18F67J60 circuit for ethernet operation
Results 1 to 4 of 4
    Perth, Australia
    Default 18F67J60 circuit for ethernet operation
    I realise that 18F67J60 dev boards are available to buy, but i've decided to make my own.
    The 18F67J60 data sheet shows this circuit for ethernet operation:
    So far I have:
    - An 18F67J60 soldered to a break-out board with all the required caps and OSC.
    - I butchered an old PCI network card which gave me a handy bit of the circuit ready to use:
    Ive been finding it hard to locate the other components like the odd valued resistors and the ferrite bead. The only places that seems to have these resistor values (at least here in Australia) is wholesalers who want me to order 100 minimum.
    And the data sheet has very little information about what is required for the ferrite bead. In fact, the only specification I can see is that it should be rated for at least 80mA. Does this mean that any ferrite bead above 80mA should be fine? There seems to be ones with lots of different inductances, impedances and frequencies.
    Has anyone had experience with building ethernet circuits that may have some advice?
    "I think fish is nice, but then I think that rain is wet, so who am I to judge?" - Douglas Adams
    Mar 2005
    Iowa, USA
    You might tap Fred Eady for advice. He has posted here before.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Aug 2014
    Default Re: 18F67J60 circuit for ethernet operation
    excuse me. i'm not good english. but i have one question : why The internal analog circuitry in the PHY module requires that an external resistor (2.26 k) be attached from RBIAS to ground. how uses this value
    please help me! (
    Quote Originally Posted by linhepu View Post
    please help me! (
    The resistor influences the TPOUT+/-
    signal amplitude.Read the Data sheet 19.1.4 it tells there.
  1. Circuit Design Question
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 11th August 2009, 08:18
  2. Short circuit portection circuit ?
    By iugmoh in forum Schematics
    Last Post: - 21st December 2008, 21:33
  3. Replies: 11
    Last Post: - 6th November 2008, 10:27
  4. Circuit reliability issues
    By hkpatrice in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2007, 14:55
  5. Replies: 3
    Last Post: - 29th October 2006, 09:16
