Reading a linear hall sensor
Results 1 to 6 of 6
    Feb 2005
    Default Reading a linear hall sensor
    Hi Im using this schematic (PIC12F683):
    and this code to continuosly read the hall sensor.
    It works fairly well, but I can't read the whole range of the ADC, I can't reach pwmstat values of 0,1 or 9 what am I doing wrong?
    Just in case here is the hall sensor datasheet
    Thanks in advance
    1. It's a hall effect sensor
    2. the output is open-collector, the resistor should be to Vdd
    3. you need to read a frequency not a voltage
    4. read #5 in the features section of the datasheet
    Feb 2005
    Thanks for the prompt reply mister_e.
    As you can see im not familiar at all with hall effect sensors weird thing about the code/schematics I posted is that it somewhat works
    I will appreciate any hint on what to do, now that I see the sensor output is digital Im completely lost (pulsin comes to mind)
    thanks!
    Pulsin may work, Count too, an internal Timer too. I prefer internal timer in counter mode.
    Oh BTW, if it was an analog out, you should disable the internal comparator -> CMCON0
    Feb 2005
    ok timer or pulsin, either way, how do I know when to stop reading and start counting again?
    Im reading another hall efect linear sensor datasheet: http://www.allegromicro.com/datafile/1301.pdf this one looks like more appropiate for my code, but it costs 5x the price of the one Im using
    back to the HI300/D1, I don't understand how to read it from the datasheet, which by the way looks very brief.
    Can you help me with some metacode on how to read this sensor?
    thanks
    Count PORTB.0,100,ByteVar
    This will count the pulse on PORTB.0 during 100mSec
    You should measure the frequency at the sensor output first.
  1. Computer Fan RPM Sensor Reading
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 27th December 2019, 20:05
  2. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 22:42
  3. Hall effect reading
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 26th November 2008, 15:49
  4. Hall sensor tach
    By zipphreak in forum mel PIC BASIC Pro
    Last Post: - 11th March 2006, 14:25
  5. Hall Sensor
    By jetpr in forum Schematics
    Last Post: - 14th February 2005, 18:55
