        IgnoreCase var bit
        Xs var byte
        Ys var byte
        Zs var byte
        Js var byte
        Ws var byte
        Cmd var byte
        Length1 var word
        Length2 var word
        MaxSearchLen var byte
        Str1ArrayLength CON 30
        Str2ArrayLength con 30
        MaxCompareLength var byte
        Str1 var byte[Str1ArrayLength]
        Str2 var byte[Str2ArrayLength]
   ; Zero out the strings
     arraywrite Str1,[rep 0\Str1ArrayLength]
     arraywrite Str2,[rep 0\Str2ArrayLength]
; Fill input arrays with some test stuff
      ARRAYWRITE Str1,["0123456789ABCDEF"]
      arraywrite Str2,["345"]
'LeftString:  ; Str2 contains the leftmost chars of Str1
;     Ys = Number of Chars to separate off from Str1
        YS = 6  ; for testing only
      If Ys != 0 then
         For Js = 0 to YS-1
            Str2[Js] = Str1[Js]
         next Js
            Str2[Js] = 0  ; make certain we always end with a nul
MidString: ; Str2 contains a string of Ys chars derived from Str1 starting at position Zs (zero based)
    ys = 2 :Zs = 4 ; for testing only
      If Ys !=0 then
        For Xs = Zs to ((Zs + Ys)-1)
           Str2[Xs-Zs] = Str1[Xs]
        next Xs
           Str2[xs] = 0  ; terminate with a nul
      Endif
RightString:  ; Str2 contains a string consisting of the right-most chars (number defined by Ys) of Str1
       Ys = 4   ; for testing only
       Js = Ys - 1
       for xs = Str1ArrayLength to 0 step - 1
             If Str1[xs] != 0 then
                 Str2 [Js] = Str1[Xs]
                 if Js = 0 then DoneRS
                 Js = Js-1
      next xs
DoneRS:
;      return
LenSTring:  ; Ys contains the length of STR1
        Js= 0
        While Str1[JS] != 0
           JS = Js + 1
        wend
        if Js > 1 then
           Ys = Js - 2
           YS = 0
;        return
InString:   ; Ws contains the position in STR1 where the match with STR2 started
            ; if there is no match, Ws contains 255
            ; if Ignore Case is set to '1', it will, of course, ignore the case.
        MaxCompareLength = Str1ArrayLength Min Str2ArrayLength
        for Xs = 0 to Str1ArrayLength
           If IgnoreCase then
                Str2[0] = Str2[0] & %11011111
                Str1[Xs] = Str1[XS] & %11011111
               If Str2[0] = Str1[Xs] then   ; Found a match on 1st char of Str2
               Ws = Xs
               Js = 1
                 for Ys = Xs + 1 to MaxCompareLength
                    if Str2[Js] = 0 then FoundMatch  ; hit the end of Str2
                       If IgnoreCase then
                           Str2[Js] = Str2[JS] & %11011111
                           Str1[Ys] = Str1[Ys] & %11011111
                    if Str2[Js] != Str1[Ys] then NoMatch
                    Js = Js + 1
                 next Ys
                 goto FoundMatch
        next Xs
NoMatch:
      WS = 255
FoundMatch:
CommandParser:
; Fast searcher! Case sensitive.  Closely based on info provided by Darrel Taylor.
; Searches through Str1. If it finds the strings listed in the quotes, it returns which one it found.
; the max length of STR1 that will be searched is in MaxSearchLen
    Cmd = 255  ; In case of no match
    MaxSearchLen = 20
    Parse01: Cmd=01 : ARRAYREAD Str1,MaxSearchLen,Parse02,[WAIT("Command1")] : GOTO Foundit
    Parse02: Cmd=02 : ARRAYREAD Str1,MaxSearchLen,Parse03,[WAIT("Age")] : GOTO Foundit
    Parse03: Cmd=03 : ARRAYREAD Str1,MaxSearchLen,Parse04,[WAIT("Weight")] : GOTO Foundit
    Parse04: Cmd=04 : ARRAYREAD Str1,MaxSearchLen,Parse05,[WAIT("Address")] : GOTO Foundit
    Parse05: Cmd=05 : ARRAYREAD Str1,MaxSearchLen,Parse06,[WAIT("Command5")] : GOTO Foundit
    Parse06: Cmd=06 : ARRAYREAD Str1,MaxSearchLen,Parse07,[WAIT("Command6")] : GOTO Foundit
    Parse07: Cmd=07 : ARRAYREAD Str1,MaxSearchLen,Parse08,[WAIT("Command7")] : GOTO Foundit
    Parse08: Cmd=08 : ARRAYREAD Str1,MaxSearchLen,Parse09,[WAIT("Command8")] : GOTO Foundit
    Parse09: Cmd=09 : ARRAYREAD Str1,MaxSearchLen,Parse10,[WAIT("Command9")] : GOTO Foundit
    Parse10: Cmd=10 : ARRAYREAD Str1,MaxSearchLen,Parse11,[WAIT("Command10")] : GOTO Foundit
    Parse11: Cmd=11 : ARRAYREAD Str1,MaxSearchLen,Parse12,[WAIT("Command11")] : GOTO Foundit
    Parse12: Cmd=12 : ARRAYREAD Str1,MaxSearchLen,Parse13,[WAIT("Command12")] : GOTO Foundit
    Parse13: Cmd=13 : ARRAYREAD Str1,MaxSearchLen,Parse14,[WAIT("Command13")] : GOTO Foundit
    Parse14: Cmd=14 : ARRAYREAD Str1,MaxSearchLen,Parse15,[WAIT("Command14")] : GOTO Foundit
    Parse15: Cmd=15 : ARRAYREAD Str1,MaxSearchLen,Foundit,[WAIT("Command15")] : GOTO Foundit
Foundit:
