Need to drive 40 pins on variable change, is there a way to do it in elegant way?
+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 40 of 97
    Default Need to drive 40 pins on variable change, is there a way to do it in elegant way?
    Hello.
    I'm building a nixie clock, which does not uses any specific decoder ICs or multiplexer. Instead, all nixie digits are connected to individual MCU pins via transistors. It uses DS1302 as clock source. Time received from DS1302 is converted into single number in 24 hour format, for example, it time is 15:53, this number will read as 1553. Using DIG statement I'm extracting individual digits from it, so I have 4 variables, called T1-T4, which have data for individual number to be displayed on specific digit. The pin numbers to which nixies are connected are aliases in the following way - A0-A9 for numbers in 1st digit, B0-B9 for numbers in 2nd digit, C0-C9 and D0-D9 for 3rd and 4th digits correspondingly. So now, to display time, I need to run the following code:
    IF T1=0 THEN A0=1
    IF T1=1 THEN A1=1
    IF T1=2 THEN A2=1
    IF T1=3 THEN A3=1
    IF T1=4 THEN A4=1
    and so on, total, 40 lines (not shown is code for extinguishing all non-used numbers, but I'm doing it at same time for all digits)
    So question is, is there a way to avoid all these if-then lines and do it somehow in more elegant way?
    Thanks in advance!
    Jan 2006
    Istanbul
    Default Re: Need to drive 40 pins on variable change, is there a way to do it in elegant way?
    Arrays?
    A_Vals var word(4) 'A0-A9, B0-B9, C0-C9, D0-D9 in each element;
    T_Vals var byte(4) 'T1-T4
    i var byte
    Tx var byte
    Xx var word
    Begin:
        for i = 0 to 3      ' Clear array.
            A_Vals(i) = 0
            T_Vals(i) = 0
        next i
    Start:
        for i = 0 to 3  ' Scan 0-3 => T1-T4
            Tx = T_Vals(i)   ' Get the value of Tx variable.
            Xx = A_Vals(i)   ' Get the value of Ax value.
            Xx[Tx]= 1        ' Change Ax value based on Tx value.
            A_Vals(i)=Xx     ' Get the value back.
        next i
        goto start
    ' Now you have all your pins masked in array A_Vals;
    ' A0 => A_Vals(0) bit.0-bit.9
    ' A4 => A_Vals(3) bit.0-bit.9
    ' you have to read them back from A_Vals, and assign your corresponding pins on its bits 0-9.
    ' For example,
    ' xx = A_Vals(0)
    ' A0 = ax.0(0)
    ' A9 = ax.0(8)
    ' xx = A_Vals(3)
    ' B0 = ax.0(0)
    ' B9 = ax.0(8)
    How about a lookup table, 5 bytes (40 bits) wide and 10 deep (0-9).
    George
    Yes, table would be nice, but how to do with less iF-THEN ?
    Here is a routine I wrote for my 6 digit nixie clock using 2 each HV5530P high voltage shift registers. That's 64 bits.
    I use a 16F1825 14 pin processor running @ 10 Mhz. I don't like to use all of that hardware....
    HVCLK VAR LATC.0 '0-SHIFT REGISTER CLOCK
    HVSTB VAR LATC.1 '0-SHIFT REGISTER STROBE
    HVDAT VAR LATC.2 '0-SHIFT REGISTER DATA
    CLOCKIT: 'ENCODE OUTPUT SEQUENCE AND SEND TO SHIFT REGISTER W/COLLONS
    '------------------------ 64 BIT ENCODE SEQUENCE ------------------------
    '9876543210,9876543210,cc,9876543210,9876543210,cc ,9876543210,9876543210
    '10's HOURs,1's HOURs ,::,10's MIN's,1's MIN's ,::,10'S SEC's,1'S SEC's
    JUNK = 7 'FIRST CLEAR THE OUTPUT ARRAY
    WHILE JUNK < 255
    OUTPUTS(JUNK) = 0
    JUNK = JUNK - 1
    WEND
    JUNK = 0 'NEXT SET THE OUTPUT ARRAY
    WHILE JUNK < 6 'CYCLE THRU ALL 6 DIGITS TO DISPLAY
    PATDOG = 1 'FEED THE DOG
    SELECT CASE JUNK
    CASE 0 'UNIT SECONDS 'BIT POSITION
    OUTPUTS.0((JUNK * 10) + (SECONDS DIG 0)) = 1 '0-9
    CASE 1 'TEN'S OF SECONDS
    OUTPUTS.0((JUNK * 10) + (SECONDS DIG 1)) = 1 '10-19
    OUTPUTS.0((JUNK * 10) + 10) = MINSECCOL '20
    OUTPUTS.0((JUNK * 10) + 11) = MINSECCOL '21
    CASE 2 'UNIT MINUTES
    OUTPUTS.0((JUNK * 10) + 2 + (MINUTES DIG 0)) = 1 '22-31
    CASE 3 'TEN'S OF MINUTES
    OUTPUTS.0((JUNK * 10) + 2 + (MINUTES DIG 1)) = 1 '32-41
    OUTPUTS.0((JUNK * 10) + 12) = HOURMINCOL '42
    OUTPUTS.0((JUNK * 10) + 13) = HOURMINCOL '43
    CASE 4 'UNIT HOURS
    OUTPUTS.0((JUNK * 10) + 4 + (HOURS DIG 0)) = 1 '44-53
    CASE 5 'TEN'S OF HOURS
    'DISPLAY 10'S OF HOURS IF THERE IS SOMETHING TO DISPLAY
    IF HOURS DIG 1 <> 0 THEN 'IF THERE IS A DIGIT TO DISPLAY
    OUTPUTS.0((JUNK * 10) + 4 + (HOURS DIG 1)) = 1 '54-63
    END SELECT
    JUNK = JUNK + 1
    WEND
    SHIFTOUT HVDAT,HVCLK,MSBFIRST,[OUTPUTS(7)\8,OUTPUTS(6)\8,OUTPUTS(5)\8,OUTPUTS(4)\ 8,OUTPUTS(3)\8,OUTPUTS(2)\8,OUTPUTS(1)\8,OUTPUTS(0 )\8]
    PULSOUT HVSTB,PULSE
    EN82fn
    Apr 2011
    Portland, Oregon
    I typically use DATA statements (simple with internal EEPROM) to map each 7 segment character in a byte value. 'A' segment is least significant digit, 'G' segment is bit 6. Bit 7 is unused. For example, the number 8 is %01111111 (all segments on), 1 is %00000011, etc. I then read the bit value and write it to a port or series of pins. If you store the digits in the corresponding memory location, you may simply READ [DIGIT VALUE + 1] to retrieve the segment code.
    Sep 2009
    Single Nixie tube need 10 pin from micro. It's not 7 segment display. And only 1 pin need to te activated at time.
    So most of suggestion wont work.
    Unfortunately you need 40 statements to set pins. eg
    IF T1=0 THEN
    A0=1
    A0=0
    By time you write first post you could write 40 IF statements without any problem.
    That way you probably get smallest program size.
    If your ports and pins are consecutively mapped ie
    MAP
    PORTC   PORTD   PORTE   PORTF   PORTG
    0127456701234567012345670123456701234567
    DIG0     DIG1      DIG0    DIG3
    just clear ports the set like this
    ;DIGO
    PORTC.0[BIN VALUE OF DIGO]=1
    ;DIG1
    PORTC.0[BIN VALUE OF DIG1+10]=1
    ;DIG2
    PORTC.0[BIN VALUE OF DIG2+20]=1
    ;DIG3
    PORTC.0[BIN VALUE OF DIG3+30]=1
    I already wrote code with if-then-else, and it works fine, just wanted to make it more nice and tidy.
    regarding port mapping, ports are 8 bit wide, but nixies are 10 bit, so that way won't work also....
    look again
    Apr 2011
    Portland, Oregon
    If you are building a clock, the minutes digits never exceed 60 - you require 10 digits for the "ones" (0 - 9), but only 6 for the "tens" (0 - 5). So, it will be possible to map every possible minute on two ports or, in one word value. By writing in DATA statements the "ON" pattern for each possible minute, the DATA statements become a lookup table. For example at XX:34, the 70th DATA position (2 positions for each WORD value and allowing for "Zero" and 1 base offset ) contains the bit code (across two bytes) to turn on the 3 and the 4 on the relevant PORTs. Write the high byte to PORTB, the low to PORTA (or whatever). Of course some minutes - say 59 will be fully contained in the upper byte: 10000010_00000000 -because the two low order bits of the high byte are conscripted for the 9 and 0.
    The Hours portion may be handled similarly. As before, you will use ten pins for the "ones" in the hours, but only - at most - three in the "tens" digit (0 - 1 - 2) . Place these values subsequent to the previous.
    To retrieve the "minutes" value READ CURRENTMINUTE * 2 + 2, MIN_VAR. For hours, READ 122 + (CURRENTHOUR * 2), HOUR_VAR. The offset values are figures in my head and may require adjustment.
    This method requires only two word variables - one for the minute value, one for the hour value and 144 - 168 EEPROM bytes. In truth, the values are easily calculated and it may be you determine only to calculate the bit value rather than store it.
    amoque's suggestion makes good sense
    my map would become [note can be any 4 consecutive ports][can start at any bit too]
    ;DIGO
    ;DIG1
    ;DIG2
    PORTC.0[BIN VALUE OF DIG2+17]=1
    ;DIG3
    PORTC.0[BIN VALUE OF DIG3+27]=1
    Apr 2011
    Portland, Oregon
    If DIG0 is "ones" digit of minutes, and DIG1 is "tens" digit, then:
    READ [MINUTEVALUE + 1], WORD WordVar
    PORTC = WordVar.lowbyte
    PORTD = WordVar.HighByte
    In fact, you could then:
    READ [HOURVALUE + 1], WORD Wordvar
    PORTE = WordVar.lowbyte
    PORTF = WordVar.HighByte
    This would overwrite F.6..7, but if you aren't using them...
    ' BIT CODE OF "00", BIT CODE OF "01", BIT CODE OF "02"...
    DATA %00000100_00000001, %00000100_00000010, %00000100_00000100,
    Will set PORTC.0 and PORTD.2 HIGH (presumably turning on the "0" digit in both positions. It may be your transistors are active low and would therefore require the inverse bit values (%11111011_11111110). WARNING: I did NOT look up the specific syntax of the READ and DATA statements, you should verify these.
    IF you do it my way, assuming HOUR,MINUTE are bcd byte values read from a rtc
    GOSUB SETDISPLAY
    LATC=0
    LATD=0
    LATE=0
    LATF=0
    LATC.0[MINUTE&$0F]=1
    LATC.0[(MINUTE>>4)+10]=1
    LATC.0[HOUR&$0F)+17]=1
    LATC.0[(HOUR>>4)+27]=1
    thats it job done
    Jan 2006
    Istanbul
    It seems that nobody paid attention to my routine.
    i looked but failed to :-
    1 understand how to feed the time from say two bcd encoded bytes into it
    2 how it maps the resultant data onto the pins
    perhaps you could explain more fully and develop the process a bit further
    naming the var more meaningfully helps , i know when i'm deep in a pgm at the time its easy to see the big picture and keep track
    but when i come back at a later time i wonder what was i doing here and why, i often wish i named things better with more comments
    Actually, for the number of digits:
    Tens of hours n: 0 1 2 - 3 pins
    Ones of hours: 0 1 2 3 4 5 6 7 8 9 - 10 pins
    Tens of minutes: 0 1 2 3 4 5 - 6 pins
    Ones of minutes: 0 1 2 3 4 5 6 7 8 9 - 10 pins
    Single pin is needed for blinking middle dot.
    So we have 3+10+6+10+1=30 pins. But I can't map them sequentially, due to pcb and other assembly restrictions. Currently say "4" in tens of minutes is PORTB.2, but "5" is PORTC.4 and so on
    Jan 2006
    Istanbul
    ' These epins are just example pins.
    ' Pin number can be in any order; does not have to be in a sequence.
    A0 var PORTA.0
    A1 var PORTB.0
    A2 var PORTC.0
    A3 var PORTD.0
    A4 var PORTE.0
    A5 var PORTF.0
    A6 var PORTA.0
    A7 var PORTA.0
    A8 var PORTA.0
    A9 var PORTA.0
    B0 var PORTA.0
    B1 var PORTD.0
    B2 var PORTC.0
    B3 var PORTE.0
    B4 var PORTG.0
    B5 var PORTB.0
    B6 var PORTB.0
    B7 var PORTB.0
    B8 var PORTB.0
    B9 var PORTB.0
    C0 var PORTB.0
    C1 var PORTF.0
    C2 var PORTD.0
    C3 var PORTE.0
    C4 var PORTC.0
    C5 var PORTC.0
    C6 var PORTC.0
    C7 var PORTC.0
    C8 var PORTC.0
    C9 var PORTC.0
    D0 var PORTE.0
    D1 var PORTF.0
    D2 var PORTH.0
    D3 var PORTA.0
    D4 var PORTB.0
    D5 var PORTC.0
    D6 var PORTD.0
    D7 var PORTD.0
    D8 var PORTD.0
    D9 var PORTD.0
    i var byte
    Tx var byte
    Xx var word
    '===== These are your T Vals ========
    '=== Use them in your code, and assign the values to them.
    T1 var T_Vals(0)
    T2 var T_Vals(1)
    T3 var T_Vals(2)
    T4 var T_Vals(3)
    AVal var A_Vals(0)
    BVal var A_Vals(1)
    CVal var A_Vals(2)
    DVal var A_Vals(3)
    Begin:
            A_Vals(i) = 0
            T_Vals(i) = 0
        next i
    Start:
    'Here, your T1-T4 variables get their values from your routine somewhere in your code.
        gosub GetPinValues
            Tx = T_Vals(i)   ' Get the value of Tx variable which can be 0...9
            Xx = A_Vals(i)   ' Get the value of Ax value. We use bits from 0 to 9 inside Xx word.
            Xx.0[Tx]= 1      ' Change Ax value based on Tx value. If TX = 0 then Xx.0[0] = 1, if Tx=9 then Xx.0[9] = 1 ... etc.
            ' Now here, something may be missing?!! Where do you make the pin = 0 after it gets to be = 1 ??
            A_Vals(i)=Xx     ' Get the assigned bits to be masked on A_vals. Now your bit arrangement is in A_Vals(i).
        next i
    'Here, you now have all your corresponding bit values assigned into A_Vals(0-3).
        gosub AssignPins
        goto start
    GetPinValues:
        ' Assign your Tx values.
        T1 = 1
        T2 = 2
        T3 = 3
        T4 = 4
        ' or use  T_Vals() array....
    AssignPins:
        A0 = AVal.0
        A1 = AVal.1
        A2 = AVal.2
        A3 = AVal.3
        A4 = AVal.4
        A5 = AVal.5
        A6 = AVal.6
        A7 = AVal.7
        A8 = AVal.8
        A9 = AVal.9
        B0 = bVal.0
        B1 = bVal.1
        B2 = bVal.2
        B3 = bVal.3
        B4 = bVal.4
        B5 = bVal.5
        B6 = bVal.6
        B7 = bVal.7
        B8 = bVal.8
        B9 = bVal.9
        C0 = cVal.0
        C1 = cVal.1
        C2 = cVal.2
        C3 = cVal.3
        C4 = cVal.4
        C5 = cVal.5
        C6 = cVal.6
        C7 = cVal.7
        C8 = cVal.8
        C9 = cVal.9
        D0 = DVal.0
        D1 = DVal.1
        D2 = DVal.2
        D3 = DVal.3
        D4 = DVal.4
        D5 = DVal.5
        D6 = DVal.6
        D7 = DVal.7
        D8 = DVal.8
        D9 = DVal.9
    Use pins in any order;
    Assign your T values before getting into scan routine.
    After scan, assign your pins to scanned & masked variables AVal...DVal.
    Much cleaner, shorter, smaller and easier.
    Thanks, looks really promising, will give it try this weekend....
    Quote Originally Posted by sayzer View Post
    A6 var PORTA.0
    A7 var PORTA.0
    A8 var PORTA.0
    A9 var PORTA.0
    Is this correct? same assignment port bit?
    Jan 2006
    Istanbul
    It is just an example; I just wanted to show how the idea works.
    Apr 2011
    Portland, Oregon
    I looked at it and, frankly, suggest that:
    Code you write (and understand) is far more maintainable, and therefore "better" than code someone else writes that cannot be modified later. The difficulty in this specific case is that there are few options to IF THEN. You may look at SELECT CASE, but it will be only marginally different. Initially, I dismissed the topic because - it worked! It was only when I read Richard's comment "Look again" that I did so - and realized the inefficiency of reading, calculating, and setting each bit and digit individually that I thought about what I saw.
    I maintain that code you understand is paramount. I made a suggestion for change because you can save a significant number of pins by dealing with HOURS and MINUTES as individual units (as I described) and, so long as you have EEPROM, you are perhaps able to save significant resources. It is also a possibility that the EEPROM map can be modified to enhance certain features. For example - you may, perhaps, define two sets of hour maps - on with the decimal lit and one without, then load alternates based on odd/ even seconds - thus, a "flashing" second indicator. When using matrix LEDs I find it handy to be able to redesign characters (via the map) without changing the code.
    It will depend on your aim in this project. If you want only a Nixie Clock and have no intention of evolving your ability (in regard) and learning from it in the future, then any solution that "works" is good enough. You need not understand it or be comfortable modifying it. However, depending on future goals, starting with code you understand, having a flexible design, and continuing to revisit with a growing understanding become greater priorities.
    As always, DIY is about solving your own priorities - and enjoying the satisfaction of doing it.
    Amoque
    The reason why I'm using separate pins for each digit can be seen in this short video:
    And as you can guess, there are no PIC16 chips with 40 available IO ports at all
    I've finished first revision of PCB, and DS1302 now is mapped on PORTA.5-7 ports now. And it does not works. While segments can be turn on/off without issues on PORTA, clock chip gives no response. The MCU used is PIC16F1519 and config looks like this:
    OSCCON = %01111010  'SET INTOSC TO 16MHZ
    ANSELC=%00000000
    ANSELD=%00000000 'disable ADC
    ANSELB=%00000000
    ANSELA=%00000000
    ANSELE=%00000000
    TRISC=%00000000 'set PORTS as output all
    TRISD=%00000000
    TRISB=%00000000
    TRISA=%00111000 '3 ports are inputs, but changing them to outputs also does nothing
    TRISE=%00000000
    DEFINE OSC 16   'OSC SPEED
    I'm missing something?
    Jan 2006
    Istanbul
    ANSELC=%00000000
    ANSELB=%00000000
    ANSELA=%00000000
    ANSELE=%00000000
    TRISD=%00000000
    TRISB=%00000000
    TRISE=%00000000
    Attachment 8862
    Where is the config?
    In addition to OSCCON for intosc setting, Config fuse also needs to be configured for internal OSC.
    Well chip works fine, and I can light up any digits via any pins in software.
    here is config used in above code
    ;----[16F1519 Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "16F1519"
      #DEFINE MCU_FOUND 1
    cfg1 = _FOSC_INTOSC           ; INTOSC oscillator: I/O function on CLKIN pin
    cfg1&= _WDTE_OFF              ; WDT disabled
    cfg1&= _PWRTE_OFF             ; PWRT disabled
    cfg1&= _MCLRE_ON              ; MCLR/VPP pin function is MCLR
    cfg1&= _CP_OFF                ; Program memory code protection is disabled
    cfg1&= _BOREN_OFF             ; Brown-out Reset disabled
    cfg1&= _CLKOUTEN_OFF          ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
    cfg1&= _IESO_OFF              ; Internal/External Switchover mode is disabled
    cfg1&= _FCMEN_OFF             ; Fail-Safe Clock Monitor is disabled
      __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF               ; Write protection off
    cfg2&= _VCAPEN_OFF            ; VCAP pin function disabled
    cfg2&= _STVREN_ON             ; Stack Overflow or Underflow will cause a Reset
    cfg2&= _BORV_LO               ; Brown-out Reset Voltage (Vbor), low trip point selected.
    cfg2&= _LPBOR_OFF             ; Low-Power BOR is disabled
    cfg2&= _LVP_OFF               ; High-voltage on MCLR/VPP must be used for programming
      __CONFIG _CONFIG2, cfg2
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    Sep 2009
    CuriousOne
    Sorry to go off topic, but how did you menage to create that turn on?
    It look amazing...
    Apr 2011
    Portland, Oregon
    If you can " light up any digits via any pins in software", it is unlikely to be the configuration. More likely in my mind the I2C routines to retrieve clock data. Can you get Hour and Minute values to display on LCD or via the serial comms provided in PB? If you don't have any of the cheap TTL to Serial modules available on Ebay or Amazon for a few bucks, they are (with a serial cable) a worthwhile investment. A 4x20 LCD can also be very helpful in providing some troubleshooting output, if you haven't anything else.
    Presuming you have serial, this should (configure the serial com screen (in PB) to match):
    '-----DEBUG (SERIAL) SETUP----------------------------------------
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 5
    DEFINE DEBUG_BAUD 2400
    DEFINE DEBUG_MODE 0
    Should get you some output and a way to demonstrate you are getting output from the clock. You can read up on all the formatting codes, but start with "TEST", 13, then start adding variables when you're sure you've got it going.
    Once you know you can output to serial... Here are some routines I use with the DS series clocks. I use the DS1337 - its supposed to be high accuracy, but I just found them in battery backed-up modules for cheap and... no fiddling with crystals, or wires.
    '-----I2C SET-UP-------------------------------------------------
    SDA  VAR PORTB.1
    SCL  VAR PORTB.4
    '-----CLOCK SET-UP------------------------------------------------
    RTC_ADD CON %11010000
    REG_TIM CON $00
    REG_AL1 CON $07		' Not implemented
    REG_AL2 CON $0B		' Not implemented
    REG_SPC CON$0E
    REG_STS CON $0F
    '-----TIME/ CLOCK VARIABLES----------------------------------------
    REG_VAL VAR Byte[7]  	' Seconds, minutes, hours, day of week, date, month, year
    '-----SET INITIAL TIME-----------------------------------------------
    'FOR FUNCTION TEST, JUST SET EACH REGISTER TO ITS POSITION - LP[0] = 0 SECONDS, LP[1] = 1 MINUTE, LP[2] = 2 HOUR...
    FOR LP = 0 TO 6        ' For each register
       REG_VAL[LP] = LP     ' Set value to address
    NEXT LP                ' Loop
    GOSUB CLK_WRITE
    '+++++MAIN LOOP+++++++++++++++++++++++++++++++++++++++++++++++++++
    MAIN:
      GOSUB CLK_READ:              ' Read clock
      PAUSE 500                          ' Pause
    GOTO MAIN
    CLK_READ:
    '-----READ TIME, CONVERT FROM BCD TO DECIMAL, DISPLAY--------------------------------------------------------------------
      I2CRead SDA, SCL, RTC_ADD, REG_TIM, [REG_VAL[0], REG_VAL[1], REG_VAL[2], REG_VAL[3], REG_VAL[4], REG_VAL[5], REG_VAL[6]]
        D0 = (REG_VAL[LP] >> 4) * 10	' Decode 10's digit
        D1 = REG_VAL[LP] & %0001111	' Blank 10's, get 1's
        REG_VAL[LP] = D0 + D1 	        ' Write Decimal value to register
        NEXT LP				                ' Next register
      DEBUG "TIME:[", dec1 REG_VAL[3], "]  ", dec2 REG_VAL[5], "/", dec2 REG_VAL[4], "/", dec2 REG_VAL[6], "  ", dec2 REG_VAL[2], ":", dec2 REG_VAL[1], ":",  DEC2 REG_VAL[0], 13
    CLK_WRITE:
    '-----CONVERT TO BCD VALUES, WRITE TO CLOCK REGISTERS ----------------------------------------------------------------------
        D0 = REG_VAL[LP] / 10		        ' Get decimal 10's digit
        D1 = REG_VAL[LP] // 10 		' Get decimal 1's
        REG_VAL[LP] = (D0 << 4) + D1	' Shift BCD 10's in, add 1's
      I2CWrite SDA, SCL, RTC_ADD, REG_TIM, [REG_VAL[0], REG_VAL[1], REG_VAL[2], REG_VAL[3], REG_VAL[4], REG_VAL[5], REG_VAL[6]]
      GOSUB CLK_READ			        ' Update display
    I don't know how much help this is, you didn't really give enough info to go beyond what you say already works, but if you I2C routines look different, then maybe your issue is there. If you're looking for some way to troubleshoot, then maybe the LCD or serial stuff will get you started... just not sure how to help.
    The animated turn on/off is created via a hardware trick, which we were using in times, when SN74141 was not widely available (~30 years ago). It requires 2 transistors per each digit, so this clock uses 60 pcs of MPSA42 transistors just to do this I'm planning to put this clock on instructables, so all details, including schematics and PCB will be available there.
    For the code (I'm using one from PBP examples). Initially, I had test setup assembled on breadboard. DS1302 module was connected to PORTC.1-2-3 and worked fine. I had MAX7219 connected and code worked as it should. However, when moving to PCB, to ease process of PCB design, I had to move DS1302 to PORTA. So now it does not works. The reason might be that I've messed up with wiring, but I wanted to be sure to ask, whenever there might be some specific additional configs needed for PORTA.
    Sep 2009
    Thanks, please post link to instructables.
    Do you have pull up resistors on I2C lines?
    Also post code for reading RTC, so we can help. This way is hard to guess what is wrong.
    All address for used for I2C should be byte or word, for proper function off i2CREAD/WRITE.
    I2C command uses variables size to send proper no of bits for addresses(8 or 16 bits).
    Here is complete code, but a lot of "water" in it
      #DEFINE MCU_FOUND 1
    #ENDIF
    #IFNDEF MCU_FOUND
    #ENDIF
    'nixie led clock electronics direct drive
    include "modedefs.bas"
    ANSELC=%00000000
    ANSELB=%00000000
    ANSELA=%00000000
    ANSELE=%00000000
    TRISC=%00000000 'set PORTC as output all
    TRISD=%00000000 'set PORTD as output all
    TRISB=%00000000 'set PORTD as output all
    TRISA=%00111000
    TRISE=%00000000
    X VAR WORD ' TEMP VARIABLE
    X=200
    'TENS HOURS PINS
    A0 VAR PORTD.7
    A1 VAR PORTD.6
    A2 VAR PORTD.5
    'ONES HOURS PINS
    B0 VAR PORTB.2
    B1 VAR PORTB.3
    B2 VAR PORTB.5
    B3 VAR PORTB.4
    B4 VAR PORTD.4
    B5 VAR PORTA.0
    B6 VAR PORTA.1
    B7 VAR PORTA.2
    B8 VAR PORTE.0
    B9 VAR PORTB.1
    'BLINKING DOT
    DOT VAR PORTE.1
    'TENS OF MINUTES
    C0 VAR PORTC.7
    C1 VAR PORTB.0
    C2 VAR PORTE.2
    C3 VAR PORTA.7
    C4 VAR PORTC.0
    C5 VAR PORTC.1
    'ONES OF MINUTES
    D0 var PORTD.3
    D1 VAR PORTC.4
    D2 VAR PORTC.5
    D3 VAR PORTC.6
    D4 VAR PORTC.2
    D5 VAR PORTC.3
    D6 VAR PORTD.0
    D7 var PORTD.1
    D8 VAR PORTA.6
    D9 var PORTD.2
    'DS 1302 pins
    RST  Var PORTA.5
    IO   Var PORTA.4
    SCLK Var PORTA.3
    ' DS1302 Allocate variables
    rtcyear    Var byte
    rtcday     Var byte
    rtcmonth   Var byte
    rtcdate    Var byte
    rtchr      Var byte
    rtcmin     Var byte
    rtcsec     Var byte
    rtccontrol Var byte
    'my time variables
    saatebi var word
    cutebi var word
    DRO var word
    T1 VAR WORD 'VARIABLES FOR TIME DIGITS
    T2 VAR WORD
    T3 VAR WORD
    T4 VAR WORD
    ' MTAVARI KODI AQ
    	' Set initial time to 8:00:00AM 07/16/99
       rtcyear = $99
       rtcday = $06
       rtcmonth = $07
       rtcdate = $16
       rtchr = $23
       rtcmin = $48
       rtcsec = 0
       Gosub settime   ' Set the time
    mtavari:
    'high dot
    gosub gettime
    't1=2
    't2=3
    't3=4
    't4=5
    gosub display
    'pause 100
    'low dot
    'pause 100
    goto mtavari
    DISPLAY: 'DECODE VALUES AND DISPLAY THEM
    'tens hours
    IF T1=0 THEN
    HIGH A0
    LOW A0
    IF T1=1 THEN
    HIGH A1
    LOW A1
    IF T1=2 THEN
    HIGH A2
    LOW A2
    'ONES HOURS
    IF T2=0 THEN
    HIGH B0
    LOW B0
    IF T2=1 THEN
    HIGH B1
    LOW B1
    IF T2=2 THEN
    HIGH B2
    LOW B2
    IF T2=3 THEN
    HIGH B3
    LOW B3
    IF T2=4 THEN
    HIGH B4
    LOW B4
    IF T2=5 THEN
    HIGH B5
    LOW B5
    IF T2=6 THEN
    HIGH B6
    LOW B6
    IF T2=7 THEN
    HIGH B7
    LOW B7
    IF T2=8 THEN
    HIGH B8
    LOW B8
    IF T2=9 THEN
    HIGH B9
    LOW B9
    'tens of minutes
    IF T3=0 THEN
    HIGH C0
    LOW C0
    IF T3=1 THEN
    HIGH C1
    LOW C1
    IF T3=2 THEN
    HIGH C2
    LOW C2
    IF T3=3 THEN
    HIGH C3
    LOW C3
    IF T3=4 THEN
    HIGH C4
    LOW C4
    IF T3=5 THEN
    HIGH C5
    LOW C5
    'ONES OF MINUTES
    IF T4=0 THEN
    HIGH D0
    LOW D0
    IF T4=1 THEN
    HIGH D1
    LOW D1
    IF T4=2 THEN
    HIGH D2
    LOW D2
    IF T4=3 THEN
    HIGH D3
    LOW D3
    IF T4=4 THEN
    HIGH D4
    LOW D4
    IF T4=5 THEN
    HIGH D5
    LOW D5
    IF T4=6 THEN
    HIGH D6
    LOW D6
    IF T4=7 THEN
    HIGH D7
    LOW D7
    IF T4=8 THEN
    HIGH D8
    LOW D8
    IF T4=9 THEN
    HIGH D9
    LOW D9
          'ended
    ' Subroutine to write time to RTC
    settime:
       RST = 1         ' Ready for transfer
       ' Enable write
       Shiftout IO, SCLK, LSBFIRST, [$8e, 0]
       RST = 0         ' Reset RTC
       ' Write all 8 RTC registers in burst mode
       Shiftout IO, SCLK, LSBFIRST, [$be, rtcsec, rtcmin, rtchr, rtcdate, rtcmonth, rtcday, rtcyear, 0]
       RST = 0         ' Reset RTC
    ' Subroutine to read time from RTC
    gettime:
       Shiftout IO, SCLK, LSBFIRST, [$bf] ' Read all 8 RTC registers in burst mode
       Shiftin IO, SCLK, LSBPRE, [rtcsec, rtcmin, rtchr, rtcdate, rtcmonth, rtcday, rtcyear, rtccontrol]
       RST = 0         ' Reset RTC
       saatebi =( rtchr >> 4 * 10 ) + ( rtchr // 16 )    'GET TIME VALUES INTO 4 DIGIT VARIABLE
       cutebi =( rtcmin >> 4 * 10 ) + ( rtcmin // 16 )
       DRO=SAATEBI*100+CUTEBI
       'DECODE TIME INTO SEGMENT VARIABLES
       T1=DRO DIG 1
       T2=DRO DIG 2
       T3=DRO DIG 3
       T4=DRO DIG 4
       'T4=rtcsec //16     'test
    :SEGTEST  'test all segments
    HIGH A0
    PAUSE X
    LOW A0
    HIGH A1
    PAUSE X
    LOW A1
    HIGH A2
    PAUSE X
    LOW A2
    HIGH B0
    PAUSE X
    LOW B0
    HIGH B1
    PAUSE X
    LOW B1
    HIGH B2
    PAUSE X
    LOW B2
    HIGH B3
    PAUSE X
    LOW B3
    HIGH B4
    PAUSE X
    LOW B4
    HIGH B5
    PAUSE X
    LOW B5
    HIGH B6
    PAUSE X
    LOW B6
    HIGH B7
    PAUSE X
    LOW B7
    HIGH B8
    PAUSE X
    LOW B8
    HIGH B9
    PAUSE X
    LOW B9
    HIGH C0
    PAUSE X
    LOW C0
    HIGH C1
    PAUSE X
    LOW C1
    HIGH C2
    PAUSE X
    LOW C2
    HIGH C3
    PAUSE X
    LOW C3
    high c4
    pause x
    low c4
    high c5
    pause x
    low c5
    high d0
    pause x
    low d0
    high d1
    pause x
    low d1
    high d2
    pause x
    low d2
    high d3
    pause x
    low d3
    high d4
    pause x
    low d4
    high d5
    pause x
    low d5
    high d6
    pause x
    low d6
    high d7
    pause x
    low d7
    high d8
    pause x
    low d8
    high d9
    pause x
    low d9
    high dot
    pause x
    low dot
    Sep 2009
    I din't look at datasheet, so I assume that RTC is I2C.
    RST is input, so it wont never go high. And your clock isn't selected.
    Things like this:
    RST = 0 ' Reset RTC
    Can make a lot of problem. Depending on how long are your traces, etc it can fail. Look up about RMW issue on PIC.
    You can try to add pauses, or slow down PIC clock. and try to use HIGH and LOW, this is little slower and it will set pin to output.
    Also try to put LED on 3 pin used by RTC, and drive them with HIGH LOW, to see if they work.
    It appears to be config issue. When using PORTC for DS1302, all works correctly. When try to use PORTA, even on breadboard it does not works.
    fixed configs, it now works on breadboard. later will try with nixies.
    Sep 2009
    Can you tell what was issue. Because I still don't see it...
    When copying code, I was missing this during initialisation:
    Low RST ' Reset RTC
    Low SCLK
    after I added it, it now works, but now I have another issue - DIG does not converts time properly. The code for that I'm using is as follows:
    gettime:
       RST = 0         ' Reset RTC
       T1=DRO dig 1
       T2=DRO DIG 2
       T3=DRO DIG 3
       T4=DRO DIG 4
    This works, but only for ones of hours and ones for minutes. Does not works for tens of hours and tens for minutes. But the problem is, that I've copied this code from somewhere, and have no clue how it works...
    t1=rtchr >> 4 * 10
    t2=rtchr // 16
    T3=rtcmin >> 4 * 10
    T4=rtcmin // 16
    Oh, need to read manual removed * 10 and all works fine.
    Sep 2009
    I use similar code, but it's faster, and take less space.
    t1=rtchr >> 4
    t2=rtchr & %00001111
    T3=rtcmin >> 4
    T4=rtcmin & %00001111
    It is always faster to do logic, than math.
    I'm facing another problem
    statement like WRITE 1, variable or READ 1, variable give "symbol not previously defined" error, but I have variable defined and it can be used with other statements without an issues.
    you need a chip that has some eeprom to use read/write
  1. Can not change variable while using DT_INT?
    By hvguy0 in forum mel PIC BASIC Pro
    Last Post: - 29th March 2013, 23:05
  2. Change a variable to the opposite?
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 21st June 2012, 07:00
  3. LCD DB4-DB7 4bit mode change pins?
    By erice1984 in forum mel PIC BASIC Pro
    Last Post: - 6th March 2009, 01:36
  4. Accessing pins with a variable
    By Desterline in forum mel PIC BASIC Pro
    Last Post: - 20th August 2004, 16:03
  5. Let a variable change from bin to dec.
    By Roy in forum mel PIC BASIC Pro
    Last Post: - 25th May 2004, 19:57
Members who have read this thread : 33
