Convert Hex to Decimal???
Results 1 to 3 of 3
    Apr 2006
    Default Convert Hex to Decimal???
    Hello, i have a problem
    sorry for my english, i dont speak, ok
    i'm using 16F876 and serial comunication, I wait for a string of bytes, my command is:
    SERIN2, RX,Baud,100,NEXT,[WAIT(INICAD),STR DATAS\SIZE\ENDCAD]
    I=0
    Y=1
    IF DATAS[I]=COMMAND THEN
    While I<= DATAS[Y]
    I=I+1
    WEND
    where:
    Baud=84 NEXT=NEXT LAbel INICAD=$AA SIZE=20 ENDCAD=$FF
    COMMAND=$BB
    if datas[y]=1,2,3,4,5,6,7,8 or 9 it works perfectly, but datas[y]=10 or more dont's function correctly, why???
    i need convert Hex to decimal??? How?
    Thanks.
    Mexico City.
    From what i understand, when you send an string of decimal character, you send each and every ASCII character of them, one after the other.
    When you receive them, and use STR modifier as...
    HSERIN [STR ArrayVar\4]
    The results will be stor in the array variable like
    ArrayVar[0]=1
    ArrayVar[1]=2
    ArrayVar[2]=3
    ArrayVar[3]=4
    So maybe...
    Var1=(ArrayVar[0]*10)+ArrayVar[1]
    Var2=(ArrayVar[2]*10)+ArrayVar[3]
    At the end... Var1=12, Var2=34.
    There's many way to do that, but it always depend how the data i sent too...
    if you send 1234 and use something like
    HSERIN [DEC2 Var1, DEC2 Var2]
    Var1=12
    Var2=34
    Apr 2006
    Default mmmm, the problem is...
    the problem is that the values come in hex and i need used SERIN2 in order to compare start and end of string, i belive that problem is the compara in the WHILE
    While I<=DATAS[y]
    "I" never take the value of DATAS[y] because value is A hex.
    there is no a way to turn hex to decimal without using DEC
    i see in a forum that convert hex to decimal something thus.
    X=X-$20 or X=X-$30
    i dont remember but is something thus
    other idea????
    i need, i'm crazy.
    Mexico City.
  1. How to convert binary to decimal?
    By Cabomba in forum mel PIC BASIC Pro
    Last Post: - 13th October 2007, 01:27
  2. How to convert HEX Value as formatted BIN String ?
    By Robson in forum mel PIC BASIC Pro
    Last Post: - 19th August 2007, 02:16
  3. Convert Hex to Decimal
    By RONKON in forum mel PIC BASIC Pro
    Last Post: - 9th May 2006, 01:01
  4. Reading a Hex value from a Modem and showing it as Decimal..
    Last Post: - 16th March 2005, 17:58
  5. Convert a word variable to decimal
    Last Post: - 4th December 2004, 20:02
