My code for TV remote and MIBAM for RGB control
Results 1 to 5 of 5
    Jan 2007
    Portland Oregon
    Default My code for TV remote and MIBAM for RGB control
    Hi all, I made a RGB LED lamp with super bright RGB LEDs from sparkfun and control the color from my TV remote. I use 16F628s X2 because I couldnt get pulsein to work with MIBAM (inturupt timming issue) Here is the code if it will help anyone. Its not real clean but it works well
    Aaron
    IR CODE
    '*  Name    : IR_RGB_ControlV2
    '*  Author  : Aaron E.Wilson
    '*  Notice  : Copyright (c) 2009
    '*          : All Rights Reserved
    '*  Date    : 2/21/2009
    '*  Version : 1.0
    '*  Notes   : Sets RGB select ports and UP/DN ports from IR remote
    define osc 4
    CMCON     = 7          ' PortA = digital I/O
    VRCON     = 0          ' A/D Voltage reference disabled
    TRISA     = %00000010  ' Set PortA I/O
    TRISB     = %00000000  ' Set PortB I/O
    PORTA     = 0          ' Clear PortA
    PORTB     = 0          ' Clear PortB
    IRpulse_length var word(13)
    xx var Byte
    Command	Var	Byte
    Device Var Byte        'IR Chip---------RGB Chip
    IR_IN var PORTA.1       'Pin 18         N/A
    RED_SEL var PORTB.1     'Pin 7          Pin 18
    BLUE_SEL var PORTB.2    'Pin 8          Pin 3
    GREEN_SEL var PORTB.3   'Pin 9          Pin 17
    UP var PORTB.5          'Pin 11         Pin 1
    DN var PORTB.4          'Pin 10         Pin 2
        gosub ReadIr
        if command = 1 then RED_Adj
        if command = 2 then BLUE_Adj
        if command = 3 then GREEN_Adj
    goto Main
    Red_Adj:
        blue_sel = 0
        Green_sel = 0
        red_sel = 1
        gosub ReadIr
        if command = 17 then
        dn = 0
        up = 1
        up = 0
        if command = 18 then
        up = 0
        dn = 1
        dn = 0
        goto red_adj
    BLUE_Adj:
        red_sel = 0
        green_sel = 0
        blue_sel = 1
        gosub ReadIr
        dn = 0
        up = 1
        up = 0
        up = 0
        dn = 1
        dn = 0
        if command = 1 then red_Adj
        goto blue_adj
    GREEN_Adj:
        red_sel = 0
        Blue_sel = 0
        green_sel = 1
        gosub ReadIr
        dn = 0
        up = 1
        up = 0
        up = 0
        dn = 1
        dn = 0
        goto green_adj
    ReadIR:
        PuLSIN IR_IN,0,IRpulse_length(0)
        if IRpulse_length(0) < 200 then
        goto ReadIR
        Endif
        for xx=1 to 12
        pulsin ir_in,0,IRpulse_length(xx)
        next  xx
        if IRpulse_length(1) < 100 then
        Command.bit0 = 0
        Else
        Command.bit0 = 1
        if IRpulse_length(2) < 100 then
        Command.bit1 = 0
        Else
        Command.bit1 = 1
        if IRpulse_length(3) < 100 then
        Command.bit2 = 0
        Else
        Command.bit2 = 1
        if IRpulse_length(4) < 100 then
        Command.bit3 = 0
        Else
        Command.bit3 = 1
        if IRpulse_length(5) < 100 then
        Command.bit4 = 0
        Else
        Command.bit4 = 1
        if IRpulse_length(6) < 100 then
        Command.bit5 = 0
        Else
        Command.bit5 = 1
        if IRpulse_length(7) < 100 then
        Command.bit6 = 0
        Else
        Command.bit6 = 1
        Command.bit7 = 0
        Command = Command + 1
        If Command = 10 then
        Command = 0
        Endif
        if IRpulse_length(8) < 100 then
        Device.bit0 = 0
        Else
        Device.bit0 = 1
        if IRpulse_length(9) < 100 then
        Device.bit1 = 0
        Else
        Device.bit1 = 1
        if IRpulse_length(10) < 100 then
        Device.bit2 = 0
        Else
        Device.bit2 = 1
        if IRpulse_length(11) < 100 then
        Device.bit3 = 0
        Else
        Device.bit3 = 1
    DebugInfo:
    SEROUT2 PORTA.0,16780,[13]
    SEROUT2 PORTA.0,16780,[10]
    SEROUT2 PORTA.0,16780,["Device ", dec Device, " Command ", dec command]
    MIBAM CODE
    '*  Name    : Adj_Color
    '*  Date    : 2/22/2009
    '*  Version : Final
    '*  Notes   :
    ;_________________________Interrupt Context save locations]_________________
    wsave       var byte    $20     SYSTEM      ' location for W if in bank0
    wsave1      VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2      VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ssave       VAR BYTE    BANK0   SYSTEM      ' location for STATUS register
    psave       VAR BYTE    BANK0   SYSTEM      ' location for PCLATH register
    ;----[ MIBAM Setup ]--------------------------------------------------------
    BAM_COUNT CON 3                     ; How many BAM Pins are used?
    INCLUDE "MIBAM.pbp"                 ; Mirror Image BAM module
    RED    VAR BYTE
    GREEN  VAR BYTE
    BLUE   VAR BYTE
    BAM_LIST  macro                     ; Define PIN's to use for BAM
         BAM_PIN (PORTB,0, GREEN)       ; Pin 6
         BAM_PIN (PORTB,1, BLUE)        ; Pin 7
         BAM_PIN (PORTB,2, RED)         ; Pin 8
      BAM_INIT  BAM_LIST                ; Initialize the Pins
    ;----[ Chip Setup ]--------------------------------------------------------
    define osc 4
    TRISA     = %00011111  ' Set PortA I/O
    TRISB     = %11111000  ' Set PortB I/O
    ;----[ Adjustment Setup ]-------------------------------------------------
    RED_VAL var byte
    GREEN_VAL var byte
    BLUE_VAL var byte
    UP_SEL var bit
    DN_SEL var bit
    RED_PORT var PORTA.1        'Pin 18
    GREEN_PORT var PORTA.0      'Pin 17
    BLUE_PORT var PORTA.4       'Pin 3
    UP_PORT var PORTA.2         'Pin 1
    DN_PORT var PORTA.3         'Pin 2
    ;----[ Inital Settings ]--------------------------------------------------
    RED_VAL = 0
    GREEN_VAL = 0
    BLUE_VAL = 0
    ;----[ Program ]----------------------------------------------------------
        gosub led
        gosub Adjust
    Adjust:
        if PORTA = 0 then main
        Red_Up:
        if red_val > 250 then red_dn
        if red_port = 1 and up_port = 1 then
        red_val = red_val +1
        Red_Dn:
        if red_val = 0 then green_up
        if red_port = 1 and dn_port = 1 then
        red_val = red_val -1
        Green_Up:
        if green_val > 250 then green_dn
        if green_port = 1 and up_port = 1 then
        green_val = green_val +1
        Green_Dn:
        if green_val = 0 then blue_up
        if green_port = 1 and dn_port = 1 then
        green_val = green_val -1
        Blue_Up:
        if Blue_val > 250 then BLue_dn
        if Blue_port = 1 and up_port = 1 then
        Blue_val = Blue_val +1
        Blue_Dn:
        if Blue_val = 0 then main
        if BLue_port = 1 and dn_port = 1 then
        Blue_val = Blue_val -1
    LED:
        red = red_val
        pause 20
        blue = blue_val
        pause 20
        green = green_val
        pause 20
    Jan 2007
    Portland Oregon
    Default Thanks to DTs MIBAM
    Great stuff Darryl
    Aaron
    Feb 2008
    schematic
    Jan 2007
    Portland Oregon
    Default Thanks to others code
    I didnt mean to sugest I wrote all the code
    I just put stuff together to make something fun
    Feb 2011
    Default Re: Thanks to others code
    shematic ?
