USB to USB flash Drive File Copier - Page 5
+ Reply to Thread
Page 5 of 6 FirstFirst 123456 LastLast
Results 161 to 200 of 223
  1. #161
    Darn...
    Check the pick with a one second blink to see if it is running at the expected speed?
    Using a 232 type chip between PIC and PC?
    Post the exact code and configs you are testing with.
    Maybe we will see some thing.
  2. #162
    Mar 2010
    i testing with the code i post b4..i got connect to 232 using max232..i already test the mode with 84,8276
    INCLUDE "modedefs.bas"
    DEFINE OSC 20
    DEFINE LCD_DREG PORTA
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 4
    DEFINE LCD_RWREG PORTB
    DEFINE LCD_RWBIT 6
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    TXD VAR PORTC.7 'AD0 TXD VDIP2 connect RX
    RXD VAR PORTC.6 'AD1 RXD VDIP2 connect TX
    Flow VAR PORTC.0 'AD2 RTS
    Start:
    HIGH RXD
    PAUSEUS 10
    SEROUT2 RXD,84,["ECS",13]
    HIGH RXD
    PAUSEUS 10
    SEROUT2 RXD,84,["IPA",13]
    HIGH RXD
    PAUSEUS 10
    SEROUT2 RXD,84,["A:",13] 'choose source disk
    HIGH RXD
    PAUSEUS 100
    SEROUT2 RXD,84,["DIR",13]
    GOTO Start
  3. #163
    I would like to see you test a simple "hello world" to the PC without the VDIP involved.
    At this point we do not know where the problem is. Need to narrow it down.
  4. #164
    Mar 2010
    i did not connect to the VDIP..just connect with max232...
    HIGH RXD
    and i change to
    HIGH RXD
    SEROUT2 RXD,84,["hello",13]
  5. #165
    Mar 2010
    DEFINE OSC 20
    FlowIn VAR PORTC.0 'AD2 RTS
    StartDisk:
    RXD=1
    SEROUT2 VinRXD,84,["hello"]
    pauseus 1000
    GOTO StartDisk
    now i testing with this code...and i wan to ask is after i set the configuration bit..the hex code will become 24kb...and the pic16f873A program memory only 4k is this got problem?
  6. #166
    There is no way that little bit of code would make a hex that large.
    The data sheet says the program memory is 7.2K Bytes.
    I really have no idea what you are doing or looking at.
    Can you make a LED blink with this chip?
  7. #167
    Mar 2010
    i know so a little bit cant have so large hex code....
    before i set the configuration bit.. the hex code size is small..after i export it..it become large...
  8. #168
    Looking at your code you have the TX and RX mixed up and here
    VinRXD does not exist.
    Try this code without the VDIP. Connect as shown in the comments.
    @ __config _HS_OSC & _WDT_OFF & _LVP_OFF & _CP_OFF
        DEFINE OSC 20
        TXD VAR PORTC.6   'CONNECT TO MAX232 PIN #11
                          'MAX232 PIN#14 TO DB9 #2
        RXD VAR PORTC.7
        StartDisk:
        SEROUT2 TXD,84,["hello",$d,$a]
        pauseus 1000
        GOTO StartDisk
  9. #169
    Mar 2010
    when i add in this line
    and compile .. get error
    Error[118] C:\USERS\DESKTOP\PIC16F873A\PIC TO HYT\ABC.ASM 157 : Overwriting previous address contents (2007)
  10. #170
    Ok. You must be setting the configuration bits in the *inc file.
    Commnt that line and use those settings.
    Fir more of what I am talking about
  11. #171
    Mar 2010
    follow the code u given already success print hello to hyperterminal...
    is that means if i modified the code n connect to VDIP2 module..
  12. #172
    Yes, we are going now!!!
    Connect the VDIP to the PC with the MAX232 chip like you had when you saw the firmware message.
    Connect the VDIP's input to the same wire you now have connected to the PC from the PIC.
    What we will do is send commands to the VDIP from the PIC and have the VDIP send the response to the PC...
    We do need to add another connection for flow control. The "FLOWIN" signal from the VDIP will tell the PIC it is OK to send another command. I am using the VDIP1 so check the VDIP2 pin out. I think they are the same...
    Try to connect FLOWIN on a non ADC pin for now. Change the code below to your pin.
    The below should cause the VDIP to diplay on the terminal a
    D:\>
    every 1.5 seconds..
    VinRXD  VAR PORTC.6 'DATA TO VDIP PIN #8 ON VDIP1
    FLOWIN  VAR PORTD.6 'FLOW CONTROL FROM VDIP PIN #9 ON VDIP1
    START:
    HIGH PORTD.2  'LED
    PAUSE 250
    LOW PORTD.2
    PAUSE 250
    SEROUT2 VinRXD,84,["ECS",13] '9600 TRUE
    HIGH VinRXD
    PAUSEUS 10
    SEROUT2 VinRXD,84,["IPA",13]
    HIGH VinRXD
    PAUSEUS 10
    WAIT111:
    IF FLOWIN = 1 THEN WAIT111
    PAUSE 1000
    GOTO START
  13. #173
    Mar 2010
    thx..
    i wan to ask..this
    "HIGH PORTD.2 'LED
    PAUSE 250
    LOW PORTD.2
    PAUSE 250"
    line is for ?
    and why need put this "HIGH VinRXD"line?
    because i test on without the HIGH VinRXD it also can send to the VDIP2 and display to the hyperterminal..
    if that this HIGH VinRX necessary?
  14. #174
    So you got it working???
    The LED is something I like to do to see it the PIC is running. A heart beat. . . .
    The HIGH VinRXD is just a little insurance to put the pin in the correct state before transmitting data. Yes, it is not always needed.
  15. #175
    Mar 2010
    ya thankyou very much...i get it work and succes send comment to the VDIP2.now working on the 2 line LCD..because it cant display the file name correctly...
  16. #176
    Quote Originally Posted by fokus_1116 View Post
    COOL Glad to have helped.
    For the LCD problem maybe it is the same as newbie was having?
  17. #177
    Mar 2010
    ya almost the same...
  18. #178
    If you can not figure it out from what we did with newbie let us know and we will try to figure it out.
    Good luck!
  19. #179
    Mar 2010
    i think another prob is ..i using 4bit....i will try using 8bit to test it..
  20. #180
    Mar 2010
    i follow the way newbie show to the LCD...but i only can show 1 or 2 file name only..then keep on repeat the second file name..
  21. #181
    Hey, at least you are getting something
    I do not think newbie ever showed us his last code so I am not sure what you are using. Sounds like a loop problem but to be sure post your current code so we can have a look at it.
  22. #182
    Mar 2010
    DEFINE OSC 20
    DEFINE SER2_BITS 8
    DEFINE LCD_DREG     PORTA 'LCD Data line
    DEFINE LCD_DBIT     0
    DEFINE LCD_RSREG    PORTB  'RS bit
    DEFINE LCD_RSBIT    5
    DEFINE LCD_EREG     PORTB 'E bit
    DEFINE LCD_EBIT     4
    DEFINE LCD_RWREG    PORTB 'RW bit
    DEFINE LCD_RWBIT    6
    DEFINE LCD_BITS     4
    DEFINE LCD_LINES    2
    DEFINE LCD_CHARS    20
    VinTXD VAR PORTC.7 'AD0 TXD VDIP2 connect RX
    VinRXD VAR PORTC.6 'AD1 RXD VDIP2 connect TX
    T VAR PORTC.0 'push button
    D VAR PORTC.1 ' PUSH BUTTON FOR DISPLAY
    FILE1 VAR BYTE[12]
    FILE2 VAR BYTE[12]
    FILE3 VAR BYTE[12]
    X1    VAR    BYTE
    X2    VAR    BYTE
    X3    VAR    BYTE
    X4    VAR    BYTE
    X5    VAR    BYTE
    X6    VAR    BYTE
    X7    VAR    BYTE
    X8    VAR    BYTE
    X9    VAR    BYTE
    X10    VAR    BYTE
    X11    VAR    BYTE
    X12    VAR    BYTE
    X13  VAR    BYTE
    X14  VAR    BYTE
    X15  VAR    BYTE
    X16  VAR    BYTE
    X17  VAR    BYTE
    X18  VAR    BYTE
    X19  VAR    BYTE
    X20  VAR    BYTE
    X21  VAR    BYTE
    X22  VAR    BYTE
    X23  VAR    BYTE
    X24  VAR    BYTE
    X25  VAR    BYTE
    X26  VAR    BYTE
    X27  VAR    BYTE
    X28  VAR    BYTE
    X29  VAR    BYTE
    X30  VAR    BYTE
    X31  VAR    BYTE
    X32  VAR    BYTE
    X33  VAR    BYTE
    X34  VAR    BYTE
    X35  VAR    BYTE
    X36  VAR    BYTE
    CRET VAR BYTE
    CRET = $0D
    StartDisk:
    pause 3000
    HIGH VinRXD
    LCDOUT $FE,1, "1"
    pause 2500
    PAUSEUS 1000
    HIGH VinRXD
    PAUSEUS 3000
    LCDOUT $FE,1, "2"
    pause 2500
    HIGH VinRXD
    PAUSEUS 1000
    SEROUT2 VinRXD,84,["A:",13]
    LCDOUT $FE,1, "3"
    pause 2500
    HIGH VinRXD
    PAUSEUS 1000
    SEROUT2 VinRXD,84,["DIR",13]
    LCDOUT $FE,1, "4"
    'pause 2500
    PAUSEUS 1000
    WAIT1
    SERIN2 VinTXD,84,[WAIT(CRET),STR FILE1\12 \CRET,WAIT(CRET),STR FILE2\12 \CRET,WAIT(CRET),STR FILE3\12 \CRET]
    LCDOUT $FE,1, "5"
    'pause 2500
    X1 = FILE1[0]
    X2 = FILE1[1]
    X3 = FILE1[2]
    X4 = FILE1[3]
    X5 = FILE1[4]
    X6 = FILE1[5]
    X7 = FILE1[6]
    X8 = FILE1[7]
    X9 = FILE1[8]
    X10 = FILE1[9]
    X11 = FILE1[10]
    X12 = FILE1[11]
    X13 = FILE1[0]
    X14 = FILE1[1]
    X15 = FILE1[2]
    X16 = FILE1[3]
    X17 = FILE1[4]
    X18 = FILE1[5]
    X19 = FILE1[6]
    X20 = FILE1[7]
    X21 = FILE1[8]
    X22 = FILE1[9]
    X23 = FILE1[10]
    X24 = FILE1[11]
    PAUSE 100
    LCDOUT $FE,1,X1,X2,X3,X4,X5,X6,X7,X8,x9,x10,x11,x12
    "actually i not really understand for this line "SERIN2 VinTXD,84,[WAIT(CRET),STR FILE1\12 \CRET,WAIT(CRET),STR FILE2\12 \CRET,WAIT(CRET),STR FILE3\12 \CRET]" "
    the code of this can display only 1 file name...but if i add another line LCDOUT the LCD display 2 same file name...
  23. #183
    Mar 2010
    dear mackrackit,
    i already figure out..how to make it display..but the array part need got some prob.. it that got other way to make the file store at X
    X1 = FILE1[0]
    X2 = FILE1[1]
    X3 = FILE1[2]
    X4 = FILE1[3]
    X5 = FILE1[4]
    X6 = FILE1[5]
    X7 = FILE1[6]
    X8 = FILE1[7]
    X9 = FILE1[8]
    X10 = FILE1[9]
    X11 = FILE1[10]
    X12 = FILE1[11]
    X13 = FILE2[0]
    X14 = FILE2[1]
    X15 = FILE2[2]
    X16 = FILE2[3]
    X17 = FILE2[4]
    X18 = FILE2[5]
    X19 = FILE2[6]
    X20 = FILE2[7]
    X21 = FILE2[8]
    X22 = FILE2[9]
    X23 = FILE2[10]
    X24 = FILE2[11]
  24. #184
    This line WAITS for a carriage return (CRET) then will take the next 12 character and place then in the array FILE1 or FILE2 and so on.
    The X~ array is just a dummy array to give a place to play with things, parse if needed. It is not really needed.
  25. #185
    Mar 2010
    mackrackit,
    can i use 2D array in picbasic pro compile or the pic16f873A can support the 2D array?
  26. #186
  27. #187
    Mar 2010
    dear sir..
    i plan to use 2d array to store the file name and then display it to the LCD..
    but cant make it success ... is that any suggestion to make it the array work?
  28. #188
    The best I can do is tell you to start a new thread about the 2D array problem. I have not tried them myself.
    Be sure to post your code when you start the new thread...
  29. #189
    Mar 2010
    i already tired to try the 2d array but it still cannot work....
    is that any way to store the file name except using the 2d array?
  30. #190
    If you do not want to post your code and ask about why it does not work I guess there is not much anyone can do to help. You have not even explained exactly what you are trying to do.
    It seems like you now have the VDIP running. So if you want help with arrays or something else start a new thread as suggested.
  31. #191
    Mar 2010
    so sorry,
    i got post my coding..but dunno y cant display...
    now the coding not at me..later i will post again for the coding...thank for your inform
  32. #192
    Mar 2010
    dear sir,
    y when i put the line @Put2D(X,Y) then cannot compile got error
    Error[108] C:\USERS\PIC16F873A\ARRAY TEST 2\ARRAY2.ASM 311 : Illegal character (()
    Mar 2010
    dear mackrackit
    below is my code..it like stuck at some where please help..
    DEFINE OSC 20
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EBIT 4
    DEFINE LCD_RWBIT 6
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_CHARS 20
    X VAR BYTE SYSTEM
    Y VAR BYTE SYSTEM
    ; -- Working with 2D arrays ---
    Width CON 8 ; Number of bytes in a Row
    Length CON 10 ; Number of Rows in the array
    ArraySize CON Width * Length ; Total size of the array
    MyArray VAR BYTE[ArraySize] ; The Array
    Idx VAR BYTE ; Index, points to 1D array locations
    Xidx VAR BYTE ; 2D column Index
    Yidx VAR BYTE ; 2D row Index
    ArrayData VAR BYTE ; holding register for array data
    ;----[Get a value from the 2D array]----------------------------------------
    Get2D:
    Idx=(Yidx*Width+Xidx) MIN (ArraySize-1) ; find Index, limit to ArraySize
    ArrayData = MyArray(Idx) ; retrieve value from the array
    ;----[Put a value in the 2D array]------------------------------------------
    Put2D:
    MyArray(Idx) = ArrayData ; store the value in the array
    ;----[Set entire array to 0's]----------------------------------------------
    Clear2D:
    FOR Idx = 0 TO ArraySize-1
    MyArray(Idx) = 0
    NEXT Idx
    ;----[Turn the Subroutines into Functions]----------------------------------
    #Get2D macro X, Y
    MOVE?BB X, _Xidx ; copy users X value to Xidx
    MOVE?BB Y, _Yidx ; copy users Y value to Yidx
    L?CALL _Get2D ; call the Get subroutine
    endm ; value is returned in ArrayData
    #define Get2D(X, Y) #Get2D X, Y ; allows paretheses in macro
    #Put2D macro X, Y ; value should be in ArrayData
    L?CALL _Put2D ; call the Put subroutine
    #define Put2D(X, Y) #Put2D X, Y ; allows paretheses in macro
    #Clear2D macro
    L?CALL _Clear2D ; call the Clear subroutine
    #define Clear2D() #Clear2D
    ;a var BYTE[12]
    FILE1 VAR BYTE[12]
    FILE2 VAR BYTE[12]
    FILE3 VAR BYTE[12]
    ;X VAR BYTE
    CRET VAR BYTE
    CRET = $0D
    StartDisk:
    pause 3000
    HIGH VinRXD
    LCDOUT $FE,1, "1"
    PAUSEUS 1000
    HIGH VinRXD
    PAUSEUS 1000
    LCDOUT $FE,1, "2"
    HIGH VinRXD
    PAUSEUS 1000
    LCDOUT $FE,1, "3"
    HIGH VinRXD
    PAUSEUS 1000
    LCDOUT $FE,1, "4"
    PAUSEUS 1000
    WAIT1
    SERIN2 VinTXD,84,[WAIT(CRET),STR FILE1\12 \CRET]
    LCDOUT $FE,1, "5"
    @ Clear2D ; clear the array
    FOR Y = 0 TO Length-1 ; fill the array with data
    FOR X = 0 TO Width-1
    ArrayData =FILE1[X] ; value to put in array
    @ Put2D(X,Y)
    NEXT X
    NEXT Y
    PAUSE 1000
    @ Get2D(X,Y)
    NEXT X
    LCDOUT $FE,1,ArrayData
    NEXT Y
    goto StartDisk
  34. #194
    So you got the new version of PBP?
    Where did you get it?
  35. #195
    Mar 2010
    u use the 2.46version...
    the code i use it like stuck only can run until the code below then stop
    DEFINE OSC 20
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EBIT 4
    DEFINE LCD_RWBIT 6
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_CHARS 20
    X VAR BYTE SYSTEM
    Y VAR BYTE SYSTEM
    Get2D:
    Put2D:
    Clear2D:
    MyArray(Idx) = 0
    NEXT Idx
    Sorry, I have not used arrays like that.
    You may want to go here
    http://www.picbasic.co.uk/forum/showthread.php?t=12870
  37. #197
    Mar 2010
    what array you using? can show it?
  38. #198
    I have shown it several times starting in post#8 of this thread.
  39. #199
    Mar 2010
    using this way of array...if i got 10 file..then need to copy the X1X2 until X120? this way of array i have try it..it simple and easy...if i dunno the pendrive have how many file?
  40. #200
    Nov 2009
    you can try storing storing all the file names that your PIC's array is capable of storing then when your cursor goes down to the last file name, do another serin but this time use the waitstr function and wait for the last file name in your list. you will then receive an new batch or list of file names. You can do this again and again if there are too many file names in your flash drive. As for going up to view the previous files names., you can save the last file name every batch and when you want to get to a specific batch, do a serin and wait for the last file name of the batch before that particular batch where you want to get to. i would advice that you lessen the file names per batch because based on my experience, the pic hangs when for example you are set to receive 8 files but receives only 7 or less. This is just my idea. its not yet complete though.. there are so many other ways to address to the problem of getting all the file names from a flash drive printed in you lcd.
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 12:34
  3. Simple USB Comms Problem
    By awmt102 in forum mel PIC BASIC Pro
    Last Post: - 6th January 2010, 20:17
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 22:40
  5. PICs and USB Flash Drives
    By The Master in forum USB
    Last Post: - 23rd October 2007, 10:23
