8x8 Scrolling LED display (Simple example) - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 69 of 69
  1. #41
    Mar 2009
    Default Re: 8x8 Scrolling LED display (Simple example)
    yes that is a great idea, going to google for samples of 4049!thx
  2. #42
    Mar 2009
    here is the final result, the message is Baby on Board on my native language (bosnian)
    the code is made in ProtonIde compiler and is similar to PBP hope someone will use it
    ' SIMPLE 15X8 LED MATRIX SCROLLING EXAMPLE
    ' 16F877A External 8MHz Xtal Osc
    ' LED Matrix columns are conected to PORTC pin rc0 via ULN2004AN and CD4017.
    ' RC1 reset for 4017
    ' LED Matrix rows conected to PORTB via 100 ohm resistors
    ' RB0 - top row
    ' Author: Muamer Halilovic
    ' www.mtskola.com
    ' today
    Device 16F877A
    Xtal 12
    TRISB = %00000000
    TRISC = %10000000
    TRISD = %00000000
    PORTB=0
    PORTC=0
    PORTD=0
    All_Digital = True
    	EWrite 0,[%00000100,%00000110,%01111111,%00000110,%00000100]	'Up Arrow
    	EWrite 5,[%00010000,%00110000,%01111111,%00110000,%00010000]	'Dn Arrow
    	EWrite 10,[%01111110,%00010001,%00010001,%00010001,%01111110]	'A
    	EWrite 15,[%01111111,%01001001,%01001001,%01001001,%00110110]	'B
    	EWrite 20,[%00111110,%01000001,%01000001,%01000001,%00100010]	'C
    	EWrite 25,[%01111111,%01000001,%01000001,%00100010,%00011100]	'D
    	EWrite 30,[%01111111,%01001001,%01001001,%01001001,%01000001]	'E
    	EWrite 35,[%01111111,%00001001,%00001001,%00001001,%00000001]	'F
    	EWrite 40,[%00111110,%01000001,%01001001,%01001001,%01111010]	'G
    	EWrite 45,[%01111111,%00001000,%00001000,%00001000,%01111111]	'H
    	EWrite 50,[%00000000,%01000001,%01111111,%01000001,%00000000]	'I
    	EWrite 55,[%00100000,%01000000,%01000001,%00111111,%00000001]	'J
    	EWrite 60,[%01111111,%00001000,%00010100,%00100010,%01000001]	'K
    	EWrite 65,[%01111111,%01000000,%01000000,%01000000,%01000000]	'L
    	EWrite 70,[%01111111,%00000010,%00000110,%00000010,%01111111]	'M
    	EWrite 75,[%01111111,%00000100,%00001000,%00010000,%01111111]	'N
    	EWrite 80,[%00111110,%01000001,%01000001,%01000001,%00111110]	'O
    	EWrite 85,[%01111111,%00001001,%00001001,%00001001,%00000110]	'P
    	EWrite 90,[%01111111,%00001001,%00011001,%00101001,%01000110]	'R
    	EWrite 95,[%01000110,%01001001,%01001001,%01001001,%00110001]	'S
    	EWrite 100,[%00000001,%00000001,%01111111,%00000001,%00000001]	'T
    	EWrite 105,[%00111111,%01000000,%01000000,%01000000,%00111111]	'U
    	EWrite 110,[%00011111,%00100000,%01000000,%00100000,%00011111]	'V
    	EWrite 115,[$00,$00,$00,$00,$00]	'blank space
    	EWrite 185,[$00,$00,$00,$00,$00]
    	EWrite 190,[$00,$00,$00,$00,$00]
    	EWrite 195,[$00,$00,$00,$00,$00]
    	EWrite 200,[$00,$00,$00,$00,$00]
    	EWrite 205,[$00,$00,$00,$00,$00]
    	EWrite 210,[$00,$00,$00,$00,$00]
    	EWrite 215,[$00,$00,$00,$00,$00]
    	EWrite 220,[$00,$00,$00,$00,$00]
    	EWrite 225,[$00,$00,$00,$00,$00]
    	EWrite 230,[$00,$00,$00,$00,$00]
    	EWrite 235,[$00,$00,$00,$00,$00]
    	EWrite 240,[$00,$00,$00,$00,$00]
    	EWrite 245,[$00,$00,$00,$00,$00]
        '________________________________________________________________
        'Deklaracija promjenjivih
       	Dim kolona As Byte
    	Dim brojac As Byte
    	Dim k As Byte
    	Dim scan  As Byte
    	Dim scroll As Byte
    	leddata var Byte[100]
        Dim ir_ulaz As Word ' WORD variabla za zaprimanje podataka
        Dim EEpromAdress As Byte 'eprom adresa za upis
        Dim test As Word 'uporedjivach
        Dim upisi As ir_ulaz.LowByte
        Dim i As Byte
        Dim sledeceslovo As Word
        Dim prethodnoslovo As Word
        Dim potvrdi As Word
        Dim play As Word
        Dim x As Byte
        Dim j As Byte
        Dim cnt As Byte
        Dim a As Byte
        Dim b As Byte
        Dim c As Byte
        Dim d As Byte
        'poetene vrijednosti
        EEpromAdress = 255
        cnt=0
        k=114
        'Inicijalizacija
        High PORTD.0
        DelayMS 1300
        Low PORTD.0
        DelayMS 1300
        'pregledaj eeprom ako ima sta idi na main ako ne idi na pripremu
        Declare RC5In_Pin PORTC.7                    'infrared sensor pin
    provjera:
            test.LowByte = ERead 255 'iscitaj zapis iz eeproma sa adrese 255
                    If test.LowByte = $FF Then 'ako je FF
                        GoSub eepromprogON 'idi u programiraj komande
                        DelayMS 500
                    EndIf
            test.LowByte = ERead 120 ' iscitaj zapis iz eeproma sa adrese 120 (pocetak poruke)
                    If test.LowByte = $FF Then ' ako je 00
                        GoSub odaberporuku     ' idi na odaberi poruku
                        DelayMS 500
                    EndIf
    Clear ' ocisti sve varijable
    Low PORTD.0  ' usli smo u mod za prikaz poruke
    a=14
    k=120
    j=0
    leddata[0-13] = $00             ' varijabla ledadta od 0 do 13 je 00
    For b = 0 To 11                 ' moguci broj slova u poruci
        For i = 0 To 4
            c=i+a                   'povecaj a=14-19; a=20-24; a=26-30 itd...
            d=i+j+k                   'povecaj j=120-124; a=126-130; a=131-135 itd...
                leddata [c]= ERead d	'filuj ledadtu od 14 do max broja slova za prikaz iz eeproma pocevsi od 120 pa nadalje
                DelayUS 20
        Next
        leddata [a+5]=ERead 119   'upisi prazanu kolonu izmedju slova
          a=a+6
          j=j+6
     Next
           For scroll = 0 To c      ' skrolaj poruku c zadnji leddata
             For scan = 0 To 35
                      PORTC.1 = 1   'reseting 4017
                      PORTC.1 =0
    			For kolona = 0 To 14  'broj kolona
    				PORTC.0 = 1       'clock 4017
                    PORTC.0 =0
                    PORTB = leddata[kolona]
    				DelayUS 250
                    PORTB=0
    		    Next
             Next
             For brojac = 0 To (c-1)
            leddata[brojac]=leddata[brojac+1]' pomjeri za jedan
            Next
            Next
                    If PORTD.1=1 Then
                    GoSub odaberporuku
        	 	End If
    GoTo main
    eepromprogON: 'podprogram za odabir komadi za upravljanje
        High PORTD.0
                Repeat
                    ir_ulaz.LowByte= RC5In '  Primanje signala sa TSOP1738
                Until upisi<> 255' Trazi-cekaj dok ne naleti valjano zaglavlje signala
          EWrite EEpromAdress , [ ir_ulaz.LowByte ]
          sledeceslovo.LowByte = ERead EEpromAdress ' pridruzi varijabli sledece slovo komandu i upisi u eprom na zadnju lokaciju
          For i = 0 To 4
    	 leddata [i]=ERead i	'  prikazi strelicu
    	Next
             For scan = 0 To 185
             PORTC.1 =0
    			For kolona = 0 To 4
                    PORTC.0 =0
    				DelayUS 500
                    PORTB=0
    		    Next
             Next
    Low PORTD.0
    DelayMS 100
    High PORTD.0
    DelayMS 100
    Low PORTD.0
    DelayMS 100
    High PORTD.0
                Repeat
                EEpromAdress=EEpromAdress - 1
          prethodnoslovo.LowByte = ERead EEpromAdress ' pridruzi varijabli sledece slovo komandu i upisi u eprom na zadnju lokaciju
          For i = 0 To 4
    	 leddata [i]=ERead i+5	'  prikazi strelicu
    	Next
             For scan = 0 To 185
             PORTC.1 =0
    			For kolona = 0 To 4
                    PORTC.0 =0
    				DelayUS 500
                    PORTB=0
    		    Next
             Next
    Low PORTD.0
    DelayMS 100
    High PORTD.0
    DelayMS 100
    Low PORTD.0
    DelayMS 100
    High PORTD.0
                Repeat
          play.LowByte = ERead EEpromAdress  ' pridruzi varijabli play komandu i upisi u eprom na predzadnju lokaciju
          leddata[0]=$FE  'play simbol
    	leddata[1]=$7C
    	leddata[2]=$38
    	leddata[3]=$10
    	leddata[4]=$00
         For scan = 0 To 185
             PORTC.1 =0
    			For kolona = 0 To 4
                    PORTC.0 =0
    				DelayUS 500
                    PORTB=0
    		    Next
             Next
    Low PORTD.0
    DelayMS 100
    High PORTD.0
    DelayMS 100
    Low PORTD.0
    DelayMS 100
    High PORTD.0
     Repeat
                       EEpromAdress=EEpromAdress -1
                       EWrite EEpromAdress , [ ir_ulaz.LowByte ] ' pridruzi varijabli potvrfi komandu i upisi u eprom na predpredzadnju  :D lokaciju
          potvrdi.LowByte = ERead EEpromAdress
          leddata[0]=$00
    	leddata[1]=$00
    	leddata[2]=$08
    	leddata[3]=$10
    	leddata[4]=$20
    	leddata[5]=$10
    	leddata[6]=$08
    	leddata[7]=$04
    	leddata[8]=$02
    	leddata[9]=$01
         For scan = 0 To 185
             PORTC.1 =0
    			For kolona = 0 To 9
                    PORTC.0 =0
    				DelayUS 500
                    PORTB=0
    		    Next
             Next
          For x=0 To 5
            Toggle PORTD.0
            DelayMS 100
          x=x+1
          Next
          x=0
          EEpromAdress=0
    Return 'vrati se u if petlju na pocetku
    odaberporuku:	' podrpogram za odabir poruke za prikaz
    High PORTD.0
    sledeceslovo.LowByte = ERead 255
    prethodnoslovo.LowByte = ERead 254
    play.LowByte = ERead 253
    potvrdi.LowByte = ERead 252
    cnt=0
    k=114
    Low PORTD.1
    Repeat
    While ir_ulaz.LowByte<>play.LowByte
        Repeat
    If ir_ulaz.LowByte=prethodnoslovo.LowByte Then
              If cnt = 0 Then
                cnt=5
             EndIf
       cnt=cnt-5
        For i = 0 To 4
    	 leddata [i]=ERead i+cnt	'
    	Next
             For scan = 0 To 185
             PORTC.1 =0
    			For kolona = 0 To 4
                    PORTC.0 =0
    				DelayUS 500
                    PORTB=0
    		    Next
             Next
    ElseIf ir_ulaz.LowByte=sledeceslovo.LowByte Then
       cnt=cnt+5
        For i = 0 To 4
    	Next
             For scan = 0 To 185
             PORTC.1 =0
    			For kolona = 0 To 4
                    PORTC.0 =0
    				DelayUS 500
                    PORTB=0
    		    Next
             Next
                       If cnt = 119 Then
                cnt=0
             EndIf
    ElseIf ir_ulaz.LowByte=potvrdi.LowByte Then 'upisi odabran0o slovo u narednu slobodnu eeprom lokaciju
     k=k+6'krecemo od 120
     For i = 0 To 4
         DelayUS 10	'
    	Next
     For i = 0 To 4
    	 EWrite (i+k),[leddata [i]]	'
         DelayMS 20
     Next
    For scroll =0 To 1
     For i = 0 To 4
    	 leddata [i]=ERead i+cnt	'prikazi odabrano slovo
    	Next
    	leddata[5]=$00
    	leddata[6]=$00
    	leddata[7]=$08
    	leddata[8]=$10
    	leddata[9]=$20
    	leddata[10]=$10
    	leddata[11]=$08
    	leddata[12]=$04
    	leddata[13]=$02
    	leddata[14]=$01
             For scan = 0 To 185
             PORTC.1 =0
                    PORTC.0 =0
    				DelayUS 500
                    PORTB=0
    		    Next
             Next
    Next
    EndIf
    Wend
    Low PORTD.0
    Return ' vrati se odakle si i dosao
  3. #43
    May 2009
    Hi to all,
    A newbie here. I try to compile the file from first post but I receive a constant error
    ERROR Line 51: LOOP without a matching DO.
    How can I avoid that?
    Many thanks in advance
    Gabi
    P.S.
    I know it is a old thread but maybe someone or OP will chime in and help me with that error
  4. #44
    I suppose you are using PBP 2.60, right?
    LOOP is a reserved word for 2.60. So use Loop1 or something.
    May 2009
    Hi Ioannis,
    Yes, sorry I forgot to tell that. Yessss it is working, meaning compile without errors. Now my problem it is in Proteus - Simulation it is not running on real time due the excessive CPU load?? Why?
    Do I need to put some delays in the code?
    Thank you in advance
    Gabi
  6. #46
    Sorry, I do not use Proteus.
    I prefer the real stuff
    May 2009
    Still, Ioannis can you have a look on that code and give me your expert opinion
    Rgds
    Gabi
  8. #48
    The code is simple and should run with no problems.
    If you insist on simulation, I do not know much. I hear that Proteus is the Best, but still have a few flaws.
    Did you try the code on real circuit?
    May 2009
    Hi Ioannis,
    No, I do not have all the parts to try it. That was the reason for using Proteus. I saw a post from you regarding ULN 2083. If I decided to use that instead ULN 2004 what else should I need to modify (software and hardware)?
    Gabi
  10. #50
    Feb 2007
    Quote Originally Posted by gabi68 View Post
    Gabi
    ULN2803 is an 8 channel transistor array (18pin package), and the ULN2004 is a 7 channel transistor array (16pin package)
    The software remains the same, with the hardware you can lower the component count, by replacing 2 ULN2004 with 1 ULN2803
  11. #51
    May 2009
    After 1 month I finally make that running - simulating properly in Proteus. My problem was that ULN2803. I didn't know that chip invert signal's. After I put some hex inverters 7404 everything running properly.
    My question is:
    in real life (I will build the real circuit) I need that inverters or everything will run normal without that?
    Many thanks
    Gabi
  12. #52
    Instead of inverters, why don't you invert he data that you output from the PIC?
    Instead of inverters, why don't you invert the data that you output from the PIC?
    May 2009
    Hi Ioannis,
    I try to do that but, I failed. Can you show my how? On the other hand the question it is still: do I need that inverters in a real circuit?
    Thank you for your time
    Gabi
  15. #55
    If your load needs an 1 and you send a 0 then it is obvious that you need an inverter.
    But as I said, instead of 1, send 0 in software.
    For example,
    var_a=%10101010
    var_1=var_a XOR %11111111
    The result in var_a will be the complement of the initial value.
    Feb 2007
    Hi all,
    This update now scrolls temperature in degrees C & F,
    with indication arrow to show increase or decrease in temperature
    and scrolls 'wellyb00t' at every few minutes.
    Works with PBP 2.60C & MPLABS v8.63
  17. #57
    Feb 2007
    See above post, this is the HEX file for it.
    couldnt add a file with .hex extention so changed it to .txt
    just remove .txt extention
    normey's Avatar
    normey Guest
    Smile Re: 8x8 Scrolling LED display (Simple example)
    hello all..
    i need your help. i want to build program even one word to display on dot matrix (7x5) with pic16f877a. i use c language. but when i compile it don't have any error. but it can't work on dot matrix after i load that program. anyone can help me.. i'm on stuck. hope you all can help me. here my program. i want use port a n port b.
    #include <16f877a.h>
    #use delay(clock=20000000)
    #fuses hs,nowdt,nocpd,nolvp,noprotect
    #byte porta=0x06
    #byte portb=0x08
    #bit clock=portd.6
    #bit data=portd.7
    unsigned int8 i,j,index1,n,
    addr[11]={0xEA,0xEA,0x2A,0x2A,0x2A,0x2A,0xAA,0x82,0xFF,0xF F,0xFF},
    cont[11];
    void main()
    set_tris_a(0x00);
    set_tris_b(0x00);
    while(1)
    for(n=0;n<=99;n++)
    data=1;
    for(i=0;i<=5;i++)
    clock=1;
    portb=addr[i];
    delay_ms(1);
    clock=0;
    data=0;
    for(j=0;j<=7;j++)
    cont[j]=addr[j];
    for(j=0;j<=7;j++)
    addr[j]=cont[j+1];
    addr[10]=cont[0];
    besides that i'm a new in programming. hope n hope anyone can help me.. thank you.
  19. #59
    prasanna's Avatar
    prasanna Guest
    Hi, Please let me know how to program this IC PIC16F872 as I am new to this area.
    My email: [email protected]
    Appreciate your help
  20. #60
    Apr 2010
    Quote Originally Posted by prasanna View Post
    u got lot to learn dear.u need a programmer n programming software to do this..
    [r u from srilanka o uk?]
  21. #61
    priya5's Avatar
    priya5 Guest
    Post Re: 8x8 Scrolling LED display (Simple example) sir please send me code usins ATMEGA16
    sir plz send me the code and ckt diagram of LED moving display using ATmega 16
  22. #62
    Default Re: 8x8 Scrolling LED display (Simple example) sir please send me code usins ATMEGA16
    This is a PIC controller forum. Not AVR.
    Hi please any one would you able to help me to build the LED Matrix project? i have already designed it for 10x7 matrix. it's working nicely. but if i extend this to 20x7 then it s running and blinking fastly. i think the delay wil b a problem. now i want some guidelines from u. please it's urgent. help me.[email protected]. mail me the code in c
  24. #64
    Sure, which compiler do you want me to make it?
    Please, check the forum and what we do here. No C and sure no serving to the plate.
  25. #65
    Thank you very much for ur quick reply,
    Now i'm using MBlap HItech Compiler and Micro c for pic.
    Please guide me. i already done this without shift register but when i try using shift register it's flickering please help me. it's urgent
  26. #66
    Kalaiyarasi's Avatar
    Kalaiyarasi Guest
    Default 8 x 8 led
    hai, i am doing project on PIC16F877A.I am executing the code in MPLAB.Can anyone help me to display the characters from A to Z in 8 X 8 LED using MPLAB code....
  27. #67
    Dec 2008
    Ploiesti, ROMANIA
  28. #68
    Jul 2013
    hello mr.fratello... can you help me? im very need your help.. i want to do font moving display... but the coding is complicated to me... can u teach me about the coding for font moving display...
  29. #69
    Jul 2013
    im use pic 16f877a... please help me... anybody also can help me...
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. MY FIRST scrolling 8X8 LED
    Last Post: - 15th August 2008, 16:23
  3. 5x7 LED Matrix Scrolling Display
    By roycarlson in forum mel PIC BASIC Pro
    Last Post: - 4th August 2008, 23:50
  4. Replies: 2
    Last Post: - 14th July 2008, 22:11
  5. LCD will not start
