First timer...building a remote controlled vehicle
Results 1 to 33 of 33
    Default First timer...building a remote controlled vehicle
    I have a science Olympiad tournament coming this month and for my project I am going to build a remote controlled vehicle. I can probably do the motor and turning part. But I need someone to help me with the transferring of data to the the pic chip in the controller (12F or 16F prob.) to the one the car (12F or 16F).
    maybe using the technique found under the "five-button V2 transmitter and receiver (old)" heading at http://jap.hu/electronic/codec-v4.0.html
    Please, please help me on this. Thank you by the way
    okay, I will be using either a 12F683 pic chip or a 16F684. I have two zilog transreceivers and IR detectors and stuff. Here are the links for some of the things I bought:
    transceiver - https://www.mouser.com/Search/Produc...X1810MV115TH29
    Infrared Emitter/Sensor Assemblies SMD Slotted Optical Switch
    https://www.mouser.com/Search/Produc...ey512-QVE00033
    I will try to buy whatever you guys suggest as long as you have tried it before and you know that it works. Please help out.
    The major thing I would need help with would be button debouncing as it does not seem to work with if then statements for me and how to send data to the another pic (either the 12F or 16F above) using the transceiver. Maybe code examples, links, and anything that can help me out would be great.
    thank you all!
    deadline? Jan 27th !!!!
    Apr 2005
    Virginia
    .n0rig.,
    I can't speak too much to the IR transmitter you're looking at, but I can point you in the direction of some other options. If time and ease outweigh cost, one option is to use a pre-built transmitter/receiver pair that uses standard serial data, like:
    http://www.parallax.com/Store/Access...%2cProductName
    You need both the transmitter and receiver. The link above takes you to a deal where you save a little money by buying two of each, but also on that page, below the picture, is a link to the transmitter and receiver by themselves. Unfortunately, I haven't used these personally (yet) but they use a simple serial interface like serout. The code provided isn't in PBP, but it is a form of BASIC, so it will help get you started. If memory serves, I think you'd use serout2 on the transmitter side and serin2 on the receiver side. That's it! No figuring out how to encode or decode IR signals. Plus, you'll get much better range (~500') and not nearly as much interference and noise as you would with IR.
    If you're hooked on IR and want to keep it cheap, I'd search the forum for using a standard TV remote control with a simple IR detector. I did that many moons ago, so it ain't too hard to figure out. In that way you don't have to spend additional time building a transmitter and writing code for it.
    Now, if you're ambitious, another option is to interface with a wireless Playstation 2 controller. Again, you don't have to build a controller or write software for the remote, because it's already done. Additionally, the PS2 has analog joysticks, so you could have your car's speed and steering controlled proportionately, assuming you have the supporting motor controls. In other words, instead of pushing one button to move the car forward at one set speed, you could push up on the joystick and as the stick was moved forward, the car would increase it's speed. It's a digital output, so you don't have to go so far as to use the ADC on the PIC. Check out this post for a little more info: http://www.picbasic.co.uk/forum/showthread.php?t=10386
    This will likely take the most time to program and debug however and as you're on a tight schedule, I leave it for you to decide which, if any of these, suit your needs best. I hope this helps.
    -Tony
    thanks tony, I figured the whole serin and serout deal but I was just wondering if I can do that on any of the pic's pins? I will look at the datasheets of the pics I am doing but can you give me a label I should for if any. I am going to assume that any pin will work, trial and error will fix this for me.
    Also, I know this is going to sound really dumb, but it is something I have been trying to fix for such a long time. I have been trying to use button debouncing with if then statements but they don't seem to work.
    Let us say this is the beginning of my code:
    gosub rightbuttoncheck  ;high then check right side. If right not, then restart.
    goto start
    rightstart:
    gosub nap54ms
    if GPIO.3 = 0 then start
    gosub checkRmode
    rightstart2:
    nap 6               ; low power mode for 1.152 of a sec.
    if rightbutton = 0 then start
    I don't know how to do a "if tact switch (momentary) is pressed, then goto [labe]" type of deal. I tried using the "button" command but that just gave me too many errors that I just dropped it. I was thinking of putting assembly in the and using btsfc or whatever I know some assembly...just to get me around and understand what a program is doing.
    So, if I had a a chip, a wire connect to that chip's pin, that wire to a pin of a momentary tact switch, then the other end to the ground or ground pin of the pic chip. How would I do that in basic, will the above If then statements work...well...they have not worked with me even when I change it to "if rightbutton = 1 (or a 0) then [label]".
    Regards and thanks for everything!
    P.S. are there any cheaper alternatives to this...is there no example code I can follow?
    Quote Originally Posted by .n0rig. View Post
    SERIN, SEROUT, SERIN2, SEROUT2, . . . YES, HSERIN HSEROUT, NO on these you must use the hardware ports
    goto start
    rightstart:
    gosub nap54ms
    gosub checkRmode
    rightstart2:
    Just use 2 if then loops with a short delay between them.
    LOOP:
    If portA.1 = 1 then
    pause 5
    if PortA.1 = 1 then
    { your code here}
    goto LOOP
    GOTO LOOP
    Some thing about that sounds...funny
    ok, I got the IF THEN statement to compile in one of my other codes. As for this remote controller car, how would I got about controlling two DC or three DC rumble motors from an xbox 360 controller? I really wanted one that you can control the speed on but dang...those cost a lot and for something like this, I don't want to blow my money on little 2 in x 2 in things that cost over $100.
    Anyways, I'm guessing PWM is not an option on these? How about pulsout? I just want to make these things make the car go forward, reverse, stop (if possible), and have a 3rd small one controll the steering of the front tires. The motors would have separate power sources from the pic chip. I believe the guidelines said to not use over 5 or so volts in total...I can bring extra batteries and I only need the car to operate for a few minutes. I am guessing a tripple A for the front motor and 2-3 double A's for the pic and two back motors. Maybe add some other components to make the whole thing work. But this is the idea for now. Oh, I have a few 16F684 chips and 16F636, 16F616 and an 18F that I never used. I usually buy 100's of 12F683 though :P.
    I like the 12F683 and the 16F684 because they both have the same modules and stuff. The datasheets are practically similar...except the 16F has 14 pins. So, this is the pic I want to use.
    sooo, what are my options?
    sorry double posted
    triple...please erase these last two.
    Apr 2005
    Virginia
    .n0rig.,
    I'll try to get more detail to you this evening if you need it, but here's some info to get you started.
    The button command will work on any I/O so long as the pin you select is set to a digital output. As I'm a little more familar with 16 and 18 series, let's stick with the 16F684. Now, most of the pins on this chip can be used as analog or comparator inputs, so you need to turn these off. Something like this (sorry, this is quick and dirty):
    CMCON0 = %00000111    ' Turn off comparator bits and set pins to digital I/O
    ADCON0.0 = 0               ' Disable ADC
    TRISC = %00001111       ' Make port c pins 0-3 inputs and the rest as outputs
    b0   VAR    byte    ' Byte variable for button
    HIGH PORTC.4
    Start:
    BUTTON PORTC.0, 0, 255, 0, b0, 1, drive_forward  ' If button is pressed, goto drive_forward routine
    GOTO Start
    drive_forward:
        LOW PORTC.4
        PAUSE 500
        HIGH PORTC.4
        PAUSE PORTC.4
    goto Start
    Now, as far as hookup, you should connect a 10k resistor to 5V (whatever is powering VDD) and to pin RC0. Connect one side of the momentary switch to RC0 and the other to ground. Connect the positive side of an LED to 5V and the other to, say, a 1k resistor and the other side of the resistor to RC4. Assuming I made no mistakes, you should see the LED blink once when you press the switch.
    To control motors, it depends on what you want to do. If you're NOT trying to vary the speed and just want to turn the motor on and off (one speed), I'd look at an H-bridge IC or make one with transistors or MOSFETs. Another option is to use a DPDT and a simple SPST relay, which you'd have to interface to the PIC with transistors or an optoisolator. The DPDT will change the direction will the SPST will turn the motor on and off. If you do want to vary the speed keep in mind your controller must be able to vary the signal to the PIC as well. If you want to go this route, I'd search the forum on PWM and/or motors. The rumble packs are just simple brushed DC motors as far as I know, so if one speed is okay, you just feed them power and they go - they don't need PWM to function. You would use PWM to vary the speed, but my knowledge on this subject is limited at best.
    As far as steering, I'd use a cheap servo and the PULSOUT command. Optionally, you could use continuous servos for the wheels too and get varying speed easy with the PULSOUT command, but it won't go very fast.
    Yea sounds like a good idea, I figured out how to do if then commands and I think I just figured out why my buttons were not working. I didn't signify a b0 register as a byte. Anyways, what I will need most help in will be the serout and serin to connect to the chip on the car to make the car move forward, back, etc.
    And can I use rumble motors from an xbox 360 controller for my main forward and reverse motions? can these be controlled like a servo or not? see, there is a requirement that we have to make the vehicle stop when at a certain time. The faster it stops the better.
    thanks for all your help guys!
    Apr 2005
    Virginia
    .n0rig.,
    By chip, do you mean the PIC or are you interfacing the PIC to some chip on the car? You only need serin and serout if you're interfacing to a computer or another IC. Or do you mean to talk from one PIC (on the remote) to the PIC on the car?
    I doubt you can control the motors like a servo. Rumble packs are typically DC brushed motors with a counterweight on the end that act like pager motors or the vibration ringer in a cellphone. They'll be full on or off like a standard DC motor. You'd have to use PWM with some type of interface circuitry or buy a motor controller that can interface with the PIC.
    If you'd like to dive further into motor control, a quick Google search turned this up:
    http://www.newark.com/pdfs/techartic...ksBrochure.pdf
    http://ww1.microchip.com/downloads/e...tes/00893a.pdf
    http://ww1.microchip.com/downloads/e...tes/00905a.pdf
    http://www.seattlerobotics.org/encod...implemotor.htm
    I haven't looked at this in detail, but you might get away building this and using pulsout:
    http://www.aaroncake.net/CIRCUITS/motorcon.asp
    However, I think this would do everything you want and pretty cheaply:
    elec_mech, you are really helpful and thank you for finding those links for me.In regards to some of your questions, yes, I will be using serout to "wireless" interface like this:
    me -> push buttons on remote -> remote has 16F684 in it -> which is connected to an RF transceiver (or transmitter "tx") -> sends the info about me pushing the button(s) -> transceiver (or receiver "rx") in car receives info -> transceiver forwards received info. to another 16F684 chip in the car that is connected to either 3 or 4 rumble motors (dc) without the weights on the spindles -> this controls forward and reverse motions. With some gears and just 3 motors (two on back and one of front between two front tires with spindle facing upward) I can make a steering system.
    That right there sums up my plan for this. I don't need anything fancy for controlling the car, nothing that exceeds 30M probably (RF quality).
    I am still lost on what actual supplies I can use that are not too expensive. If you have done something like this before I would greatly appreciate either a sample code, parts list, or guides for me. I really appreciate all of your help...this is going to be a really important event for me if I finish this as it will be one of the biggest completed codes I could possibly make. With the knowledge that I attain from this, I can put it to use in the future. Anyways, thanks...just keep all this information rolling guys.
    n0rig
    Apr 2005
    Virginia
    .n0rig.,
    Ahh, okay. It's been years since I worked on an IR project, so I did a quick search on the forum under 'infrared' and found some postings you might want to check out:
    http://www.picbasic.co.uk/forum/show...light=infrared
    Now, by all accounts, everyone said Bruce was the man on IR and to check out the solutions on his website. These are both inexpensive and relatively easy to implement.
    http://www.rentron.com/Infrared_Communication.htm
    http://www.rentron.com/remote.htm
    http://rentron.com/PicBasic/IR_Chips.htm
    If you'd consider using a universal TV remote programmed with Sony signals, as a backup plan - I'm not encouraging you to abandon your plans for making your own remote - then: http://www.rentron.com/remote_control/IR-D15A.htm
    Hope this helps and good luck!
    okay, after spending about an hour reading through rentron's articles...I have come to the conclusion that I will need to generate the signal, run that through my IR transceiver and then collect it again at the transceiver in the car. I have three transceiver here that have an in and out for RF communication. I am sure I will not need to encode the data stream, right?
    Well, I have two of these:
    http://www.mouser.com/search/Product...CYV8QSMg%3D%3D
    100+ 12F683 I/P
    ~6 16F683 I/P
    ~3 16F616
    1 18F2550
    ~500 tact switches
    ~3000 ft kynar wire (30 awg)
    no oscilloscope
    1 voltimeter
    and soldering iron and glue
    other basics
    Soo...I am not sure if this is what all I may need to make an IR link between two chips. I just need your guidance guys in all of this. I will post pictures of it if I finish it
    Found this at rentron and going to see if I can make my own encoder and decoder. Ok...I know I will need this to minimize "noise" that may be from cells and stuff like that at the competition. sooo, what exactly will me connecting my 16F to the encoder pic to the transceiver which will transmit to the tranceiver at the car, decoded by the decoder pic, and forwarded to the 16F in the car do to my remote controlling abilities. Is this required and what are the benefits. And...is my concept above wrong? Does the data go through the transceivers and get picked up by the other transceiver?
    This is seriously the first ever pic basic code that I have done for wireless or "serin/serout" communication. I have some good knowledge of a pic but it is just novice to intermediate knowledge. But anyways, the link is here:
    http://www.rentron.com/PicBasic/IR_Chips.htm
    Also, I will be trying to test some serout/serin commands with my 16F684 tonight to see if I can get a pin on the receiving pic to go high and turn on an LED. If I can do this...maybe using the pulse command can control the DC motors? Then I can incorporate this to the IR transceivers.
    Any tips and help is appreciated by all viewing...
    Also, for my two 16F pics (not decoder/encoder, Tx/rx) I was wondering if I could make subroutines in the code that simplify the wireless communication part. Maybe have it do something like this (in English not in basic ) .
    -------16F in remote controller-----
    if porta.0 button is pressed (signifies forward) then goto send_forward
    send_forward:
    serout the letter "f"
    ------16F in car------
    serin "letter (can be F, B, L, R, and combinations of letters)
    if letter = F then goto foward
    foward:
    PWM on two back motors using hardware PWM
    ...or jsut make both pins connected to the + of the motors high?
    Would something like that work? Also....I have some guides here (and the internet) on how to use the serin/out commands....I just need to learn the basics of what I can and cannot do. I cannot test anything right...I really don't want to mess anything up. For now...I want to collect as much info as i can and prepare myself with the knowledge that others have done this before me...that I should be able to as well.
    n0rig
    Apr 2005
    Virginia
    .n0rig.,
    As much as I love to help, I'm a bit short on time this week. It looks like you're heading in the right direction. My only advice to you at this point is to put something together and try it. The worse case is it won't work - you're not going to blow anything up. Just make darn sure there are no shorts between the positive and negative power leads and that you don't switch the two going into your ICs before you apply power - those have been my biggest problems (thumping head against wall). Once you've put something together and tried out some code, let us know what you've done, where you're stuck and we'll do our best to help. Good luck!
    I can't get the chips to communicate...
    Try it without the transmitter, use a wired connection for trouble shooting.
    Post the non-working code!
    Default Robotic control via TV remote control
    I just found out about this website. So, this information may be too late to use.
    On the other hand, your original post was on Jan 15, 2009.
    Microchip has an application note, AN657, that shows you how to decode TV remote control signals. The application note includes source code.
    You make a table of the decoded codes for the buttons you want to use.
    Then write simple subroutines for each task you need to do.
    Can you please post the link ????
    Okay, deadlines are this saturday. I got the chips communicating with a wired connection. On a 16F684 I used the pin portc.1 to communicate. I got it to send a variable (but now I just changed it to two word sized variables (movement1 for forward and reverse motors, and movement2 for turns). When I did one veriable, it worked perfectly by using this:
    TRAIN VAR BYTE
    movement1 var word
    movement2 var word
    PORTc.1 = 1 'turn enable pin high
    TRAIN=$55
    SEROUT PORTc.1,T2400,[TRAIN,TRAIN,TRAIN,TRAIN,TRAIN,9,movement1,movement2]
    goto get_actions
    goto start
    and this to receive:
    *movement1 and 2 have been declared in the beginning of code
    TRAIN VAR BYTE
    Start:
    PORTc.1 = 1 'turn communication pin high
    TRAIN=$55
    SERIN PORTC.1,T2400,[9],movement1,movement2
    gosub get_actions
    goto start
    forward:
    forwardleft:
    forwardright:
    backward:
    backwardleft:
    backwardright:
    turnleft:
    turnright:
    nomov:
    the last labels are where my actions to route power to the motors will go...that will be the simpler part I suppose.
    Also, I want to add buttons to my remote control. It will simple momentary tact buttons but I still do not understand what will need to be hooked up to make this stuff work. Basically, I will need around 6 buttons or so...maybe all in the porta pins. That will be the basic way to do it...given each direction a button (e.g. L, R, FL, FR, Rl, RR). But now I am thinking of using the two movement word variables (movement1 & movement2) to do two things at once. So, when I press R and the forward button (almost like a dpad), it will send out those two variables to the chip in the car. But Idk how to make those two variables run at the same time . Like...if I am doing left and forward, then I want left and forward to be enabled at the same time.
    *actually...wouldn't tris and port commands do this quicky?
    It's late and I am tired...
    anyways, here is what I have for the buttons as described above...will this section of code work work with momemtary tact switches like I said? Or do I have to use the button command? If I am missing or doing something wrong in any part of this...please, please help me out. Also, if you have any tuts or previous codes your wrote and don't mind PMing me...then please do.
    get_actions:
    if leftbutton = 0 then
    turns = 1                   ;turns = 1 means a left turn
    turns = 0                   ;no turn at all
    turns = 2                   ;turn = 2 means a right turn
    if backwards = 0 then
    forwardsandback = 1
    forwardsandback = 0
    if forward = 0 then
    forwardsandback = 2
    forwardsandback = 0
    goto start                   ;now we have all the buttons pressed at this small
                                 ;interval of time...we need to send it.
    *the serout command is located after start
    I have been working on this for a long time and have spent so much money that I decided to buy those rentron transmitter and receiver pair. I did next day shipping on it too as I need them fast.
    If I were to use tho...will I have to encode anything or can I just connect the transmitter to the remote control pin and the receiver to the car?
    Oh, I bought these:
    1 - RXLC-315-LR High-Performance RF Receiver Module
    http://www.rentron.com/remote_control/RXLC-434LR.htm
    1 - TXLC-315-LR High-Performance RF Transmitter Module
    http://www.rentron.com/remote_control/TXLC-XXX-LR.htm
    I got the full code compiling but just a few things I am not sure about stilll...I have the chassis and also ordered some motors from...well...for now I forgot the place. But it was like 10 DC motors and stuff...
    ONE MAJOR QUESTION!!!!
    How do I make my car stop? I mean, using a DC motor...if u take the currect away from it, the car will still keep on rolling...how can I make it so that it locks up and stops? Is it possible by reading the adc or something and making it go postive, then negative then positive (pulse???) make it stop?
    Please give me something to work on that above guys.
    n0rig
    P.S. Pin diagram attached is not final...just something that I keep on erasing and stuff...then changing it again.
    P.S.S. Help me because this is my first time using PicBasic
    some funny thing that happened...I ordered some wireless transceiver RF chips from mouser.com (great place ) but they were so tiny and I don't have the equipment to solder to them that they are just now sitting there. Also, can these work (I got like 10 of them while I ordered my regular stuff from them...)?
    http://www.mouser.com/Search/Product...579-MCP201-E/P
    To make a PM motor brake, short the power leads together, so the current the motor is generating works to stop the rotation. Obviously you would disconnect power first
    .nOrig.,
    Unfortunately, the MCP201 ICs you ordered from Mouser aren't RF tranceivers. These are
    bidirectional serial interface ICs. See section 1.0 device overview in the MCP201 data
    sheet: http://ww1.microchip.com/downloads/e...Doc/21730d.pdf
    P.S.
    Thanks for the order. I'll have a free copy of our RF code examples CD included/shipped
    with your order today.
    -Bruce
    tech at rentron.com
    Wow bruce Thanks. I did receive it today and I am planning on working on it later tonight (the cd was in there and those files look very helpful). I am going to attach what I have as of now for both my receiving and transmitting chip (both 16F684). I would like you guys to correct me on some stuff because I had it working the day prior to yesterday (but it was just the serin and serout without the "get_direction" label and the forward, backwards, left, right labels as well), but now it has stopped working.
    Here is the code for the 16F684 that will be connected to the transmitter:
    *also, how can I make a circuit with about 4 buttons using my 7mm tact switches so that I can get the values and send them out over serout?
    **what is needed...I am still unclear on this, is it a 10k resistor or something. A simple diagram would be helpful (maybe with an accompanying piece of code )
    ***keep in mind that this is my first project ever in PBP, I have pieced stuff together from other's posts and stuff I have read. I have managed to get the somewhat good amount of knowledge that I possess of assembly programming (and all the stuff that you may learn from it) to better understand my code.
    Transmitter chip code (beta - malfunctioning?):
    *I was playing with the data being sent out and making it my own numbers so it is just a loop between start and the serout command...so I can test the receiver pic...which isn't working for some reason
    '*  Name  : Electric car (4 motors and remote controlled) for Science Olympiad*
    '*  Author  : GiroTechs                         *
    '*  Notice  : Copyright (c) 2009 GiroTechs                      *
    '*  Date    : 1/14/2009                                         *
    '*  Notes   : this is a single attempt to make a remote controller electric *
    '*          : vehicle with both reverse and forward plus steering *
    '*          : capabilities as well as a stop button.            *
    '* major code piece that baffled me came from:
    '*http://www.picbasic.co.uk/forum/showthread.php?p=50584#post50584
    '* THANK YOU n qwerty!
    '             power   ^   ground
    '              RA5         RA0
    '              RA4         RA1
    '              RA3         RA2
    '              RC5         RC0
    '              RC4         RC1
    '              RC3         RC2
    Include "modedefs.bas"
    ' ——-[ Equates ]———————————————————————————-
    FLbutton var porta.0          ;left side forward
    FRbutton var porta.5         'right side forwad
    BLbutton var porta.1       ;left side backwards
    BRbutton var porta.4       ;right side backwards
    rightbutton var portc.5          ;just turn right
    leftbutton var  porta.2           ;just turn left
    act1 var word
    act2 var word
    ;Create a changing pulsewidth signal from 10 usec wide to 655
    ;msec wide.
    pulsewidth   var    word
    ;end equates
    ;Main start
    start:
    TRISA=%00000000
    TRISC=%00000010
    OPTION_REG.7=0 'Enable Pull-Up's on PORTB
    ANSEL = 0 'turns off analogue inputs
    OSCCON =$60 'sets internal osc to 4MHz
    TRAIN VAR BYTE
    movement1 VAR WORD
    movement2 var word
    direction var word
    turns var word
    TRAIN=$55
    movement1 = 4
    movement2 = 1
    direction = movement1
    turns = movement2
    goto start
    ;subroutines
    get_actions:
    if FLbutton = 0 then
    direction = 1
    direction = 0
    if Frbutton = 0 then
    direction = 2
    direction = 0
    ;***RAN out of space on this post, you will need to get this part of code ;from the next one below.
    My Receiving pic's code:
    *in the previous code, I set it up to send fixed data so I can see if the pins are being enabled or not. As it turns out, my code isnt working for some reason. 2 days ago I had it working but idk what could be wrong because I know that "movement1" and "movement2" are being received (wired connection). Any help by looking over my if then statements and all that would be apreciated
    '             power   ^   ground
    '              RA5         RA0
    '              RA4         RA1
    '              RA3         RA2
    '              RC5         RC0
    '              RC4         RC1
    '              RC3         RC2
    forwardL var porta.0          ;left side forward
    forwardR var porta.5         'right side forwad
    backwardL var porta.1       ;left side backwards
    backwardR var porta.4       ;right side backwards
    right var portc.5          ;just turn right
    left var  porta.2           ;just turn left
    rec var   portc.1           ;receiver pin
    action var byte
    B1 var byte
    movement1 VAR WORD
    movement2 var word
    direction var word
    turns var word
    ;msec wide.
    pulsewidth   var    word
    ;end equates
    ;Main start
    TRISA=%00000000
    TRISC=%00000010
    TRAIN VAR BYTE
    Start:
    TRAIN=$55
    movement1 = direction
    movement2 = turns
    goto checkdirection
    goto start
    forward:
    if turns = 0 then
    goto forwardgo
    if turns = 1 THEN
    goto forwardleft
    if turns = 2 then
    goto forwardright
    forwardgo:
    high forwardl
    high forwardr
    low forwardl
    low forwardr
    goto start
    forwardleft:
    forwardright:
    backward:
    if turns = 1 then
    goto backwardleft
    if turns = 2 then
    goto backwardright
    high backwardl
    high backwardr
    low backwardl
    low backwardr
    goto start
    backwardleft:
    backwardright:
    turnleft:
    high left
    low right
    low right
    low left
    goto start
    if turns = 0 then
    goto start
    if turns = 1 THEN
    goto checkturns
    if turns = 2 then
    goto turnright
    goto turnright
    turnright:
    low left
    high right
    low left
    low right
    if turns = 0 then
    goto start
    if turns = 1 THEN
    goto turnleft
    if turns = 2 then
    goto checkturns
    goto turnright
    nomov:
    goto start
    ;subroutines
    checkdirection:
    ;forward and backwards
    if direction = 0 then
    goto start
    if direction = 1 THEN
    goto forward
    if direction = 2 then
    goto backward
    checkturns:
    if turns = 0 then
    goto start
    start_turn:
    if turns = 1 THEN
    goto turnleft
    if turns = 2 then
    goto turnright
    goto start
    ;left and right turns
    ;Subroutines
    nap18ms:
    clearwdt        ;let us make these nap intervals accurate by resetting the
    nap 0           ;the watch dog timer on the PIC itself.
    nap54ms:
    gosub nap18ms
    gosub nap18ms
    gosub nap18ms
    nap108ms:
    gosub nap54ms
    gosub nap54ms
    nap216ms:
    gosub nap108ms
    gosub nap108ms
    nap540ms:
    gosub nap108ms
    gosub nap108ms
    gosub nap108ms
    gosub nap108ms
    gosub nap108ms
    nap1080ms:
    gosub nap540ms
    gosub nap540ms
    nap1512ms:
    gosub nap1080ms
    gosub nap108ms
    gosub nap108ms
    Thanks guys for helping me out, and bruce...for some reason you taking the care to responding to this thread and knowing that it was me that ordered the other day really shows that ye top you guys are at the top of your game around here. I am wanting to talk to you about something I want to do...it involves selling chips and stuff.
    Just get back to me at my email "GiroTechs [at] gmail".
    Thanks for your help all!
    n0rig
    P.S. If you can help me out with my code please, please do it quickly as I will need to have a working piece with a remote control (transmitter chip connected to tact switches to designate what the motors connected to the receiving chip will do).
    I could be wrong, but this might work for you.
    Receive:
    MOVEMENT	VAR	BYTE[2]  'ARRAY VARIABLE
    SERIN2 PORTC.1,396,[WAIT("9"),STR MOVEMENT\2]
    MOVEMENT1 = MOVEMENT[0]
    MOVEMENT2 = MOVEMENT[1]
    wtf...double post and I don't know why...READ BELOW
    That part I am good in, it is the if then and stuff that after I connect the chips to a power source....the transmitter is supposed to send the already set numbers to the receiver. When the receiver gets that info., it is supposed to use that information to control the in/out at the car so it can turn the motors on or off.
    EDIT: WORKED PERFECTLY! NOW LET ME CENTER MY THING AROUND THAT...
    This is what I did to test it with your code and it worked perfectly
    Start:
    TRAIN=$55
    direction = MOVEMENT[0]
    turns = MOVEMENT[1]
    if turns = 1 then
    high porta.1
    if turns = 2 then
    high porta.5
    goto start
    ;goto checkdirection
    goto start
    BRILLIANT! I LOVE YOU! (just...I apreciate you )
    Now to learn how to wire those buttons up so that they work when I press them down...I really don't know anything about that. Lets say I have porta.1 connected to a button that is also connected to ground pin (which is connect to ground...). In my code, will I be looking for a "0" or "1". *just thought of this: will I have to use the poke command to get the status of the pin (either low or high)*
    n0rig
    Have one side of the button connected to 5 volts, the other to the PIC pin. Have a 10 k resistor connected to the same PIC pin and ground (zero).
    When the button is pushed ( assuming it is NO ) the PIN pin will be forced HIGH, that is 1.
    IF PORTA.1 = 1 THEN LABEL
    Being this sounds like a school project, can you tell me why the below worked?
    I am assuming that it "waited" to receive a digit of 9, then the array of 2 movement split the next 2 incoming bytes into the array.
    That part worked if afterward I did a check on what digit was sent (in this case, a 1), and then if it was a 1, to turn the pin porta.1 high. This worked and turned an LED i had put there on. Buttttt, when I did the same thing with the following if then statements...it did not work:
    ;lets get moving!
    checkdirection:
    goto checkturns
    goto forward
    goto backward
    checkturns:
    if turns = 0 then
    goto start
    start_turn:
    if turns = 1 THEN
    goto turnleft
    if turns = 2 then
    goto turnright
    goto start
    forward:
    if turns = 0 then
    goto forwardgo
    if turns = 1 THEN
    goto forwardleft
    if turns = 2 then
    goto forwardright
    forwardgo:
    high forwardl
    high forwardr
    low forwardl
    low forwardr
    goto start
    I am not sure why it would not work...
    Default :(
    Guys, I could not get the car working . I lost...but can take it to states
    For some reason the data being sent, even when wired, would not work. I was using several if then statements but I think that some small discrepancy was what was making it not work.
    I have posted my code above and would like someone to help me out with the trisa, porta things. I believe that is where i have messed up.
    Please guys, support me on this and help me out.
    Thanks...
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 17:39
  2. Pulse Capture and byte building
    Last Post: - 21st July 2009, 01:59
  3. TV remote controlled RGB LEDs
    By idtat in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 17:15
  4. Timer interrupt frequency
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 17th January 2009, 23:49
  5. Need help building a simple IR learning remote with a PIC
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 20th April 2006, 22:22
