HI all,
This question comes from a long night of trying to guess the internals on my PIC. While trying to migrate from 16f devices to a 18F1330, I stripped down the code to the most basic part to see if I could understand how to get DT_INTs to run.
What I found was that I had to be very careful the timing and prescaler or they started to run over each other and it locked up. The issue was that I had to guess at what was happening. In fact, I'm still not sure if I completely understand all I know about it.Code:DEFINE OSC 8 clear ADCON0 = 0 ADCON1 = %00001111 ' Set up ADCON1 no matter what you're doing!!!!!! T0CON = %10000111 ' Set TMR0 Prescaler Bypassed, T1CON = %10110001 ' TMR1 ON, 1:1 prescaler 30 mS cycle, 5543 preload RCON = %00011111 ' NO Priority for interrupts OSCCON = %01111100 OSCTUNE = %11000010 :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: INCLUDE "DT_INTS-18.bas" ' Base Interrupt System INCLUDE "ReEnterPBP-18.bas" ' Include if using PBP interrupts ':::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: ' Variable definition ':::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: TRISB = %00000000 ledR var PORTB.3 ' ledG var PORTB.4 'on 18F1230 PulseOut var PORTB.7 '************************************************************************** ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler TMR0_INT, _BlankGain, PBP, yes INT_Handler TMR1_INT, _Transmit, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE TMR0_INT @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts '*************************************************************************** Main: TOGGLE PulseOut ' heartbeat without the INT PAUSE 500 goto main BlankGain: 'TMR0_INT, Green LED TOGGLE LEDg TMR0L = 0 TMR0H = 0 @ INT_RETURN Transmit: 'TMR1_INT , RED led TOGGLE LEDR TMR1H = 0 TMR1L = 0 @ INT_RETURN end![]()
Here's the root of the question: How are you watching what is going on inside the code? I have tired on numerous occasions to use MPASM.
I'm sure there is a way, but I have never been able to integrate it and watch while using PBP. I read and article from Chuck Hellebuyck that was suppose to explain it, but I have never got it to work for me.
There is a Simulator from Oshonsoft that is really neat, but strictly Microchip assembly. I have managed to put it to some use, but it is tedious converting PBP to .asm just to see what's going on.
You all can't all be going through this to produce some of the incredible solutions that I see here, are you?
Hi, we are pleased to see that you are using our forum.
We'd like you to become a member of our community. Membership is FREE, please REGISTER and view our forums without these annoying reminders!
Once registered you may post on the forums, download from the file areas and use the WIKI without interruption.
Bo
I thought I had it figured out, but I left it running for that last 6 hours and when I came back, all is not well in Gotham. The Green LED is toggling, but the other two are stuck on. Not working as planned, and wondering how to determine where the issue is....
