PIC-LCD3310 Pin Outs for PicBasic(pro)
Results 1 to 5 of 5
    Question PIC-LCD3310 Pin Outs for PicBasic(pro)
    I've been playing around with the PIC-LCD3310 from SparkFun/Olimex
    ( http://www.olimex.com/dev/pic-lcd3310.html )
    I can't figure out the LCD pin-outs for picbasic(pro). I found the names/pins within the C sample code but I can't seem to (guess) what they mean for pbp.
    From the schematic here are the pins I have to work with...
    http://www.olimex.com/dev/images/PIC...-REV-A-sch.gif
    VDD(1)
    SCK1(2) -> SCK
    MOSI1(3) -> SDIN
    D/#C(4) -> D/#C
    #SS1(5) -> #SCE
    GND(6)
    VOUT(7)
    #RES(8) -> #RES
    Looking on the web/forums I find no xref to these names and what I need within PicBasic(pro).
    ( http://www.melabs.com/downloads/pbpm108.pdf )
    ‘ Set LCD Data port
    DEFINE LCD_DREG PORTA
    ‘ Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 0
    ‘ Set LCD Register Select port
    DEFINE LCD_RSREG PORTA
    ‘ Set LCD Register Select bit
    DEFINE LCD_RSBIT 4
    ‘ Set LCD Enable port
    DEFINE LCD_EREG PORTB
    ‘ Set LCD Enable bit
    DEFINE LCD_EBIT 3
    ‘ Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ‘ Set number of lines on LCD
    DEFINE LCD_LINES 2
    ‘ Set command delay time in us
    DEFINE LCD_COMMANDUS 1500
    ‘ Set data delay time in us
    DEFINE LCD_DATAUS 44
    I found all these great examples/tutorials/etc but NON seem to use a common name. (end rant)
    Dec 2007
    Finland
    Post More info about 3310 LCD ....
    Have you read Using Nokia LCD? There is more info and some codes for 3310 LCD.
    BR,
    -Gusse-
    Yes I did thank you but I can't seem to find a xref for the names of the pins within the PIC_3310 board and the picbasic(pro) commands LCD_DREG_***
    California, USA
    Well, the LCDOUT command in PBP is for a parallel LCD (either 4 or 8 data lines)
    and your Nokia LCD appears to be a SERIAL device... (1 data line and a clock)
    Dec 2007
    Finland
    Post
    3310 is using serial interface (1 Data and Clk) as Byte_Butcher mentioned. You have to use SHIFTOUT -command to transfere data to LCD.
    Here you can find one 3310 LCD example.
    Controllers used in 3310 or variants (8210...) are: PDC8544 (Philips), KS0712 (Samsung) or SED15A2D01 (Seiko-Epson). All are commands wise compatible.
    5.39. LCDOUT
    "PBP supports LCD modules with a Hitachi 44780 controller or equivalent."
    BR,
    -Gusse-
  1. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  2. 4017 counter and pic
    Last Post: - 28th May 2008, 16:09
  3. Help with 16f688
    Last Post: - 21st October 2006, 00:12
  4. RS232 to Parallel Printer Converter
    By Squibcakes in forum Code Examples
    Last Post: - 19th September 2006, 17:11
  5. PIC16F62x 18 pin SMT breakout PCB
    By jdgrotte in forum Adverts
    Last Post: - 1st January 2004, 09:59
