OT: KS0108 Graphics LCD control question
Results 1 to 3 of 3
    New England
    Default OT: KS0108 Graphics LCD control question
    Hi all,
    Just a quick question regarding the control of a graphics LCD display using dual KS0108 controllers.
    Is it acceptable to enable both halves of the display and send data / instructions to both controllers at the same time, or should each side be written to separately?
    In writing instructions or graphics such as simple lines, etc - it would take less code to write both sides at the same time - but i don't want to kill the controllers. The data sheets were fairly sparse as far as useful information goes :-(
    Arch
    Feb 2004
    Germany
    I don't know the details of the Display you are using, but:
    as long as you enable both the controllers only when writing to the controller there shouldn't be a problem.
    (I have done this a number of times on dual controller character displays)
    But never try to read from both the controllers at the same time if they are sharing the "Data-Bus"!
    regards
    Ralph
    New England
    Thanks Ralph!
    Great point about reading back data - I had not even thought of that.
    Thanks again,
    Arch
  1. Play with LCD on PICDEM
  2. graphics lcd with lcdout style serial??
    By reaper0995 in forum Serial
    Last Post: - 27th March 2008, 19:57
  3. Need help with LCD number display.
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
