Darrel Taylor's SPWM code usage
Results 1 to 2 of 2
    Unhappy Darrel Taylor's SPWM code usage
    Hello All
    A while ago I tried using Darrel Taylor's "Instant Interrupts. The demo showed that
    three separate items could run (seemingly) at the same time using this interrupt scheme. It is a great piece of code.
    Recently I tried to use the SPWM code with a 16F628a and three LEDs. After a day of
    "it won't run at 20MHZ problems", I finally found the problem in posts concerning "setting fuses". If you are
    venturing from 4MHZ to 20 MHZ for the first time, take the time to read these posts. Fuses are a real "gotcha" and
    this may save you hours of frustration.
    http://www.picbasic.co.uk/forum/show...ighlight=fuses
    http://melabs.com/support/config_defaults.htm
    Anyway...I finally got the SPWM demo to run. The problem I have is
    that the only advantage I can find here is that the PWM function can be held at a certain value
    after leaving a for next loop. That's good! I could not do that with the basic PWM function
    since the pulse generation stops when the loop is ended.
    What I don't see in the demo is an example of the (magic) seemingly simultaneous interrupt scheme put to use as in
    the "Instant Interrupts" code. I would like to run three PWM outputs independently controlled
    using a technique similar to the one shown below. The SPWM demo uses a nesting of "for next" statements
    but never seems to use the interrupt handlers. I have played around with INT settings in the
    belly of the ASM beast but I'm just guessing.
    Is this possible? Am I making this clear, or should I have another beer?
    Something like below except for SWPM......
    IF SecondsChanged = 1 THEN
    SecondsChanged = 0
    LCDOUT $FE,$C0, DEC Days,"d-",DEC2 Hours,":",DEC2 Minutes,":",DEC2 Seconds
    GOTO Main
    '---[INT - interrupt handler]---------------------------------------------------
    ToggleLED1:
    TOGGLE LED1
    @ INT_RETURN
    '---[TMR0 - interrupt handler]-------------------------------(Blinky Light)------
    T0Count VAR WORD
    ToggleLED2:
    T0Count = T0Count + 1
    IF T0Count = 512 THEN T0Count = 0 : TOGGLE LED2
    @ INT_RETURN
    "LISA, JUST ANSWER THE QUESTION, DADDY SHOULD BET ON!......"
    Thanks in advance.
    Homerclese
    Quote Originally Posted by Homerclese View Post
    What I don't see in the demo is an example of the (magic) seemingly simultaneous interrupt scheme put to use as in the "Instant Interrupts" code. I would like to run three PWM outputs independently controlled
    Here is an example of using his Instant Interrupt code to perform SPWM. I am cheating here a bit, using the R/C receiver as my 20ms timer. But it gives you an idea how to pulse your pins for a set amount of time. It uses one interrupt timer to SPWM out to 4 pins. http://www.scalerobotics.com/stamps/84-projects/pwm/71-pwm-passthrough.html
    Edit: Mybad, I forgot about Mibam. If you are interested in PWM for lighting/led control, you can use Mibam, basically a SPWM for smooth lighting effects on multiple pins. See: http://www.picbasic.co.uk/forum/showthread.php?t=10564
