I2C Slave with a PIC - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 130
  1. #81
    Perth, Australia
    It's Proteus VSM, and it's extremely handy.
    My breadboards are all covered in a layer of dust.
    They don't get used much anymore.
    Unfortunately, as I feared, the price is pretty steep.
  2. #82
    That was my initial reaction too.
    But I've since found that it is EXTREMELY inexpensive, if you consider the value vs. cost.
    You can't even buy a decent Digital O-Scope for that much.
    But Proteus gives you Multiple 4ch-DSO's, 32ch-logic analyzers, voltmeters, ammeters, virtual terminals, signal generators, pattern generators, power supplies, I2C debuggers, SPI debuggers, frequency counters ...
    There's a whole boat load of PIC's to choose from, plus all the other chips and discrete parts.
    You can simulate multiple PIC's in the same circuit simultaneously.
    And with PBP 2.60a, it integrates right into the MPLAB IDE for step by step debugging.
    $479 gives you all that and either the 16F's or 18F's.
    Can't get much cheaper than that.
    I should be getting a commission, I sound like a commercial.
    P.S. You can download the Demo Version and run your PBP programs on the sample circuits. You just can't modify the circuit.
        Take a test drive.
    Dec 2007
    Paris
    Would it be possible to easily change one of these example routines to use the MSSP module for I2C Master?
    In my program I change the clock speed from 12MHz to 250kHz, and it takes about 50ms to execute an I2CWRITE command at the slower speed. I measured the I2C clock to be about 800µs which is 1,2kHz... that's not much. I'm guessing that the PBP command includes it's own set of hardcoded delay... I'd like to save power, and if running I2C at 100kHz, I could get the PIC back to sleep 100 time faster.
    I'm understanding quite well changes to make in registers to configure the hardware part, but I must say that when it get to assembler I don't understand too much of it right now...
  4. #84
    Jun 2011
    Philippines
    Default Re: I2C Salve with a PIC
    Hi, I'm interested to try the master-slave(I2C) worked by Daniel and other members, sorry if it is not obvious for me in the code given, but can someone share the schematic used in the example?
    I'm using Pic16877(master) and Pic16F88(salve).
    tacbanon
  5. #85
    Jun 2011
    Philippines
    From the code provided, here is how I interpret the pin connection between pics.
    Master(Pic16F877A) Slave(Pic16F88)
    (SCL)RB5 <---> RB4
    (SDA)RB7 <---> RB1
    but with this connection, LCD displays "Time out", can anyone help me what I'm missing?
  6. #86
    May 2008
    Italy
    Did you pullup SCL and SDA with a 3.3K resistor?
    Cheers
    Al.
  7. #87
    Jun 2011
    Philippines
    Hi aratti,
    Thanks for replying, I added the resistors but I have the same output("Time out" on the lcd). Any idea what causing the issue?
    Thanks in advance,
    tacbanon
    Attachment 6422
  8. #88
    May 2008
    Italy
    You should post the schematic of your setup along with the code you are using. Without more info it is difficult to give you proper answers.
    Al.
  9. #89
    Jun 2011
    Philippines
    Hi again,
    Here is the code I'm using..
    Master pic using Pic16F877A
    ' Master
    'OPTION_REG.7 = 0
    ADCON1 = 7
    DEFINE I2C_SLOW 1
    TRISB.5 = 1
    TRISB.7 = 1
    scl VAR PORTB.5        ' i2c clock input
    sda VAR PORTB.7     ' i2c data input
    I2Caddress VAR BYTE
    valor VAR BYTE
    ' Set LCD Data port
    DEFINE LCD_DREG PORTD
    ' Set starting Data BIT (0 OR 4) IF 4-BIT bus
    DEFINE LCD_DBIT 4
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTC
    ' Set LCD Register Select BIT
    DEFINE LCD_RSBIT 6
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTC
    ' Set LCD Enable BIT
    DEFINE LCD_EBIT 7
    ' Set LCD bus size (4 OR 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines ON LCD
    DEFINE LCD_LINES 2
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 2000
    ' Set Data delay time in us
    DEFINE LCD_DATAUS 50
    Pause 500       ' Wait for LCD to startup
    LCDOut $fe, 1
    LCDOut $fe, "Daniel"
    valor = 0
          I2Caddress = $3
          LCDOut $fe, 1
          LCDOut "Write 1 - LED ON"
          Pause 500
          I2CWrite SDA, SCL, I2Caddress, [6], bogus ' Write offset to slave
          Pause 500
          LCDOut $fe, 1
          LCDOut "Write 1 - LED OFF"
          Pause 500
          I2CWrite SDA, SCL, I2Caddress, [8], bogus ' Write to slave
          Pause 500
          LCDOut $fe, 1
          LCDOut "Reading 1..."
          Pause 500
          I2CRead SDA, SCL, I2Caddress, [valor], bogus ' Read from slave
          LCDOut $fe, 1
          LCDOut "Value1: ", DEC valor
          Pause 500
          I2Caddress = $5
          LCDOut $fe, 1
          LCDOut "Write 2 - LED ON"
          Pause 500
          I2CWrite SDA, SCL, I2Caddress, [4], bogus ' Write to slave
          Pause 500
          LCDOut $fe, 1
          LCDOut "Write 2 - LED OFF"
          Pause 500
          I2CWrite SDA, SCL, I2Caddress, [10], bogus ' Write to slave
          Pause 500
          LCDOut $fe, 1
          LCDOut "Reading 2..."
          Pause 500
          LCDOut $fe, 1
          LCDOut "Value2: ", DEC valor
          Pause 500
          GoTo main       ' Do it forever
    bogus:
            LCDOut $fe,1, "Time out"    ' I2C command timed out
            Pause 500
            GoTo main
    Here is the code for the Slave Pic16F88
    DEFINE OSC 8
    OSCCON = 110001 '8mhz
    CMCON = 7
    ADCON1 = 0 ' Disable A/D converter
    ADCON0 = 0
    ANSEL = 0 ' all analog pins to digital
    '--- tris port config here (don't use SCL & SDA pins other than I2C) ----------
    DEFINE I2C_HOLD 1
    TRISB.1 = 1
    TRISB.4 = 1
    '--- Alias pins ---------------------------------------------------------------
    SDADIR VAR TRISB.1
    SCLDIR VAR TRISB.4
    '--- Define here your variables and alias -------------------------------------
    LEDT VAR PORTA.2
    LEDL VAR PORTB.7
    LEDM VAR PORTB.6
    LEDR VAR PORTB.5
    readcnt VAR BYTE
    datain VAR BYTE
    WrData VAR BYTE
    '--- Define used register flags ------------------------------------------------
    SSPIF               VAR PIR1.3    ' SSP (I2C) interrupt flag
    SSPIE               VAR PIE1.3
    BF                  VAR SSPSTAT.0 ' SSP (I2C) Buffer Full
    R_W                 VAR SSPSTAT.2 ' SSP (I2C) Read/Write
    D_A                 VAR SSPSTAT.5 ' SSP (I2C) Data/Address
    CKP                 VAR SSPCON.4  ' SSP (I2C) SCK Release Control
    SSPEN               VAR SSPCON.5  ' SSP (I2C) Enable
    SSPOV               VAR SSPCON.6  ' SSP (I2C) Receive Overflow Indicator
    WCOL                VAR SSPCON.7  ' SSP (I2C) Write Collision Detect
    STAT_BF             VAR SSPSTAT.0 ' SSP (I2C) Buffer Full
    STAT_RW             VAR SSPSTAT.2 ' SSP (I2C) Read/Write
    STAT_DA             VAR SSPSTAT.5 ' SSP (I2C) Data/Address
    CKE                 VAR SSPSTAT.6 ' SSP (I2C) Data/Address
    '--- Rx Buffer defintion ------------------------------------------------------
    RxBufferLEN         CON 1
    RxBuffer            VAR BYTE[Rxbufferlen]
    RxBufferIndex       VAR BYTE
    '--- Tx Buffer defintion ------------------------------------------------------
    TxBufferLEN         CON 1
    TxBuffer            VAR BYTE[txbufferlen]
    TxBufferIndex       VAR BYTE
    '--- Define constants ---------------------------------------------------------
    I2Caddress          CON $3 ' Make address = 3
    '--- Initialize I2C slave mode ------------------------------------------------
    SCLDIR = 1          ' SCL must be an input before enabling interrupts
    SDADIR = 1
    SSPADD = I2Caddress ' Set our address
    SSPCON = $36        ' Set to I2C slave with 7-bit address
    SSPSTAT = 0
    SSPIE = 1
    SSPIF = 0
    RxBufferIndex = 0
    TxBufferIndex = 0
    '--- Initialization Done! -----------------------------------------------------
    GoTo main
    '--- I2C subroutine  ----------------------------------------------------------
    i2cslave:                                      ' I2C slave subroutine
              SSPIF = 0                            ' Clear interrupt flag
              IF R_W = 1 Then i2crd                ' Read data from us
              IF BF = 0 Then i2cexit               ' Nothing in buffer so exit
              IF D_A = 1 Then i2cwr                ' Data for us (not address)
              IF SSPBUF != I2Caddress Then i2cexit ' Clear the address from the buffer
              readcnt = 0                          ' Mark as first read
              GoTo i2cexit
    i2cwr:                                ' I2C write data to us
           datain = SSPBUF                ' Put buffer data into array
           Rxbuffer[Rxbufferindex]=datain
           Rxbufferindex=rxbufferindex+1
           IF rxbufferindex=RxBufferLEN Then           ' end of buffer transfer
              WrData=1
              rxbufferindex=0
           EndIF
           GoTo i2cexit
    i2crd:                                      ' I2C read data from us
           IF D_A = 0 Then
              TxBufferIndex = 0
           EndIF
           While STAT_BF : Wend                        ' loop while buffer is full
           wcol = 0                                    ' clear collision flag
           SSPBUF = TxBuffer[TxBufferIndex]
           While wcol
                 wcol = 0
           Wend
           CKP = 1                                     ' release clock, allowing read by master
           TxBufferIndex = TxBufferIndex + 1           ' increment index
           IF TxBufferIndex = TxBufferlen Then         ' all bytes have been tx
              TxBufferIndex = 0                           ' reset index
           EndIF
    i2cexit:
    '--- End I2C subroutine  ------------------------------------------------------
          txbuffer = 12
          IF SSPIF = 1 Then
             GoSub i2cslave
          EndIF
          SSPOV = 0
          WCOL = 0
          Select Case RxBuffer[0]
                 Case 6
                         High LEDT
                 Case 8
                         Low LEDT
          End Select
          WrData=0
          GoTo Main
    The codes I'm using is from Daniel(copy and paste).
    BTW I'm using a simulator...
    regards,
    tacbanon
  10. #90
    May 2008
    Italy
    Very likely is a simulator problem!
    Al.
  11. #91
    Jun 2011
    Philippines
    Okay, I will try it in the real hardware(need first to buy Pic16F88), and post here the result. Can anybody in the forum who has Proteus to try to test if similar output I'm having?
    tacbanon
  12. #92
    Jun 2011
    Philippines
    Default Please help me understand how the application works
    Hello,
    While waiting for my Pic16F88(probable by next week) I tried to play with this code below with success in the simulation...
    master(Pic18F2620)
    DEFINE OSC 40
    DEFINE I2C_HOLD 1
    DEFINE LCD_DREG         PORTB
    DEFINE LCD_DBIT         0
    DEFINE LCD_RSREG        PORTB
    DEFINE LCD_RSBIT        4
    DEFINE LCD_EREG         PORTB
    DEFINE LCD_EBIT         5
    DEFINE LCD_BITS         4
    DEFINE LCD_LINES        2
    PAUSE 100
    LCDOUT $FE,1,$FE,2
    ADCON1=001111
    CMCON=000111
    scl             VAR PORTC.3
    sda             VAR PORTC.4
    i2c_address     VAR BYTE
    i2c_data        VAR BYTE[6]
    i2c_address=$02
    I2CREAD sda,scl,i2c_address,[STR i2c_data\6]
    LCDOUT $FE,$80,DEC i2c_data[0]
    LCDOUT " ",    DEC i2c_data[1]
    LCDOUT " ",    DEC i2c_data[2]
    LCDOUT " ",    DEC i2c_data[3]
    LCDOUT " ",    DEC i2c_data[4]
    LCDOUT " ",    DEC i2c_data[5]
    GOTO main
    Slave(Pic18F2620)
    DEFINE OSC 40
    INCLUDE "DT_INTS-18.bas"
    INCLUDE "ReEnterPBP-18.bas"
    ADCON1=001111
    CMCON=000111
    i2c_buffer_full     VAR SSPSTAT.0
    i2c_read            VAR SSPSTAT.2
    i2c_release_scl     VAR SSPCON1.4
    i2c_data_index      VAR BYTE
    dummy               VAR BYTE
    i var byte
    i=1
    SSPADD=$02          ' I2C Address: $0A
    SSPCON1=$36
    SSPCON2.0=1
    i2c_data[0]=6
    i2c_data[1]=5
    i2c_data[2]=4
    i2c_data[3]=3
    i2c_data[4]=2
    i2c_data[5]=1
    i2c_data_index=0
    INT_LIST  macro
            INT_Handler SSP_INT, _i2c_int_handler, PBP, yes
        INT_CREATE
        INT_ENABLE SSP_INT
    endasm
    i2c_int_handler:
    IF i2c_read then
        dummy=SSPBUF
        IF i2c_buffer_full=0 THEN
            SSPBUF=i2c_data[i2c_data_index]
            i2c_data_index=i2c_data_index+1
            IF i2c_data_index=6 THEN i2c_data_index=0
    i2c_release_scl=1
    @ INT_RETURN
    As I understood, in the master pic the code below tries to communicate to the Slave having the address $02
    i2c_address=$02
    and display data from Slave to the Master pic LCD. Then I tried to modify the setup and add another Slave#2 with address $0B like the this code below..
    i2c_address=$02
    PAUSE 1000
    LCDOUT 254,1
    i2c_address=$0B
    PAUSE 1000
    GOTO main
    What I get is "6 5 4 3 2 1" and "0 0 0 0 0 0 " should be "1 2 3 4 5 6" for Slave#2
    Slave#2
    DEFINE OSC 40
    ADCON1=001111
    CMCON=000111
    dummy               VAR BYTE
    i var byte
    i=1
    SSPADD=$0B          ' I2C Address: $0B
    SSPCON1=$36
    SSPCON2.0=1
    i2c_data[0]=1
    i2c_data[1]=2
    i2c_data[2]=3
    i2c_data[3]=4
    i2c_data[4]=5
    i2c_data[5]=6
    i2c_data_index=0
    INT_LIST  macro
        INT_CREATE
        INT_ENABLE SSP_INT
    endasm
    i2c_int_handler:
    IF i2c_read then
        dummy=SSPBUF
    i2c_release_scl=1
    @ INT_RETURN
    I was only hoping that it would work that way(I guess not ), how can I add another Slave and get data from it? I appreciate any help and the time for sharing.
    Thanks in advance,
    tacbanon
  13. #93
    Default Re: Please help me understand how the application works
    In your previous code with the F88, 3 is not a valid I2C address.
    In the current code, $B is not a valid I2C address.
    They should be a multiple of 2.
    Bit 0 is reserved for the R/W bit.
    Jun 2011
    Philippines
    Hi Darrel,
    Thanks for replying, I did some testing on 1Master and 1Slave with these address($02,$04,$06,$08,$10,$12,$14) and works fine. But when I trying to add Slave #2 I get "0 0 0 0 0 0". It only reads on the Slave #1 correct (displays "1 2 3 4 5 6").
    This is how I code to read the 2nd Slave.
    DEFINE OSC 40
    DEFINE I2C_HOLD 1
    DEFINE LCD_DBIT         0
    DEFINE LCD_RSBIT        4
    DEFINE LCD_EBIT         5
    DEFINE LCD_BITS         4
    DEFINE LCD_LINES        2
    PAUSE 100
    LCDOUT $FE,1,$FE,2
    ADCON1=001111
    CMCON=000111
    scl             VAR PORTC.3
    sda             VAR PORTC.4
    i2c_address2     VAR BYTE
    i2c_data2       VAR BYTE[6]
    i2c_address=$10
    pause 200
    LCDOUT $FE,$80,"1> ",DEC i2c_data[0]
    PAUSE 500
    LCDOUT $FE,1
    i2c_address2=$14
    pause 200
    I2CREAD sda,scl,i2c_address2,[STR i2c_data2\6]
    LCDOUT $FE,$80,"2> ",DEC i2c_data2[0]
    LCDOUT " ",    DEC i2c_data2[1]
    LCDOUT " ",    DEC i2c_data2[2]
    LCDOUT " ",    DEC i2c_data2[3]
    LCDOUT " ",    DEC i2c_data2[4]
    LCDOUT " ",    DEC i2c_data2[5]
    PAUSE 500
    LCDOUT $FE,1
    GOTO main
    BTW the code for Slave1 and Slave2 are identical (Slave#1 is address $10 and Slave#2 is address $14)
    What I'm doing wrong in the code? I appreciate very much your help.
    Tacbanon
  15. #95
    If you comment out the first I2CREAD, is it able to read from the second slave?
    If you change the order so that it reads the second slave first, is it then unable to read the first slave?
    Jun 2011
    Philippines
    Yes it is able to read.
    Nope, displays "0 0 0 0 0 0" for first Slave, 2nd Slave shows "6 5 4 3 2 1"
  17. #97
    It sounds like a buffer overflow.
    ... bad comment deleted ... duh!!
    If you post or email your .DSN, I'll take a closer look.
    Jun 2011
    Philippines
    Thanks Darrel, oh sorry to ask this, but how do I send a winrar file?
  19. #99
  20. #100
    Jun 2011
    Philippines
    Thanks mister_e
  21. #101
    Or you can stuff it in a ZIP file and post it here. The forum accepts ZIPs as attachments.
    Some RAR programs can also save as ZIP format.
    Jun 2011
    Philippines
    Thanks for the info Robert...
    and here is the zip file.
    tacbanon
  23. #103
    Jun 2011
    Philippines
    Oops here are the codes I'm using for the master, Slave1 and Slave 2.
    Thanks for the files tacbanon.
    Well, this code for the slaves will allow it to read from both devices.
        IF SSPCON1.6 THEN SSPCON1.6 = 0
    i2c_int_handler:
        IF i2c_read then
                dummy = SSPBUF
            i2c_data_index=0
        i2c_release_scl=1
    @ INT_RETURN
    But it's still not right. And is not a complete slave.
    According to AN734 there are 5 states to maintain. 6 including the ERROR state.
    Your original code only handles 1 state, and this modification only does 2 states.
    I think by adding the other 4 states, it will get rid of the buffer overflows, but I'm not absolutely sure.
    I'm going to convert AN734 state machine to PBP and see what happens.
    May take me awhile.
    Jun 2011
    Philippines
    Thank you for the code, and thanks in advance DT for your valuable time...looking forward for the end result(I wish and pray that things goes well). I've been reading about I2C on net, trying to understand and the applications that might be done(particularly on Master-(multi-Slave/Multi-master)) are very interesting...
    tacbanon
  26. #106
    Sep 2005
    Campbell, CA
    Although my slave example may not be as robust as AN734, I have systems running that have 14 slaves running. All 14 slaves are polled on 2 second intervals. The master uses bit-banging (I2CWrite). I have never had trouble with the code below. I have tested it with -
    18F8723, 18F2221, 18F2321, 18F2523 and had excellent results.
    '*  Name    : I2C slave                                         *
    '*  Author  : Charles Linquist                                  *
    '*  Notice  : Copyright (c) 2010 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 10/20/2010                                        *
    '*  Notes   : Transmits 100 bytes in ~14 ms (Master SEND)       *
    '*          : Recives 100 bytes in ~12 ms (Master RECEIVE)      *
    '*          : Could possibly go faster.  Master used for  the   *
    '*          : test used bit-banging (I2CREAD/I2CWRITE           *
    '*          : settings on that end were                         *
    '*          :  DEFINE I2C_SLOW 1 ,DEFINE I2C_HOLD 1             *
        ifndef __18F2221
            error "18F2221 not selected"
           movlw 0x62                              ; %0110 0010  = 4 Mhz, internal osc block
           movwf OSCCON
           movlw 0x80                              ; %1000 0000  = PLL disabled
           movwf OSCTUNE
            DATA @0,0      ; programming flag
            DEFINE NO_CLRWDT 1                                                      ' Don't waste cycles clearing WDT
            Define USE_LFSR 1
            define USE_LOWPRIORITY 1
    ;---------------- Alias the bits ------------------------------------
        SSPIE               VAR PIE1.3    ' Int Enable
        SSPUA               VAR SSPSTAT.1
        SSPS                VAR SSPSTAT.3
        SSPP                VAR SSPSTAT.4
        SSPSMP              VAR SSPSTAT.7
        CKP                 VAR SSPCON1.4  ' SSP (I2C) SCK Release Control
        SSPEN               VAR SSPCON1.5  ' SSP (I2C) Enable
        SSPOV               VAR SSPCON1.6  ' SSP (I2C) Receive Overflow Indicator
        WCOL                VAR SSPCON1.7  ' SSP (I2C) Write Collision Detect
        GENCALL             VAR SSPCON2.7  ' General Call enabled
        MainTimer           var word bankA System
        I2CTimer            var word bankA System
        I2CTimerGate        var byte bankA System
        I2CErr              var byte bankA System
    ;Alias pins
        SCL     VAR     PORTC.3         ' I2C clock input
        SDA     VAR     PORTC.4         ' I2C data input
        LED     VAR     PORTB.5
    '------------------- Rx Buffer defintion --------------------
        RxBufferLEN         con 10
        RxBuffer            var BYTE[Rxbufferlen + 1]
        TxBufferLEN         CON 10
        TXBuffer            VAR BYTE[TxBufferLEN + 2]
        InBuff              VAR BYTE
        GeneralCall         VAR BIT
        RXBufferOverFlow    VAR BIT
        TxBufferUnderFlow   VAR BIT
        RXBufferPointer     VAR Byte
        TXBufferPointer     VAR Byte
        address             VAR BYTE
        x                   VAR BYTE
        dummy               var byte
        I2CAddress          VAR BYTE
        WCOLCounter         VAR BYTE
        TXBuffer[TxBufferLen + 1] = $FF  ; Char to send if requestor asks for too much.
        I2CDeviceAddress    VAR BYTE
        I2CMajorAddress     CON $3
        I2CDeviceAddress =  $8
        I2CAddress = (I2CMajorAddress <<4) | I2CDeviceAddress
        SSPCON2.0 = 1      ; Stretch the clock
        SSPSTAT = 0
        SSPEN = 1
        SSPIE = 1
        SSPIF = 0
        GenCall = 1           ; Turn general call on
        SSPCON2.7 = 1         ' General call address ENABLED
        SSPCON1 = $36    ' Set to I2C slave with 7-bit address
        TRISA = %11111111
        TRISB = %11011111
        TRISC = %11111111
    ' -------------- Turn on Ints  ------------------------
        INTCON.7 = 1  ; global ints
        INTCON.6 = 1  ; peripheral ints
    ;------------------  Clear parameters --------------
        RXBufferPointer = 0
        TxBufferPointer = 0
        GeneralCall = 0
        RxBufferOverFlow = 0
        TXBufferUnderFlow = 0
        WCOLCounter = 0
    INCLUDE "DT_INTS-18.bas"    ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ' Use PBP interrupts
    include "ReEnterPBP-18LP.bas"
    INT_LIST  macro    ; IntSource,         Label,  Type, ResetFlag?
            INT_Handler    TMR0_INT, TimerInt,    ASM,  yes
    INT_LIST_L  macro    ; IntSource,        Label,  Type, ResetFlag?
         INT_Handler    SSP_INT,  _I2C_Int,   PBP,  yes
         INT_CREATE_L               ; Creates the LP interrupt processor
    endasm
    ''----------------- Initialization Done! -----------------------------
        Goto OverInt ; jump over ISR
    asm
    TimerInt
          infsnz MainTimer
          incf   MainTimer + 1
          btfsc  I2CTimerGate,0        ; Don't count if low bit is clr
          incf   I2CTimer
          btfss  I2CTimer,2            ; Bit 2 is set , we have at least 4 counts, we must be hung
          bra    NoProb
          bcf    PIR1,3                ; Clear Int flag
          bcf    SSPCON1,5             ; Stop the
          bsf    SSPCON1,5
          bsf    I2CErr,0
          clrf   I2CTimer
    NoProb
          bcf INTCON,2
          INT_RETURN
    endasm
    '------------------------- I2C subroutine  --------------------------------
    I2C_Int:
      ; We don't get here uless someone has matched our address register.
    @ bsf I2CTimerGate,0    ; start the counter
    If R_W = 0 then             'This is a WRITE by the master to us
        IF BF = 0 Then goto i2CEXIT   ; Nothing for us!
        if D_A = 0 then         'We have an address
          address = SSPBUF     'Need to READ to satisfy Microchip
           IF Address = 0 THEN
               GeneralCall = 1
               GeneralCall = 0
            IF WCOL OR SSPOV THEN I2CExit
              RXBuffer [RxBufferPointer] = SSPBuf   ;
              RxBufferPointer = RXBufferPointer + 1
              IF RXBufferPointer > RxBufferLen  THEN
                    RXBufferOverFlow = 1
                    RXBufferPointer = 0
        else   ' R_W = 1 Master wants to read FROM us
              IF !D_A Then
                    TxBufferPointer = 0  ' Mark as first read
                    RXBufferPointer = 0
              EndIF
              IF CKP THEN I2CExit
                  dummy = SSPBUF  ;NECESSARY!
              If TXBufferPointer < TxbufferLen THEN
    SENDI2C:
                  WCOL = 0
                      SSPBUF = TXBuffer[TXBufferPointer] ' Get data from array
                       IF WCOL THEN
                           WCOLCounter = WCOLCounter + 1            ; Don't hang the bus with infinite WRITES!
                           IF WColCounter = 0 Then goto I2CExit     ; Rolled over
                          Goto SendI2C       ; Rety
                           WColCounter = 0
                       TXBufferPointer = TXBufferPointer +1
                       TXBufferPointer  = TXBufferPointer MIN TXBufferLen + 1 ; Don't let it get larger than this
                       ; Send FFs if requestor asks for too much data
                      TXBufferPointer = 0
                      TXBufferUnderflow = 1
    I2CEXIT:
    Asm
        bcf SSPCON1,6
        bcf SSPSTAT,0
        bcf PIR1,3
        bsf SSPCON1,4
        bcf I2CTimerGate,0      ; stop the counter
        INT_ENABLE SSP_INT      ; probably don't need this, but want to make certain it gets reenabled
        INT_RETURN
    endasm
    ' -------------------------end I2C subroutine  --------------------------------
    '--------------------[ main program loop]---------------------------------------
    OverInt:
    Asm
       clrf MainTimer
       clrf I2CTimer
       bcf INTCON,2
       bcf PIR1,3  ; Clear the I2C flag before we turn on the INT.
       movlw 0x83
       movf T0CON
       INT_ENABLE  SSP_INT
       INT_ENABLE TMR0_INT
    endasm
    MAIN PROGRAM LOOP GOES HERE!
    Charles Linquist
  27. #107
    Jun 2011
    Philippines
    Hi Charles, thanks for sharing..I will try it out..
    tacbanon
  28. #108
    Jun 2011
    Philippines
    @Charles
    Sorry I was not able to make it work on my setup..I'm not really sure what the following code is doing, so I tried to comment it and assign a value, but no effect.
    'I2CAddress = (I2CMajorAddress <<4) | I2CDeviceAddress
    I2CAddress =$14
    I hope it will be alright if you share the master side code?
    tacbanon
  29. #109
    At this point, I'm thinking Al (aratti) was right.
    AN734 didn't work either.
    Bytes are being put in the SSPBUF without an address match.
    So the slaves that aren't being accessed are overflowing during reads from other devices.
    The code I gave earlier works because it's resetting the overflow in the main loop, but that's just not right.
    I'm trying to get some more info from Labcenter.
    Sep 2005
    Campbell, CA
    I am using a slight variant of the code I posted, and it is working fine. The only major change is that I'm sending a packet length byte, and I'm handling the entire receive packet inside the ISR. This is safe because I have my ( higher priority) timer interrupt watching over the whole process.
    Charles Linquist
  31. #111
    Jun 2011
    Philippines
    Just want to ask if anyone tried to extend say 50meters communication between master and slave using I2C bus extender P82B715PN or similar?
    tacbanon
  32. #112
    tacbannon,
    The problem with Proteus and multiple I2C slaves has been fixed by Labcenter.
    If you update Proteus to 7.10 SP1, you should have better luck.
    Jun 2011
    Philippines
    @ DT, Thanks for the update..I will find time to play with it(I2C multiple slaves) this weekend(so many work, little time to play )
    Kind regards,
    tacbanon
  34. #114
    Nov 2008
    Hi all,
    for info to all: I have the code from Aretti here on a 18F25K22, works fine with one slave on one master. When i connect more slaves (up to 31) i get the effect that a NACK comes right behind the address, the SDA line is high during the 9th clock cycle... my bus is about 70cm long (long backplane) and i use a 3.3k on the i2c bus. It seems that this "NACK" effect is coming sporadic, does someone tried to do the same like me?
    Ralf
  35. #115
    Nov 2008
    Hi again,
    found the bug: the bus i am using is splitted in two 2 x 25cm long busses which is not the best solution. Sometimes because of layout reasons it must be done this way. In this case two 100 Ohm resistors close to the Master in series with SDA and SCL and pullup's 2 x 10kOhm at both ends of the splittet bus make the bus working fine. I checked the timing with a logic analyser and the quality of the signals with a scope, both ok, no glitches or other dirty effects. Hope this help others having same trouble. I must say best solution is always making the bus from one end to the other end in one direction, i tested this also with 80cm. Adding also two 100 Ohm resitors in series with SDA and SCL close to the master makes the signal quality better also.
    Both versions run with 80kHz very fine now.
    Ralf
  36. #116
    Jan 2014
    Excuse me for my English.
    How can I send data from a PIC 16F876 to four slaves
    using the I2C bus protocol, with the same address?
    Could you help me, a piece of code would be welcome!
    mimie64.
  37. #117
    Jun 2009
    Sc*nthorpe, UK
    I2C bus protocol requires unique addresses for each slave. Just code the address into each slave if you are building the slaves yourself of course.
  38. #118
    Feb 2007
    Thanks to all of you for your greath wok!
    ... just to avoid to have trouble in future and have a clear view of a new project, I have in plan to use the slave routine on almost 12 PIC of 18F2550 and one Master with 18F4550.
    The idea is that:
    I shall have the Master far from the first slaves at about two to three meters and the second slave is far from the first slave around 50 cm, and all other slaves are distanced 50 cm between them.
    At the end the total length shall be more than 10 meters. but less that 12 meters.
    Also, I would use the RJ45 connectors to make interconnection between the PCBs and use the preassembled CAT5 Ethernet patch cable to carry the supply voltage from the Master to the slaves.
    I have thinked to put on pin 1, 2 and 3 the VCC, on pin 4 the Clk, on pin 5 the Dat and on pin 6. 7 and 8 the GND?
    The lenght of the cables can be a problem?
    The idea to use the RJ45 with the CAT5 patch cable is good?
    Leo
    Leo
  39. #119
    Default Re: I2C Slave with a PIC
    WIKI I2C
    The maximum number of nodes is limited by the address space, and also by the total bus capacitance of 400 pF, which restricts practical communication distances to a few meters.
    CAT5 CAPACITANCE
    52pF / metre
    cat5 balanced cable / i2c unbalanced signal.
    cat5 characteristic impedence of 100 ohms is probably a big load for the i2c pins also.
    its not a good match , and won't go far
  40. #120
    Aug 2011
    A regular CAT5 RJ45 has 4 twisted pairs, but they're not "in order"
    1,2 orange,orange/wht
    3,6 green,green/wht
    4,5 blue,blue/wht
    7,8 brown,brown/wht
    I'd pair the SDA and SCL signals each with a GND (ie 1=GND, 2=SDA, and 7=SCL, 8=GND) and use the others for PWR/GND.
    10 meters is a long way for a single-ended TTL level signal. They make I2C bus extenders for this sort of thing.
  1. Problem with PICto PIC I2C MASTER-SLAVE
    By juanen19 in forum mel PIC BASIC Pro
    Last Post: - 11th June 2013, 02:58
  2. PIC as I2C Slave
    By Mainul in forum General
    Last Post: - 5th January 2013, 13:23
  3. I2C Slave, config Vref - + in pic with ADC
    By sebapostigo in forum PBP Wish List
    Last Post: - 5th March 2007, 03:21
  4. Pic as an i2c slave
    By Robert Soubie in forum mel PIC BASIC Pro
    Last Post: - 25th January 2007, 21:11
  5. Use pic as slave in I2C
    By robert0 in forum General
    Last Post: - 3rd February 2006, 19:26
Members who have read this thread : 5
