Re: 16F877A and LCD HD44780
_WDT_ON try change to _WDT_OFF it could be your reset
I am NOT overly familiar with the analog stuff. What I THINK I SEE, is ADCON1 is set to use VDD & VSS as voltage reference, you can change this to an external vref for your A/D conversion in the ADCON1 register, see sect. 11.2 of the data sheet, and you can supply that vREF on AN3, also you lose about .7 volt across those diodes, you could use schottkey or germanium which switch at lower voltage.
