & water flowing
      Low low_bat         ' Simulate battery monitor input is low
      DEFINE WRITE_INT 1
      Write 7, low_bat    ' Remove comment for test only
      IF FLUSH_INT_FLAG = 1 Then  ' Interrupt was from RA3 on change
        write  9, flush     ' Write RA3 (FLUSH) value during testing
        ' Put code here to start a timer to run for 50 secs as a fail safe
        ' to prevent overflow of toilet tank in case of sensor failure.
            'Goto Shutvalve
        dummy = flush          ' Clear mismatch condition
        FLUSH_INT_FLAG = 0     ' Clear interrupt flag & enable
        'INTCON = %10100000     ' global & TMR0 interrupts..preclude RA3 interrupt
      Endif
      IF TMR0_INT_FLAG = 1 Then  ' Interrupt was a TMR0 overflow..volume reached
        PULSOUT valve,2000  ' Generate required 20 msec pulse to RC3..close valve
        WRITE 5, TMR0      ' Write TMR0 value..remove comment for test only
        bat_mon = low_bat * Vthr
        Write 13, bat_mon    ' Remove comment for test only
        If bat_mon < Vthr Then
            'Light the low battery monitor light
            HIGH led2
        dummy = TMR0              ' Clear mismatch condition
        TMR0 = 256-k              ' Reload TMR0 to overflow after k counts
        TMR0_INT_FLAG = 0         ' Clear overflow flag and enable
        'INTCON = %10001000       ' global & RABIE (RA3 on-change-INT)
                                  ' ..preclude TMRO overflow interrupt
      LOW led1
      Low led2
      RESUME
      ENABLE
        ' If the user program ends by getting to the last statement of the program
        ' at an END instruction, the MCU will SLEEP and await a wakeup.
    on interrupt goto . . . the devil !
    On interrupt is a junk imitation of a real interrupt. It places a flag on the stack when the port change interrupt occurs and continues doing what it was doing . . .until it finishes what it is doing. You have set WDT to off and what is to awaken the PIC from sleep ? I would set WDT to ON and probably set up and use Darrel's instant interrupts. Then you have assembly interrupts at PBP control. On interrupt works like a gosub.
    Mar 2009
    Colorado
    Red face Got it working except for SLEEP mode
    Thanks, Joe. Am going to study the instant interrupts to see how to use them.
    I did finally get the OnInterrupt version working so that the Int_handler would determine which type of interrupt occurred and service them accordingly. Only thing I haven't yet got working is the SLEEP mode, even after turning WDT on as you pointed out. Intention is to put the MCU into SLEEP mode for 45 secs on power up while waiting for the first interrupt from the Flush switch. However, when I do this, the Flush switch interrupt works, but the RA3 OnChange interrupt doesn't work. Can't figure out why. If I use a PAUSE 1 statement instead of SLEEP 45 everything works correctly. Any ideas on how to solve this?
    I am posting all of my current code below in case anyone wants to see how the overall interrupt structure does work for use with both types of interrupts.
    ' -----[ Program Description ]---------------------------------------------*
    '  This Program is for a PIC16F690 installed in a PICkit2 Starter Kit      *
    '  Purpose:        *
    '       1)  Monitor an input for an external Interrupt from flush          *
    '		2)  On Interrupt, command latching solenoid to open valve          *
    '		3)  Measure flow meter output to determine when 1.6                *
    '           gallons have passed                                            *
    '		4)  On 1.6 gallons, command latching solenoid to close             *
    '	    5)  Put Microcontroller back in Sleep State to await next          *
    '           Flush Interrupt	                                               *
    ' A normally open, momentary push button switch is installed on the PICkit2
    ' LPDM board between pin RA2 and ground to simulate the flow meter pulse input.
    '       monitor R/C circuit for normal ops.
    '       is open.
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
    '@device pic16F690, intrc_osc_noclkout, bod_off, pwrt_off, wdt_off, mclr_off,
    ' -----[ Declare Variables & Aliases ]-----------------------------
    diff    VAR Byte      ' Difference between bat_mon and Vthr
    bat_mon VAR PortA.0   ' Set RA0 as battery low power monitor
    ' -----[ Declare Constants ]----------------------------------------
     Vthr          CON 3    ' Aasumes Low Battery Monitor threshold = 3 volts
      OPTION_REG = %00111000   ' PORTA pullups disabled, TMR0 clock source is RA2,
      TMR0 = 256 - k           ' preload TMR0 to overflow after k counts
      CM1CON0=0
      CM2CON0=0
    'Port Settings
    Init:
    PORTA = 0           ' PortA pins all set to Low
    TRISB = %00000000   ' Set all PORTB pins to outputs
    TRISC = %11110000   ' Set lower 4 pins of PartB as outputs
      Valve = 0         ' Initialize RC3 (valve) at Low value
      TRISA.3 = 1       ' Set RA3 as input port for sensing Flush switch closure
      meter = 1         ' Initialize RA2 (meter) at High for METER pulse inputs
      flush = 1         ' Initialize RA3 (flush) at High value for flush interrupt
    'INTCON = %10100000           ' enable global & Timer0 interrupt only
    'Set INT Handler
    MAIN:
        Pause 1    ' Works when SLEEP statement doesn't work!!
        'SLEEP 45  ' Put MC in Sleep state at power up for 45 secs..doesn't work!!
        Low led2
      DISABLE
    Int_handler:
      High bat_mon           ' Simulate battery monitor input is Low
      DEFINE WRITE_INT 1
      'Write 5, bat_mon      ' Remove comment for test only
        HIGH led1           ' Light indicator that valve is open & water flowing
        'Write  7, flush     ' Write RA3 (FLUSH) value during testing
            'Goto Shutvalve
        REPEAT
            ' Wait until the external Flush interrupt is at high level...limits
            ' interrupt to switch closure only and not for switch open
        Until flush = 1
                                  ' ..preclude TMRO overflow interrupt..test only
      Endif
        'WRITE 11, TMR0      ' Write TMR0 value..remove comment for test only
        'Write 13, bat_mon   ' Remove comment for test only
        'Write 15, Vthr
        diff = Vthr - bat_mon
        'Write 17, diff
        If diff > 2 Then    'Battery is low
            HIGH led2
        TMR0_INT_FLAG = 0 ' clear overflow flag
        TMR0 = 256 - k    ' reload TMR0 to overflow after k counts
        LOW led1      'Turn off LED indicators
        'INTCON = %10100000   ' global & TMR0 interrupts..preclude RA3 interrupt..
                              ' test only
      RESUME
      ENABLE
    I have never ever had reason to use sleep directive, I know it is supposed to wake on interrupt. Pause 1 is 1 millisecond not 45 seconds as you comment indicates the sleep directive is asking for, are you sure or your intcon and option_reg settings? They affect interrupts. I am not in the shop right now, and do not have books handy, will look further later.
    I saw nothing in the PBP Book , check your Data sheet and see what kind of OSC the WDT uses and make sure it is turned on. See sect. 14.6 of the datasheet, it is a pretty good treatise on sleep.
    Not sure how PBP deal with SLEEP 45, but from memory, the WDT "should" use TMR0 as clock source, and if you don't assign it to, then it may indeed give you some problems... but you're currently using TMR0 for something else, so probably part of the problem.
    I would probably opt for a real WDT timeout interrupt with @ SLEEP, or see if there's any other Timer who can wake-up the PIC, leaving TMR0 free to count your pulses.
    Check your datasheet to see how each Wake-up source behave.
    Mar 2009
    Colorado
    Thumbs up Sleep problem solved!
    Thanks Mister e! I uses @ SLEEP and @ NOP statements instead of the SLEEP 45 statement and it all works. Didn't need to put it in SLEEP for only 45 seconds since prolonged @ SLEEP mode is still awakened by either of my interrupts implemented in this code.
    The contributions on this thread have been outstanding in helping me understand my problems and achieve solution. Thanks again to all of you who posted answers to my questions. I consider this to be the end of this thread.
    Quote Originally Posted by jellis00 View Post
    You know, I was thinking about the @ sign but didn't have time to research it this morning, and didn't have the stones to go out on the limb . . .
    Hurray for mister_e !
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 18:14
  3. Replies: 0
    Last Post: - 15th December 2006, 19:16
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 02:59
  5. USART interrupt not interrupting right
    By Morpheus in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 01:07
