Timer interrupt frequency
Results 1 to 2 of 2
    Jan 2006
    Slovenia EU
    Default Timer interrupt frequency
    Hello,
    I use template from DT for my project. I wish to made simple voltage to frequency converter. AD converter measure voltage and show value from 0-1023 o LCD. On output pin become 2Hz pulse. This working ok.
    Problem is following:
    I don't know where can place routine which will be change internal timer prescaler from 2Hz to 2048Hz. This frequency must be read from AD. (value*2)
    Is it possible to made?
    routine is here:
    'PIC18F252
    ADCON1=%10001110
    DEFINE LCD_DREG PORTC
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTC
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 4
    DEFINE LCD_COMMANDUS 4000
    DEFINE LCD_DATAUS 255
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 11
    INCLUDE "DT_INTS-18.bas"
    INCLUDE "ReEnterPBP-18.bas"
    w0 var word
    w1 var word
    FOUT VAR PORTB.1
    INT_Handler TMR1_INT, ReloadTMR1, ASM, no ; MUST be first
    INT_Handler TMR1_INT, _T1handler, PBP, yes
    INT_CREATE
    @Freq = 2'10 ; Frequency of Interrupts in Hz
    @Prescaler = 8 ; Timers Prescaler setting
    T1CON = $30 ; $30 = Prescaler 1:8, TMR1 OFF
    ; $00=1:1, $10=1:2, $20=1:4, $30=1:8 -- Must match @Prescaler value
    @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
    GOSUB StartTimer ; Start the Timer
    ADCIN 0, w1
    lcdout $fe,1, #W1, " VAL"
    PAUSE 100
    GOTO Main
    T1handler:
    toggle FOUT
    @ INT_RETURN
    ReloadInst = 8 ; # of Intructions used to reload timer
    if ((Prescaler == 1)||(Prescaler == 2)||(Prescaler == 4)||(Prescaler == 8))
    MaxCount = 65536 + (ReloadInst / Prescaler)
    TimerReload = MaxCount - (OSC*1000000/4/Prescaler/Freq)
    if ((TimerReload < 0) || (TimerReload > (65535-ReloadInst)))
    error Invalid Timer Values - check "OSC", "Freq" and "Prescaler"
    error Invalid Prescaler
    @Timer1 = TMR1L ; map timer registers to a word variable
    Timer1 VAR WORD EXT
    TimerReload CON EXT ; Get the External Constant
    TMR1ON VAR T1CON.0 ; Alias the Timers ON/OFF bit
    ReloadTMR1
    MOVE?CT 0, T1CON, TMR1ON ; 1 stop timer
    MOVLW LOW(TimerReload) ; 1 Add TimerReload to the
    ADDWF TMR1L,F ; 1 value in Timer1
    BTFSC STATUS,C ; 1/2
    INCF TMR1H,F ; 1
    MOVLW HIGH(TimerReload) ; 1
    ADDWF TMR1H,F ; 1
    MOVE?CT 1, T1CON, TMR1ON ; 1 start timer
    INT_RETURN
    StartTimer:
    Timer1 = TimerReload ; Load Timer
    TMR1ON = 1 ; start timer
    StopTimer:
    TMR1ON = 0 ; stop timer
    Hi Samoele,
    The "Timer Template" was intended for a Fixed Frequency.
    There's no easy way to convert it to what you want.
    The SSPWM (Slow speed Software PWM) program ...
    http://www.pbpgroup.com/modules/wfse...hp?articleid=6
    does allow you to change either frequency or dutycycle on the fly.
    But it only goes down to 16hz, and would need a 20mhz crystal to get your upper frequency.
    Sorry,
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 17:39
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. How to set interrupt for Timer 0
    Last Post: - 18th November 2006, 00:14
  4. USART interrupt not interrupting right
    By Morpheus in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 01:07
  5. Multi Interrupt How To ?
    By capitano in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2005, 14:48
