ADC Calculator
Results 1 to 2 of 2
Thread: ADC Calculator
    OK
    Default ADC Calculator
    The Mr.E Calc has an ADC Calculator function, but it calculates clock times for reading the ADC port. I needed the ability to enter voltages and get a 12-bit ADC value (expected) for a long list of voltages. Again, I turned to my new-found skill of PC programming and created an ADC Calculator App. From the start page, you set the VREF+ voltage (defaults to 5.00) then enter the voltage. It spits out 8-, 10-, and 12-Bit ADC values. Click on "Calc Volts" and it allows you to work the program in reverse. Choose 8-, 10-, or 12-Bit from the Radio Buttons and enter an ADC value. The Volts give you the expected voltage for that ADC value.
    ADC_Calc.zip
    OK
    Default Re: ADC Calculator
    ADCa.zip
    As I said, this whole PC programming thing is new to me. I spent some time with the ADC Calculator and realized there was a bit of polishing that needed to be done. Attached is a bit refined version.
  1. help with calculator
    By minssss in forum General
    Last Post: - 10th November 2009, 00:12
  2. Calculator LCD
    By menze in forum General
    Last Post: - 26th June 2006, 21:31
  3. help with my calculator project
    By loayaouad in forum mel PIC BASIC Pro
    Last Post: - 17th May 2005, 07:42
  4. Calculatorīs LCD
    By srspinho in forum mel PIC BASIC Pro
    Last Post: - 4th May 2005, 10:27
  5. Calculator
    By neiron21 in forum mel PIC BASIC Pro
    Last Post: - 1st February 2005, 00:53
