using PIC 16f84 at 315 MHZ
Results 1 to 9 of 9
    abood's Avatar
    abood Guest
    Default using PIC 16f84 at 315 MHZ
    I am using TLP/RLP 434 (from laipac.com) module which is ASK transmitter and reciver for serial communication with PIC 16f84 Micocontroller.
    These two module operate at frequency 315 MHz. I found some difficulty in sitting the frequency of the PIC to 315 MHZ.
    Moreover, the data rate for this module is 4800 bps.
    help me in sitting these two things.
    Note:I am using serin2 and serout2 commands.
    Ya know, my mother always told me that "There are no stupid questions, just stupid answers".
    Sorry MA, you were wrong.
    abood,
    Before you can do anything with PIC chips, you'll need to learn at least the very basic's of how they work. Things like what voltage to use for power, what to do with the MCLR pin, and what crystals you can use for the oscillator.
    May I suggest you start with this article from Rentron.com
    Your first PICMicro Project
    abood's Avatar
    abood Guest
    Default Don't blame me for that question??
    I know my question is stupid but what to do to make this thing work.......
    Actually, you didn't help me with your site
    please directly answer my question as I explainded previously.... with sending me throw these sites
    OoooKaaaay,
    It really doesn't matter what frequency the RF link is operating at. The 16F84 will have it's own oscillator running at 10mhz or less. Simply add a DEFINE OSC 10 for a 10 mhz crystal, or change the number to the appropriate value to match you're crystal. And, be sure to set the oscillator config to "HS". (You will never get a 16F84 to run at 315Mhz)
    Then, a quick look in the manual shows that 188 is the Mode for 4800 baud, or 16572 for inverted 4800 baud.
    Or, go here for a complete list of Serin/Out modes.
    http://www.melabs.com/resources/ser2modes.htm
    Feb 2004
    Germany
    Quote Originally Posted by Darrel Taylor
    ...Sorry MA, you were wrong.
    Darrel,
    abood had actually a very innovative thought.
    By running the PIC @ 315MHz he wouldn't need any RF-modules.
    A piece of wire at any PIC ouptut pin is all he needs.
    regards
    Ralph
    Mar 2005
    Iowa, USA
    Quote Originally Posted by NavMicroSystems
    ... I've heard of people trying to overclock Pics... but that's just a little extreme. {chuckles} Don't you think?
    OverClockers.com would be proud.
    I suppose I could have mentioned that with an rfPIC you can make an ASK/FSK Transmitter running at 315mhz.
    But then he'd still need to run that 16F84 at 315mhz to be able to receive it. :)
    abood,
    Sorry, we're just poking a little fun. Don't take it personaly!
    What you are trying to do is pretty easy. Check out this link for some example code ...
    http://list.picbasic.com/forum/messa...tml?1043179926
    abood's Avatar
    abood Guest
    Default ..............
    It is nice that you gaues to have a little fun.........
    Thank you Mr.Darrel Taylor for your help but next time try to lessen to your mother and not to answer other people questions with stupid answers
    (Don't take it personaly)
    Thanks for the advice.
    But I think the next time somebody posts a similar question in the "Forum Requests" area, I'll probably do the same thing.
    Darrel
  1. Electrical noise problem with PIC 16f84
    By Snap in forum General
    Last Post: - 26th September 2007, 09:36
  2. send data from VB 6 to PIC 16f84
    By win_832001 in forum Serial
    Last Post: - 9th March 2006, 14:21
  3. send serial data to PIC 16f84 ausing VB6
    By win_832001 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 21:14
  4. how to send data from VB to PIC 16f84
    Last Post: - 25th February 2006, 16:15
