DC - AC Solid State Relay
Results 1 to 7 of 7
    Jun 2006
    Bangalore, India
    Question DC - AC Solid State Relay
    Can i switch a 25 watt CFL with circuit using a PIC ???
    <p align="center"><img border="0" src="http://www.delabs-circuits.com/cirdir/power/static-relays/dc-ssr-sch.png" width="700" height="287"></p>
    Do you have a data sheet for the opto relay? I can not find one.
    I would say yes, the PIC can do this but the 12 volt zener looks like trouble.
    Omaha, Nebraska USA
    Looks like a lot more components than I would use to do the same job . . .
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Jun 2006
    Bangalore, India
    Smile
    Got it working.
    PORTB.1 --> 33 ohm --> anode of optocoupler LED
    Cathode of oftocoupler --> battery negative
    Simple enough and works great . . .
    33 Ohms i wish you meant 330 Ohm, unless your PIC and the OPTO will suffer...
    5/33=151.52 mA
    PIC max 25mA
    Opto max 60mA
    Jun 2006
    Bangalore, India
    Post
    Thanks for the heads up mister_e . . .
    But the opto does not respond with anything less than 100 ohm.
    Don't know why ?!?
    So use a 33 ohm and it worked . . .
    I checked the current drain and its around 13 ma, which is in the safe level . . .
    Jun 2006
    Bangalore, India
    Question
    Tested the circuit with a 25 watt bulb.
    Is it safe to test it with a 25 watt CFL ?
    The CFL's have a electronic ballast circuit so i am not sure if its safe.
  1. DC to AC convertor
    Last Post: - 6th February 2010, 17:44
  2. 600w dc to ac invertor
    By marsh in forum Forum Requests
    Last Post: - 16th August 2008, 17:04
  3. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 17:42
  4. AC Relay EMI Suppression
    By CocaColaKid in forum Schematics
    Last Post: - 4th January 2006, 08:13
  5. AC and DC how to?
    By Scott in forum Schematics
    Last Post: - 12th August 2005, 15:21
