 Re: Very quick question... To help a dim wit !!
 Originally Posted by
andybarrett1
				Hi...
But what would the right "if-then" would be for this ??
Andy
 Hi Andy,
The "right" one is the one that works for  YOU  the person doing the programming. Many options exist. If Then is a Boolean or true false expression. You could use select case, or branch, on goto to acheive the same results.
