Microstepper controller
Results 1 to 15 of 15
    May 2008
    Italy
    Default Microstepper controller
    I have been thinking for a while, how to put togeter a simple microstepper controller without using a ready made commercial driver.
    At the end, I came up with this simple project capable to drive unipolar stepper motor in three different modes
    FULL STEP
    HALF STEP
    MICRO STEP
    The Pic micro used in this work is a Pic 16F628 a powerfull small micro with PWM capability. With this MCU plus a 74HC04 and a74HC86 the controller will produce 20 microsteps out of a nominal motor step.
    An additional improvement of this controller, is the capability to accept travel commands of 24 Bits, wich gives to the user the possibility to send positioning profile of over 16 millions steps.
    Controller accept commands via TTL serial port @ 9600,n,8,1 and return an (Ack) once the positioning profile has been completed.
    Download the zipped file which contains schematic + software + user manual
    Enjoy
    Al.
    May 2009
    Northeastern USA
    Thanks -
    I loved your stepper project, and this just as helpful. My students are very motivated by projects with possible robotic uses.
    Thanks again - Fiz
    Fiz,
    Check out our Micro-Bot projects section; http://web.archive.org/web/201301160...-Bot/index.htm
    If your ship to address is a school, I'll send you a couple of our Micro-Bot circuit
    boards - with a few additional components for experiments - gratis.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    May 2008
    Italy
    Thank you Fiz, you are welcome.
    Al.
    May 2010
    Chile
    Seems like a nice way of driving steppers, really a clever solution with gate logic.
    (long live gates, gates are[n't] dead)
    One question:
    The hex file included is version compatible with the 16F628A?
    Just asking because sometimes compiled hexs for different versions just don't work
    "If at first doesn't work, kicking it wont help either"
    May 2008
    Italy
    You should have no problem.
    Cheers
    Al.
    Jan 2015
    Default Re: Microstepper controller
    Hello there, im interested in designing as microstepper controller via a pic, using everything that its needed (as i have been investigating, it uses pwm and other functions). The thing is that the only programming language i know well is picbasic pro. is it possible to do such thing with this compiler?, lets say using a pic like 16f877a or a 18fxx?, can somebody help me out with a code in this language?, tis for controlling a bipolar stepper motor. i only want to know how it works and undersand it because i dont have it very clear, and of course in basic language.
    Thanks everybody, Regards.
  1. Temperature Controller using PIC16F628A
    By bentech4u in forum mel PIC BASIC
    Last Post: - 14th March 2010, 19:44
  2. problem with the GSM controller
    By Dariolo in forum mel PIC BASIC Pro
    Last Post: - 30th May 2009, 20:33
  3. Fridge controller
    By nomad in forum General
    Last Post: - 23rd February 2008, 07:13
  4. Graphics controller for the Sitronix ST7549
    By ttease in forum mel PIC BASIC Pro
    Last Post: - 26th May 2007, 21:45
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
