16F627A to 16F88 conversion problem
Results 1 to 5 of 5
    Feb 2009
    Default 16F627A to 16F88 conversion problem
    I was working on a project and ran out of room on my 627A and switched over to a 16F88 spare that I had.
    My code is a clock that can be programmed via IR signals. Strangely, the clock portion works fine, however the IR part no longer works. There was no problem changing the device over to the 88, and the program compiled just fine, so I am not sure what is wrong exactly.
    Here is a copy of the code:
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
    Include "modedefs.bas"
    DEFINE LOADER_USED 1     ' Using boot-loader for initial prototype
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 0
    DEFINE DEBUG_BAUD 19200
    define DEBUG_MODE 0 ' 1 = inverted, 0 = true
    Enter     CON     11      'Enter key on remote
    Out       VAR     BYTE(4) '7 seg display
    TChange   VAR     BYTE(4) 'Time change digits
    Enable1   VAR     BYTE(4) 'Power goes on for memory 1
    Disable1  VAR     BYTE(4) 'Power goes off for memory 1
    Enable2   VAR     BYTE(4) 'Power goes on for memory 2
    Disable2  VAR     BYTE(4) 'Power goes off for memory 2
    TimeSet   VAR     BIT     '1 = Enabled 0= Disabled
    Second    var     byte
    Minute2   VAR     BYTE    ' Ones column for minutes
    Minute1   VAR     BYTE    ' Tens column for minutes
    Hour2     VAR     BYTE    ' Ones column for hours
    Hour1     VAR     BYTE    ' Tens column for hours
    Counts    VAR     BYTE    ' Counts for timer
    Loop      VAR     BYTE     ' Loop counter
    Index     VAR     BYTE     ' Index counter
    IR_PULSE  VAR     BYTE(13) ' 13-bytes. 8 data ; 5 address
    PULSE_IN  VAR     WORD     ' Raw pulsin value
    DBYTE     VAR     BYTE     ' Holds 8-bit data byte
    ABYTE     VAR     BYTE     ' Holds 5-bit hardware address
    Second = 0
    Minute1 = 0
    Minute2 = 0
    Hour1 = 1
    Hour2 = 2
    Loop = 0
            INT_Handler   TMR1_INT,   ReloadTMR1,   ASM,  no    ; MUST be first
            INT_Handler   TMR1_INT,   _T1handler,   PBP,  yes
    ;--- Change these to match the desired interrupt frequency -------------------
    ;--- See http://DarrelTaylor.com/DT_INTS-14/TimerTemplate.html for more Info.
    @Freq       = 10                  ; Frequency of Interrupts in Hz
    @Prescaler  = 2                   ; Timers Prescaler setting
    T1CON = $10                       ; $30 = Prescaler 1:8, TMR1 OFF
    ; $00=1:1, $10=1:2, $20=1:4, $30=1:8 --  Must match @Prescaler value
    @ INT_ENABLE  TMR1_INT            ; enable Timer 1 interrupts
    GOSUB StartTimer                  ; Start the Timer
       PULSIN PORTB.7,0,PULSE_IN        '// Read-in start pulse
    IF (PULSE_IN < 200) OR (PULSE_IN = 0) THEN '// Less than Start pulse, then keep looking
       GOTO Main                       '// so clear outputs & return.
    @ INT_DISABLE TMR1_INT
    GOTO Verify
    '--Main 2 used after values have been entered without Enter press to get around INT
    Main2:
       GOTO Main2                       '// so clear outputs & return.
    Verify:                              '// Read, Decode, then verify data
       FOR Index = 0 TO 12               '// Setup to read-in 13 pulses
        PULSIN PORTB.7,0,IR_PULSE[Index] '// Read 13 low-going pulses on RA.7
       NEXT Index                        '// Loop x times
       DBYTE = $FF                       '// Start with all 1's and find each 0
       FOR Index = 0 TO 7                '// Get 8 "data" bits
        IF IR_PULSE[Index] < 100 THEN DBYTE.0[Index]=0 '// Less than 1mS = 0
       NEXT Index
    Result:
    Loop = Loop + 1
    Out[Loop] = DBYTE + 1
    If Out[Loop] = 10 then
    Out[Loop] = 0
    EndIF
    DEBUG "D", Out[1],out[2],out[3],out[4]
    PAUSE 500
    IF Loop = 5 Then
    Loop = 0
    EndIF
    If TimeSet = 1 then                   'Time change
       IF OUt[5] = 12 THEN                 'If enter pressed, with valid time entry
          IF (Out[1] = 2 AND OUt[2]<=4) AND (Out[3]<=5) And (out[4] <=9) Then
           Second = 0
           HOur1 =Out[1]                   'Set new time
           Hour2 =Out[2]
           Minute1 =Out[3]
           Minute2 =Out[4]                 'Clear time entry bit.
           Out[1] = 20
           Out[2] = 20
           Out[3] = 20
           Out[4] = 20
           Out[5] = 20
           TimeSet = 0
           GOTO Main
           IF (Out[1] <= 2 AND OUt[2]<=4) AND (Out[3]<=5) And (out[4] <=9) Then
           Second = 0
           Hour2 =Out[2]
           Minute1 =Out[3]
           Out[1] = 20
           Out[2] = 20
           Out[3] = 20
           Out[4] = 20
           Out[5] = 20
           TimeSet = 0
           GOTO Main
           EndIF
        GOTO Main
    IF OUT[1]=1 AND Out[2]=7 and OUt[3]=7 and Out[4]=12 THEN  'TimeSet entry correct  (177 + enter)?
    Out[1] = 20
    Out[2] = 20
    Out[3] = 20
    Out[4] = 20
    Out[5] = 20
    TimeSet = 1                          'If they enter the correct code, then unlock features
    GOTO Main
    GOTO Main2
    T1handler:
    Counts = Counts + 1  ;   Increase the 1/10th sec count
    IF counts = 10 then
    Counts = 0
    Second = Second + 1      'Calculate time and change values
    If Second = 60 then
       Minute2 = Minute2 +1
       Second = 0
         IF Minute2 = 10 THEN
         Minute1 = Minute1 + 1
         Minute2 = 0
            IF Minute1 = 6 then
            Hour2 = Hour2 + 1
            Minute1 = 0
               IF Hour2 = 10 THEN
               Hour1 = Hour1 + 1
               Hour2 = 0
    IF Hour1 = 2 AND HOUR2 = 4 THEN      'Roll clock over from 23 to 0
       Hour1 = 0
       Hour2 = 0
    If Hour1 = 0 then                    'If hour 1 is 0 then do not display it
       Hour1 = 20                        'SLED-C4 will not display anything if the
    Endif                                'value is above 10
    DEBUG "D", Hour1,Hour2,Minute1,Minute2 ' Display time
    DEBUG "P",12,"~"                       ' Display Colon
    @ INT_RETURN
    @ INT_RETURN
    ;---[TMR1 reload - interrupt handler]-----------------------------------------
    ASM                               ; Calculate Timer Reload Constant
    ReloadInst  = 8                   ; # of Intructions used to reload timer
      if ((Prescaler == 1)||(Prescaler == 2)||(Prescaler == 4)||(Prescaler == 8))
    MaxCount    = 65536 + (ReloadInst / Prescaler)
    TimerReload = MaxCount - (OSC*1000000/4/Prescaler/Freq)
        if ((TimerReload < 0) || (TimerReload > (65535-ReloadInst)))
            error Invalid Timer Values - check "OSC", "Freq" and "Prescaler"
          error Invalid Prescaler
    @Timer1 = TMR1L                   ; map timer registers to a word variable
    Timer1       VAR WORD EXT
    TimerReload  CON EXT              ; Get the External Constant
    TMR1ON       VAR T1CON.0          ; Alias the Timers ON/OFF bit
    ;---Reload Timer1------
    ReloadTMR1
        MOVE?CT  0, T1CON, TMR1ON     ;  1     stop timer
        MOVLW    LOW(TimerReload)     ;  1     Add TimerReload to the
        ADDWF    TMR1L,F              ;  1     value in Timer1
        BTFSC    STATUS,C             ;  1/2
        INCF     TMR1H,F              ;  1
        MOVLW    HIGH(TimerReload)    ;  1
        ADDWF    TMR1H,F              ;  1
        MOVE?CT  1, T1CON, TMR1ON     ;  1     start timer
      INT_RETURN
    ;---Start/Stop controls -----
    StartTimer:
        Timer1  = TimerReload         ; Load Timer
        TMR1ON = 1                    ; start timer
    StopTimer:
        TMR1ON = 0                    ; stop timer
    Thanks for the help
    The 16F88 has a lot of Analog pins that need to be disabled.
    It has an A/D module, the 627A only has comparators.
    <br>
    16F648A uses the same data sheet (as the 627A) and has twice the code space.
    Feb 2009
    Thanks for the responses. Ill figure out how to adjust my I/O pins (never done it) and im sure it would work fine.
    I purchased 16F628A PIC's to replace the 16F627A that I was using. They seemed to have double the memory if I recall correctly (3.5kb as opposed to 1.75kb) and the 648's had 7kb of memory.
    Did I miss something?
    Then let's make the first one easy...
    ANSEL = 0
    Whenever you start using a new chip, the first thing you should do is look at the Comparator and Analog-to-Digital sections of the datasheet for the device you are using.
    The different varieties of PIC's have many different ways of disabling the Analog functions, so you have to look in the datasheet to know which way to do it on that particular chip.
    For the 16F88, the comparators are disabled at Power-Up.
    For many other chips, that's not the case.
    <br>
  1. 16F88 ADC problem
    By greensasquatch in forum mel PIC BASIC Pro
    Last Post: - 7th September 2008, 17:16
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 17:26
  3. A/D conversion problem on 18F4431
    By ttease in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 00:03
  4. Conversion Problem
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 18th March 2007, 13:09
  5. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 19:21
