Really simple SD/MMC card socket
Results 1 to 13 of 13
    Default Really simple SD/MMC card socket
    Found this about an hour ago. Tried it... Works like a champ. Take an old 'female' floppy drive connector, plug an SD card into it. Pins line up almost perfectly.
    And who doesn't have a few floppy drive cables laying around....
    Could it be any simpler than this?
    http://uanr.com/sdfloppy/
    That is the greatest hack I 've seen lately! Thanks for sharing.
    I'm almost sorry I found it... Very little sleep since last night!
    Nice way to reuse ol' dusty stuff indeed. Nice finding.
    Aug 2003
    Hey mister_e, do you have any sample routines to share that make use of SD cards?
    It would open up new worlds to be able to move from I2C EEPROMS to 1Gb SD cards!
    Italy
    Also possible:
    Best regards,
    Luciano
    to share
    Quote Originally Posted by Luciano View Post
    Also possible:
    Best regards,
    Luciano
    True, I'm kind addicted to MikroE solution for development thingy...
    ~18USD everything you need
    http://www.mikroe.com/en/tools/mmc/
    Oooh, you bad boy!
    Aug 2003
    Use the email link to contact the author of this page:
    http://www.turtlesarehere.com/html/data_logger.html
    and he will share his AVR routines which can be easily ported to Microchip assembler.
    I didn't really require BASIC code. Assembler source is actually quite abundant.
    The routines I have access the SD card as a mass RAM with no FAT system,
    which is the same way we use I2C EEPROMS.
    Art.
    Italy
    Is something similar already available somewhere?
    An SD card socket has a switch to detect if the SD card is inserted.
    This switch is useless to detect if the user removes the SD card
    from the socket while data is written to it. With the solution
    below, it is possible close the file as soon as the user opens the door.
    (The file can be closed before the card is removed from the socket).
    I am searching something like that:
    Best regards,
    Luciano
    Also possible:
    Best regards,
    Luciano
    Even better! Nice find...
    Best regards,
    Luciano
    Kind of SD card reader Bay or sort of... well, never saw one myself yet
  1. TTL magnetic card reader interface ith PC
    By attabros in forum Schematics
    Last Post: - 24th February 2016, 07:04
  2. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 06:19
  3. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 04:59
  4. Smart card reader with PIC16F84A
    By bangunprayogi in forum Serial
    Last Post: - 12th August 2005, 10:36
  5. Reading Magnetic Card on Pic16f876
    By Finn in forum mel PIC BASIC Pro
    Last Post: - 4th February 2004, 23:36
