+ Reply to Thread
Results 1 to 7 of 7
Thread: Auto reset MCLR
    Sep 2005
    France
    Default Auto reset MCLR
    I would like to use a bootloader (mikroE) on my PCB (18f45k22) over my serial RF connection (433MHz). To distant upgrade my pic. (I'm using PBP2.60)
    The bootloader works like this:
    Put the Mclr Low then I have 2 seconds to upload my new firmware or my program is starting.
    As my program use Usart, I would like to send my pic a command to put it's own MCLR low...
    But I have no idea how to do it...
    May be using another pic in // RX and doing the job ? or my 18f45k22 could do the job itself ?
    Thanks for ideas.
    Default Re: Auto reset MCLR
    If you have a spare I/O then you could have the PIC pull its own MCLR down. Or, perhaps you can use the watchdog timer to "force" a reset.
    Sep 2005
    France
    Henrik,
    I tried (simulation) with one Output of my PIC but it doesn't work. Pic doesn't restart... May be it's because simulation ? Actually it works when my pic trig a 555 in monostable (output of 555 trig a mosfet connected to MCLR)
    May be I have to try in real life ?
    regards
    I don't see how it could NOT work. MCLR is pulled up thru the normal resistor and also connected to a normal I/O.
    When that I/O is set LOW it'll pull MCLR low which will reset the PIC. As soon as that happens the TRIS bit for the IO will be set which makes the pin high Z which releases MCLR.
    Try it with real hardware and let us know.
    It wouldn't be the first time a simulator got it wrong but I'll gladly stand corrected if the simulator is right.
    /Henrik
    Quote Originally Posted by harryweb View Post
    Thanks for ideas.
    Don't the 18F series have a software reset command ???
    4.0 RESET
    The PIC18(L)F2X/4XK22 devices differentiate between
    various kinds of Reset:
    a) Power-on Reset (POR)
    b) MCLR Reset during normal operation
    c) MCLR Reset during power-managed modes
    d) Watchdog Timer (WDT) Reset (during
    execution)
    e) Programmable Brown-out Reset (BOR)
    f) RESET Instruction
    g) Stack Full Reset
    h) Stack Underflow Reset
    see Datasheet : DS41412D-page 397
    Don't the 18F series have a software reset command?
    Yes, but not knowing the bootloader it's possible that it might not work since it can tell the difference. That's unlikely, though.
    What Henrik proposed works. Once again, the simulator lies.
    Aug 2003
    Australia
    There is some benefit to timing out the watchdog in that some variables are not reset by it.
    If you aren’t using a timer, you could use a timer value as a flag to tell the program what to do the next time is starts, so long as power isn’t lost.
    ie. a button could be pressed at any time to restart into the boot loader.
  1. Auto Pilot
    By PlantBob in forum mel PIC BASIC Pro
    Last Post: - 28th May 2012, 19:43
  2. Replies: 12
    Last Post: - 7th May 2012, 18:25
  3. External Reset for MCLR
    By gavo in forum mel PIC BASIC Pro
    Last Post: - 20th September 2010, 21:56
  4. Auto Downloads
    Last Post: - 16th November 2004, 19:21
  5. auto advance
    By c_Moore in forum General
    Last Post: - 31st October 2004, 12:20
Members who have read this thread : 26
