2nd order Low-pass passive RC filter on PWM
Results 1 to 7 of 7
    Nov 2008
    Default 2nd order Low-pass passive RC filter on PWM
    I have working a PWM output driving the input of a 0 to 200mV digital panel meter, but would like some input/review of the filter. I'm running the uP @ 4MHz, the PWM at 3.9kHz with 10 bit resolution and it seems to run just fine for my application but I'm not sure if I can improve on the RC filter, it was basically pulled from the net and I can't seem to find a good online design program to help.
    I found by trial and error that the 1.46M voltage divider load worked well, any advantage / disadvantage to going higher?
    Any comments would be appreciated.
    Oct 2003
    holland
    If you take a longer RC time, the ripple voltage will be smaller, but the time when the DC outputvoltage is stable is than longer.
    Well higher impedance voltage divider may help or screw your reading depending at least of your instrument input impedance.
    However higher impedance of your voltage divider, the less you alter the RC filter.
    Personally, i would avoid a too high impedance to the instrument, maybe refine the whole design with a buffer in between.
    Some instruments also have their own low pass filter at the input, so I would compare a DVM reading with. Not as this sure that you really need to go crazy in your PWM filtering. First order might work as well.
    Default smoothing pwm
    did you try just using the 1 micro farad across the 46k ohm ?
    Nov 2008
    The input impedance is 1000M, pretty darn high.
    Ahhhh, yes. I tried just connecting the PWM across the voltage divider and it looks great. I looked at the block diagram of the DPM and there is a filter on the input.
    Looks like that might not be necessary.
    Life is easier than we think sometime huh?
    Glad to know it's working as expected now.
    Enjoy!
    Nov 2008
    And I just keep trying to make it harder. That's what happens when we don't look at the big picture and get lost in the trees.
    Still, it should be harder then that .... shouldn't it
    Mark
  1. Old and beyond help ?
    By DavidFMarks in forum mel PIC BASIC Pro
    Last Post: - 11th December 2008, 16:23
  2. "hello world" with 18f6680
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 6th February 2008, 07:06
  3. Problems with RC2 and RC3
    Last Post: - 29th May 2006, 18:19
  4. 2nd Order Digital Filter for 24-bit
    By sefayil in forum mel PIC BASIC
    Last Post: - 2nd December 2005, 22:55
  5. 4-line LCD Help - using PortA instead of B
    Last Post: - 31st March 2005, 04:14
