Using Nokia LCD - Page 2
Page 2 of 8 FirstFirst 123456 ... LastLast
Results 41 to 80 of 301
Thread: Using Nokia LCD
  1. #41
    Feb 2004
    Germany
    and here is yet another working piece of code.
    dependend on your LCD
    you will have to adjust the values in the LCD_Init Routine
    regards
    Ralph
  2. #42
    Jul 2005
    Thumbs up
    Hello
    I need a complete PICBasic Pro code for controlling Nokia 3310 LCDs, as I have plenty of those, can any one post it here please, also I need this LCD datasheets.
    Thanks in advance
  3. #43
    Feb 2004
    Germany
    Crematory,
    Pleas read this thread from the beginning.
    There are several code examples and linlt to DataSheets etc.
    regards
    Ralph
  4. #44
    Dec 2006
    Default Can you help me about Nokia 3310 pin connection ?
    i could not tied the connection. Can you help me ?
    1-Vdd-------- 5V
    2-SCK--------Portb.4
    3-SDIN-------
    4-D/C--------Portb.6
    5-SCE--------
    6-GND--------GND
    7-Vop--------
    8-RES--------Portb.7
    DEFINE LOADER_USED 1
    DEFINE OSC 20
    DC VAR PortB.6
    DTA VAR PortB.5
    RST VAR PortB.7
    CLK VAR PortB.4
  5. #45
    1-Vdd-------- 5V
    3-SDIN-------PORTB.5
    5-SCE--------
    6-GND--------GND
    7-Vop--------
    DEFINE OSC 20
    DC VAR PortB.6
    DTA VAR PortB.5
    RST VAR PortB.7
    CLK VAR PortB.4
    Datasheet => http://www.myplace.nu/mp3/files/pcd8544.pdf
    http://www.picbasic.co.uk/forum/show...7&postcount=40
  6. #46
    Dec 2006
    Default 3310 Lcd
    Thanks for your tip. Lcd is working.
  7. #47
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by pcbb View Post
    This wouldn't be the practically the same LCD as the one found at Sparkfun is it?
    http://www.sparkfun.com/commerce/pro...oducts_id=569#
  8. #48
    amro's Avatar
    amro Guest
    Question 6310 Lcd ?
    Hi all
    any body deal with Nokia 6310 LCD ?
    it is exist two opinion about this LCD :
    first it is operate by i2c protocol .
    the other operate by SPI 3-wire .
    which is true ?
  9. #49
    Dec 2006
    Default Isıs library for 3310 lcd
    Have you 3310 lcd library for isis ?
  10. #50
    Dec 2006
    Default Matrix data problem
    i make the data with using Matrix program but Where will i place data after scaned picture in pbp program? ? have you any example about it?
    PROGRAM:
    DEFINE OSC 20
    DC VAR PortB.6
    DTA VAR PortB.5
    RST VAR PortB.7
    CLK VAR PortB.4
    Chr VAR Byte
    BitMap VAR Word
    CharCount VAR Byte
    PosX VAR Byte
    PosY VAR Byte
    Column VAR Byte [6]
    LCDstr VAR Byte [26]
    LcdData VAR Byte
    PAUSE 100
    GOSUB LCD_INIT
    PAUSE 100
    GOSUB LCD_Clear
    Start:
    Loop:
    'PAUSE 2000
    'LOW DC
    'LcdData= %00001101:GOSUB LCD_ByteOut ' Invert
    'PAUSE 2000
    'LcdData= %00001000:GOSUB LCD_ByteOut ' Blank
    'PAUSE 2000
    'LcdData= %00001100:GOSUB LCD_ByteOut ' Normal
    GOTO loop
    LCD_Init:
    LOW RST ause 20 : HIGH RST : LOW DC ' RESET LCD
    LcdData= $21: GOSUB LCD_ByteOut ' LCD EXTENDED COMMANDS
    LcdData= $c8: GOSUB LCD_ByteOut ' SET LCD Vop (CONTRAST)
    LcdData= $06: GOSUB LCD_ByteOut ' SET TEMP COEFFICENT
    LcdData= $13: GOSUB LCD_ByteOut ' LCD BIAS MODE
    LcdData= $20: GOSUB LCD_ByteOut ' LCD STANDARD COMMANDS
    LcdData= $0c: GOSUB LCD_ByteOut ' LCD IN NORMAL MODE
    LCD_ByteOut:
    SHIFTOUT DTA,CLK,1,[LcdData]
    LCD_CharOut:
    IF lcddata=32 THEN BitMap=216 ' SPACE
    IF lcddata=42 THEN BitMap=240 ' *
    IF lcddata=43 THEN BitMap=222 ' +
    IF lcddata=45 THEN BitMap=228 ' -
    IF lcddata=46 THEN BitMap=234 ' .
    IF lcddata=58 THEN BitMap=246 ' :
    IF LCDData > 47 THEN ' Numbers 0-9
    IF lcddata < 59 THEN
    BitMap=6*(lcddata-48)+156
    ELSE ' Capital Letters A-Z
    BitMap=(LcdData-65) * 6
    FOR Chr=0 TO 5
    READ BitMap+Chr,Column(Chr)
    NEXT Chr
    HIGH DC
    SHIFTOUT DTA,CLK,1,[Column(0),Column(1),Column(2),Column(3),Column(4), Column(5)]
    LCD_StringOut:
    FOR CharCount=0 TO 13
    LcdData=LCDstr(CharCount)
    PAUSE 80
    GOSUB LCD_CharOut
    NEXT CharCount
    LCD_Clear:
    PosX=0:PosY=0:GOSUB LCD_GotoXY
    HIGH DC
    FOR Chr=1 TO 252
    LcdData=0:GOSUB LCD_ByteOut
    NEXT Chr
    LCD_GotoXY:
    LOW DC
    LcdData=%01000000 | PosY :GOSUB LCD_ByteOut
    LcdData=%10000000 | PosX :GOSUB LCD_ByteOut
    ' Font DATA table
    ' DEC Chr HEX
    Data $7E,$11,$11,$11,$7E,$00 ' 65 A 41
    Data $7F,$49,$49,$49,$36,$00 ' 66 B 42
    Data $3E,$41,$41,$41,$22,$00 ' 67 C 43
    Data $7F,$41,$41,$22,$1C,$00 ' 68 D 44
    Data $7F,$49,$49,$49,$41,$00 ' 69 E 45
    Data $7F,$09,$09,$09,$01,$00 ' 70 F 46
    Data $3E,$41,$49,$49,$7A,$00 ' 71 G 47
    Data $7F,$08,$08,$08,$7F,$00 ' 72 H 48
    Data $00,$41,$7F,$41,$00,$00 ' 73 I 49
    Data $20,$40,$41,$3F,$01,$00 ' 74 J 4A
    Data $7F,$08,$14,$22,$41,$00 ' 75 K 4B
    Data $7F,$40,$40,$40,$40,$00 ' 76 L 4C
    Data $7F,$02,$0C,$02,$7F,$00 ' 77 M 4D
    Data $7F,$04,$08,$10,$7F,$00 ' 78 N 4E
    Data $3E,$41,$41,$41,$3E,$00 ' 79 O 4F
    Data $7F,$09,$09,$09,$06,$00 ' 80 P 50
    Data $3E,$41,$51,$21,$5E,$00 ' 81 Q 51
    Data $7F,$09,$19,$29,$46,$00 ' 82 R 52
    Data $46,$49,$49,$49,$31,$00 ' 83 S 53
    Data $01,$01,$7F,$01,$01,$00 ' 84 T 54
    Data $3F,$40,$40,$40,$3F,$00 ' 85 U 55
    Data $1F,$20,$40,$20,$1F,$00 ' 86 V 56
    Data $3F,$40,$38,$40,$3F,$00 ' 87 W 57
    Data $63,$14,$08,$14,$63,$00 ' 88 X 58
    Data $07,$08,$70,$08,$07,$00 ' 89 Y 59
    Data $61,$51,$49,$45,$43,$00 ' 90 Z 5A
    Data $3E,$51,$49,$45,$3E,$00 ' 48 0 30
    Data $00,$42,$7F,$40,$00,$00 ' 49 1 31
    Data $42,$61,$51,$49,$46,$00 ' 50 2 32
    Data $21,$41,$45,$4B,$31,$00 ' 51 3 33
    Data $18,$14,$12,$7F,$10,$00 ' 52 4 34
    Data $27,$45,$45,$45,$39,$00 ' 53 5 35
    Data $3C,$4A,$49,$49,$30,$00 ' 54 6 36
    Data $01,$71,$09,$05,$03,$00 ' 55 7 37
    Data $36,$49,$49,$49,$36,$00 ' 56 8 38
    Data $06,$49,$49,$49,$3E,$00 ' 57 9 39
    Data $00,$00,$00,$00,$00,$00 ' 32 20
    Data $08,$08,$3E,$08,$08,$00 ' 43 + 2B
    Data $08,$08,$08,$08,$08,$00 ' 45 - 2D
    Data $00,$60,$60,$00,$00,$00 ' 46 . 2E
    Data $14,$08,$3E,$08,$14,$00 ' 42 * 2A
    Data $00,$36,$36,$00,$00,$00 ' 58 : 3A
    DATA
    $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$ 0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0, $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$ 0,
    DATA $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$ 0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0, $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$F0,$F0,$0,$0,$0,$0, $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,
    DATA $0,$0,$0,$0,$0,$0,$30,$7C,$C4,$86,$86,$86,$86,$4,$ 4,$0,$0,$C,$84,$86,$86,$86,$C6,$C4,$FC,$F0,$0,$0,$ 0,$FE,$FE,$8,$4,$6,$6,$6,$FC,$F8,$8,$4,$6,$6,$6,$F 0,$0,$0,$0,$FE,$FE,$8,$4,$4,$6,$6,$4,$C,$F8,$E0,$0 ,$0,$FF,$FF,$0,$0,$C0,$F8,$CC,$C4,$C6,$C6,$C6,$C4, $CC,$F8,$E0,$0,$0,$0,$0,$0,$0,$0,$0,$0,
    DATA $0,$0,$0,$0,$0,$0,$18,$10,$30,$30,$30,$30,$11,$1F, $6,$0,$6,$1F,$11,$30,$30,$10,$10,$8,$3F,$3F,$0,$0, $0,$3F,$3F,$0,$0,$0,$0,$0,$3F,$3F,$0,$0,$0,$0,$0,$ 3F,$0,$0,$0,$FF,$FF,$10,$10,$30,$30,$30,$10,$18,$F ,$1,$0,$0,$3F,$3F,$0,$0,$1,$F,$18,$10,$10,$30,$30, $30,$10,$10,$18,$0,$0,$0,$0,$0,$0,$0,$0,$0,
    DATA $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$ 0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$7,$7,$0, $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$ 0,
    DATA $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$ 0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0, $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$ 0,
  11. #51
    Jan 2004
    Thessaloniki , GREECE
    Hi PCBB
    As there has been a lot of time since last worked in this project (matrix proggy of mine e.t.c) I have to re-scan my nokialcd files to answer you...
    Please wait a little and I 'll see what I can do for you.
  12. #52
    Dec 2006
    Default ok
    i wait your message back. Thanks for interest.
  13. #53
    Dec 2006
    Unhappy Which converter ?
    Which program did you use for convert to hex ? there are many program for graphic lcd but they dont make 5 columns about data, more! So Microcode program give error "Address exceeds maximum range for this processor " My processor is 16F877
    There are many converter in this site, h**p://www.compsys1.com/workbench/Benchware/GLiPIC2/glipic_2.html
    Can you help me for this problem ?
  14. #54
    Jan 2004
    I didn't manage yet to visit my lab (upstairs) to compile and try my code for you !
    I hope this weekend
  15. #55
    Jun 2006
    Bangalore, India
    Unhappy 3310 LCD trouble
    hello bitmaniac,
    In some previous posts, it is said that your code contains some errors. Can you point out those errors to me ? ? ?
    I'm having a hard time getting the nokia 3310 LCD to work.
  16. #56
    Jun 2006
    Bangalore, India
    Question Matrix program data ? ? ?
    bitmaniac,
    Where do i have to place the data generated by the matrix program ???
  17. #57
    Aug 2005
    Question Data placement
    shahidali55, you have to place the data in the start of your program, after the device and xtal definition. However, I stumbled on a problem with bitmaniacs matrix program. It generates code in one long string for ech line of the display, however these lines get to long for the PICBASIC to interpret them, so it cuts them off when they are longer than 250 symbols, so the picture gets ruined. I tried to write my own program, that would split the data in more lines, but when i split the data it for some reason ads a $00 byte after each line which results in shifted lines, that also ruins the graphic. Does anyone know how to deal with this?
    Any replies would be appreciated
    Denis Tcherniak
  18. #58
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by Russian View Post
    Well, since we can't see the program that you wrote and the problem that it entails, I can only speculate the problem is that you haven't changed the oil in your automobile or rotated the air in your tires yet this year.
    Post some code!
  19. #59
    Aug 2005
    Wink Sorry for the inconvinence, language bug...
    I meant, that's not a bug in my program, it works perfectly, i mean the PICBASIC program. When I add multiple DATA statements eg.
    DATA $FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF
    and then make the pic "paste" all the data to the screen it adds an empty column after each DATA line. It draws the first 11 black lines then it adds an empty line, and then it continues to the second data line.
    Denis Tcherniak
  20. #60
    skimask's Avatar
    skimask Guest
    Denis Tcherniak
    I don't follow what you're trying to say...pic 'paste'...adds empty column...???
    If it's not a bug in your program (what program? where?) and it's a PICBASIC problem, then post the code for the PICBASIC program. I've used DATA plenty of times without a problem, up to and including lines 254 characters long.
  21. #61
    Aug 2005
    Post
    By, "my program" i meant a prog I wrote in VB.net for converting BMP pictures to PBP DATA code, so the lines wouldn,t get longer than 250 characters.
    I am sorry, it is late, and it is hard to explain the problem. I have attached my PBP code. The data I want to use as picture is declared in the very start of the program, and it is slitted, so the lines are < 250. After the initialization of the display I call the LCD_SHOWIMAGE sub, this happens at line 95. The LCD_SHOWLCD is running a loop 504 times, each time advancing to the next DATA byte, to fill the entire display matrix with data. I am using a filled with black pixels image to make the debugging easier. I have attached a photo of the display, when my program has been run. The focusing isn't good, but notice the white lines. There are 8 of them, equal to the number DATA strings in the program.
    Denis Tcherniak
  22. #62
    skimask's Avatar
    skimask Guest
    By, "my program" i meant a prog I wrote in VB.net for converting BMP pictures to PBP DATA code, so the lines wouldn,t get longer than 250 characters. I am sorry, it is late, and it is hard to explain the problem. I have attached my PBP code.
    Look at the very top of this webpage, roughly 3 lines down, left side of the screen, and tell me what you see.
  23. #63
    Aug 2005
    Post
    MELabs PICBASIC forums? Are you writing this because I mentioned my .net program? I have not asked for help with .net. I am trying to get help with some PIC BASIC code I wrote. I mentioned .net just to explain the inconvenience we had before about me saying "my own program".
    Denis Tcherniak
  24. #64
    skimask's Avatar
    skimask Guest
    Well, good luck trying to get these lines:
    DEVICE 18F458
    XTAL = 4
    @CONFIG_REQ
    DECLARE RSOUT_MODE INVERTED , TRUE
    DECLARE SERIAL_BAUD 9600
    DIM I AS BYTE
    DIM E_DATA AS BYTE
    DELAYMS 50
    SHOUT LCD_SDA , LCD_CLK , MSBFIRST, [ $21,$A7,$20 ]
    VALIN = COUNTER PORTE.2 ,100
    STR LCDSTR = "Freq:",0:GOSUB LCD_HOME:GOSUB LCD_SENDSTRING
    STR LCDSTR = STR$(DEC VALIN):GOSUB LCD_SENDSTRING
    STR LCDSTR = "KHz:",0
    RSOUT DEC VALIN,$D,$A
    RSOUT "MEMORY FULL"
    DELAYMS 20
    SHOUT LCD_SDA , LCD_CLK , MSBFIRST, [ LCD_DATA ]
    LCD_DATA=CREAD FONT1+J+I
    SHOUT LCD_SDA , LCD_CLK , MSBFIRST, [ FONTCACHE[0],FONTCACHE[1],FONTCACHE[2],FONTCACHE[3],FONTCACHE[4],FONTCACHE[5] ]
    RSOUT "BAR", DEC I2,":", DEC LCD_DATA, "PLOT:",DEC
    RSOUT "0"
    EWRITE CUR_ADR,[E_DATA]
    CData $00,$00,$00,$00,$00,$00 'Graphic character 0
    CData $00,$08,$04,$08,$04,$00 '126 ~ - 7E
    using the compiler that's listed at the top of this webpage, roughly 3rd line down, at the left of the screen.
  25. #65
    What Skimask try to say in it's own words ... this is Melabs PICBASIC forum and not Crownhill PROTON (PDS or else) forum.
    PROTON Picbasic forum is located
    www.picbasic.org/forum
  26. #66
    skimask's Avatar
    skimask Guest
    Awwwwww.....I was having fun too!
  27. #67
    Aug 2005
    Post
    Dough... I am sorry, guys... I actually thought that it was the same thing, since the code from this forum, end especially this topic always worked for me.. Is the syntax really the same??
    I'll try the other forum...
    sorry again..
    Denis Tcherniak
  28. #68
    Syntax are slightly different... but both are named PICBASIC, hence the confusion. Don't worry about that
  29. #69
    Default gameboy GLCD to PIC16F877A
    hi guys, pls i need help on interfacing a game boyGLCD to PIC16F877.
    thanks in anticipation
  30. #70
    Jun 2006
    Bangalore, India
    Question 3310 thermo
    How can i make this in PicBasic Pro ?
    http://free-vz.htnet.hr/Ivica-Novako...ometar-eng.htm
    I want to use the 12F629 , a 3310 lcd and the DS1820.
    Currently i have got the DS1820 running and readings displayed onto a 16x1 LCD.
  31. #71
    Here it is.
    P.S. And a bonus zip with other examples!
    Sorry forgot the original!
    Very nice.
    Me too i'm playng with this display.
    Gianni
  34. #74
    Jun 2006
    Bangalore, India
    Thumbs up
    Wow cool. Thanks Ioannis.
    I'll modify the code to work with DS1820 and see if it works...
    Thanks Again . . .
  35. #75
    Jun 2006
    Bangalore, India
    Question Variable names in Ds18B20TempLcd.bas.txt
    Ioannis,
    could you please help me out with the variable names?
    Can you give me the meaning of variable names like Bitovi,Predznak,Skala,MinusNaSkali,PrintSkala ?
    I am having a hard time understanding what these variables mean...
  36. #76
    I don't speak that lanquage too, but I think the meaning is as this:
    Skala = scale
    predznak = flag
    MinusNaSkali = Negative Scale
    PrintSkala = Print Scales on LCD
    Hope it helps you a little.
    Jun 2006
    Bangalore, India
    Question
    I think predznak = sign
    What does "Bitovi" represent ???
  38. #78
    Assuming it 'could be' Croatian, i think it mean 'Bit' or 'Digit'
    well...
    http://www.eudict.com/?lang=croeng&w...&submit=Search
  39. #79
    Well, after looking the program again, bitovi is defined as byte to store a flag. That flag is 'predznak' which as you stated could be the sign.
    The bitovi is not directly used anywhere in the program.
    Mar 2005
    Novi Sad, Vojvodina
    Predznak = prefix like - or +
    Bitovi are bits (flags)
    Emil
  1. Nokia COLOR LCD PicBasicPro 2.50a example code
    By skimask in forum Code Examples
    Last Post: - 28th September 2011, 01:43
  3. Play with LCD on PICDEM
  5. LCD will not start
