PicBasicPro+DT Interrupts vs mikroC PRO for PIC
Results 1 to 12 of 12
    Default PicBasicPro+DT Interrupts vs mikroC PRO for PIC
    Hi Guys
    The place I work for have just purchased mikroC PRO for PIC. I am currently using Picbasicpro compiler and I am quite happy with it. In saying so I have to admit that I wouldn't use it if there were no DT instant Interrupt system designed for it by Darrel Taylor.
    Have some used mikroC PRO for PIC http://www.mikroe.com/eng/products/v...c-pro-for-pic/. What are the cons and pros compare to PicBasicPro+DT Interrupts?
    Any feedback is greatly appreciated
    May 2007
    Default Re: PicBasicPro+DT Interrupts vs mikroC PRO for PIC
    mikroC (as well as all the other mikroE compilers) have full support for interrupts and do not require any additional routines.
    Hi ya netstranger.nz,
    I am just learning C++ right now, and not mikroe C, BUT as luck would have it I Do have an opinion ( who would have thought ) PBP interrupts " ON Interrupt " do leave a bit to be desired, and DT-INTS rock, but what IS DT_INTS anyway ? Here comes the opinion part, As I See It, DT_INTS is a function, much the same as the "C" functions which handle interrupts. Basic and C compilers essentially just turn human mnemonics into assembly code (which DT-INTS are) and the assembler MPASM turns it into the machine code (HEX) the pic requires. As I see it, the real advantage to C over Basic is this, All variables in basic are global and C can have temporary non global vars, and as such uses a bit less memory. Your program only has to work, every time. Both compilers will do that.
    All that said, I vote use both! The upside to C is code portability from PICs to ATMEL to ? ? ? as there are flavors of C for almost every MCU on the market.
    Being Honest ....
    1) MikroC do not have the Interrupts priority system Darrel has implemented ... ahaaaaa
    2) PBP + DT interrupts is rather difficult to use with small devices showing small RAM ( say 12F675/16F84A ....) ... Ohhhhhh, do not tell Darrel ...
    But, in this particular case ... Basic interrupts are not the best language to use
    3) MikroC consumes LOTS of ROM for variables conversion to text as soon as you use graphics ( LCD or GLCDS ) ... ahaaaaa
    PS: I use Both ...
    May 2007
    Quote Originally Posted by Acetronics
    I totally agree that you should stick with 8 bits.
    Jan 2006
    Istanbul
    Quote Originally Posted by netstranger.nz View Post
    Hi Guys
    We have some one like Darrel here all the time, who is willing to help & support with nothing in return.
    Since we are comparing, can we also consider him as a part of PBP?
    Quote Originally Posted by sayzer View Post
    Being Darrel works for Melabs I would say he is part of PBP.
    Jan 2006
    Istanbul
    My point actually was; he is actually a part of the solid product.
    Mar 2011
    Redmond WA USA
    I absolutely agree! rmteo are you serious?
    I'll get rid of the signature later!
    May 2007
    Quote Originally Posted by larryvc View Post
    Too bad LPC isn't MIPS.
    Mar 2011
    Redmond WA USA
    Some have argued that Microchip chose the wrong core. I think both cores have merits and flaws. Combining the best of both would be awesome.
    I'm going to this http://esc.eetimes.com/siliconvalley/. I don't see NXP, CodeRed or Microchip as being there though.
    May 2007
    ....I'm going to this http://esc.eetimes.com/siliconvalley/. I don't see NXP, CodeRed or Microchip as being there though.
    AFAIK, both NXP and CodeRed will be there. Doesn't look like Microchip will be going, though.
