RC5 code for infrared receiver
Results 1 to 24 of 24
    Default RC5 code for infrared receiver
    Hi All
    I am using a TSOP 1736 connected to a 12F629 and that in turn connected to a MAX232 which connected to a PC serial port.
    The idea is to capture the keypress data from infrared remotes.
    Digging through the forumas I found and tried Dave Houston's code which worked for NEC based remotes. (Thanks Dave!)
    I am now searching for some very simple code suited to the RC5 protocol. The one requirement is that hopefully it is purely PICBASIC without any assembler.
    I would like to receive the button press from the RC5 infrared transmitter, and store it in a variable , then I could do something like
    IF ButtonCode = xxx then
    do_something
    Any help or pointers would really be appreciated.
    Kind regards
    Dennis
    Dec 2005
    You should be able to adapt my code. All you need is the details for each protocol of interest. See...
    Default Dave thanks
    That definitely is a start ...
    Did you check the PM I sent you by the way ?
    As much as I have read the info on the PULSIN command, it still leaves me somewhat confused.
    I have seen many references to your code on the forum but I just can't seem to 'catch on' to the method
    My blurred pseudo understanding of it is :
    1.Wait for a certain pulse of specified duration (discard all other pulses we are not interested in)
    2. Once the correct pulse is received then start counting pulses of a certain duration
    3. Store each pulse as a bit. 8 pulses = a byte , 32 pulses = 4 bytes
    4. Decipher the received/stored bits/bytes into a SYSTEM ID and a DEVICE ID.
    So with reference to the diagram and the following quote:
    http://www.sbprojects.com/knowledge/ir/rc5train.gif
    The first two pulses are the start pulses, and are both logical "1". Please note that half a bit time is elapsed before the receiver will notice the real start of the message.
    Extended RC-5 uses only one start bit. Bit S2 is transformed to command bit 6, providing for a total of 7 command bits. The value of S2 must be inverted to get the 7th command bit though!
    The 3rd bit is a toggle bit. This bit is inverted every time a key is released and pressed again. This way the receiver can distinguish between a key that remains down, or is pressed repeatedly.
    The next 5 bits represent the IR device address, which is sent with MSB first. The address is followed by a 6 bit command, again sent with MSB first.
    A message consists of a total of 14 bits, which adds up to a total duration of 25 ms. Sometimes a message may appear to be shorter because the first half of the start bit S1 remains idle. And if the last bit of the message is a logic "0" the last half bit of the message is idle too.
    As long as a key remains down the message will be repeated every 114ms. The toggle bit will retain the same logical level during all of these repeated messages. It is up to the receiver software to interpret this auto repeat feature.
    PS: I had rather a big error on this page for quite some time. For some mysterious reason the LSB and MSB of the address and command were reversed. I can recall correcting this error before, but somehow an old version of the description must have sneaked its way up to the internet again.
    And with reference to your code
    If (stx<760) Then init
    As soon as a pulse is received greater than 760 then INIT but what is the 760 ?
    and
    While GPIO.1=1:Wend			'wait space
    This line is the same as
    While GPIO.1=1
    Wend			'wait space
    So in other words keep looping while GPIO.1 is 1
    and as soon as it goes to a 0 then continue to the next line(s)
    On the next section of code (the pulse count/bit catcher) you REPEAT the same thing until i is > 31 (since 0 to 31 is 32 pulses(1 or 0 bits) right ?
    Repeat
              PulsIn GPIO.1, 1, pulse
              If (pulse>100) Then
                IR.0(i)=1				'set bit
              EndIf
              i=i+1
            Until (i>31)
    OK for me there is a little confusion in the above stub of the code
    If (pulse>100) Then
    So do we disregard any pulse less than 100 here ?
    and this line
    [/code] IR.0(i)=1 [/code]
    So the above begins to build the the array IR[4] (it's 4 since we need to catch 4 bytes (32 pulses/bits) not so ?)
    The value "i" is the counter which is incremented evertime we loop through this section of code until the UNTIL condition is met (Ie. we have 32 bits or 4 bytes namely IR.0,IR.1IR.2and IR.3)
    And finally to send what we have so far (the value of the 4 IR bytes to the PC serial port
    For i = 0 To 3
              Debug IHEX2 IR[i]
            Next
    I notice you display the HEX value here, is that because if it were decimal you might overflow the WORD var ?
    I also saw in another posting that there might be a reverse bit order sent through ... is that correct ?
    In the meantime I will go through the link you sent and carefully examine the RC5 info and post what I have come up with albeit wrong.
    Kind regards
    Dennis
    I hope you don't mind me asking a tally of questions to get a clearer understanding of the functions.
    Default so..
    I have to catch 14 bits as opposed to 32 right ?
    would this mean something like
    Until (i>13)
    If that's the case then what about the pulse sizing ?
    I am specifically referring to these lines
    and
    pulse>100
    I am correct so far then the above part is where the confusion starts and it has to do with the PULSIN command.
    As i understand it the PULSIN command...
    As per the manual
    Measures pulse width on Pin.
    If State is zero, the width of a low pulse is measured.
    If State is one, the width of a high pulse is measured.
    The measured width is placed in Var.
    If the pulse edge never happens or the width of the pulse is too great to measure, Var is set to zero
    Fantastic , that explains the following (I think!)
    While GPIO.1=1
    Wend
    Now here's the cruncher for me
    The resolution of PULSIN is dependent upon the oscillator frequency. If a 4MHz oscillator is used, the pulse width is returned in 10us increments.
    If a 20MHz oscillator is used, the pulse width will have a 2us resolution.
    This is a tad confusing, what about other values of oscillator ?
    I am using a 4MHZ internal clock so therefore I would be looking at 10uS increments, but what does this mean exactly ? Does it mean the pulse is returned rounded off to the nearest 10uS ?
    Another thing ...
    Defining an OSC value has no effect on PULSIN.
    The resolution always changes with the actual oscillator speed.
    So PULSIN reads ONLY the ACTUAL oscillator (crystal, R/C) so what happens if we were using this on an 18F4520 for example where you could use PLL , something like 8MHz x 4 to total up to 32MHz ..?
    Is there some trick involved in that instance or do we then need to start looking at HPWM ?
    Apologies for the what may appear as "dumb questions" but I am trying to keep them simple in order to explain my confusion.
    And looking at the forums and various posts it seems you have so many asking similar thnigs about your code.
    Kind regards
    Dennis
    Dec 2005
    Dennis,
    I am not going to write your code for you. And I've already answered many of your questiions 2 or 3 times either here or in the many PMs you sent before I stopped responding. Here's a thread which includes code for capturing durations of both edges which you will likely need for RC5...
    Default Not giving up
    Dave thanks for the link as always.
    For the record I have never wanted anyone, nor asked anyone to write code for me! I am not using PIC's nor electronics for any commercial gain ..it is merely a hobby !
    I have asked only for code snippets to gain more of an understanding of certain aspects of a particular technology or to move past a struggling block.
    So THANK YOU to you and to all the others who still reply no matter how many times they have heard and answered the same questions.
    It's fantastic that so many here are happy to share code and experiences with others but please understand that as simple as it may seem for some to read and understand, it may take others lifetimes and that's where a few lines in a reply to a question will advance the learning process.
    To err is human ... not so ?
    So off I went
    Forums,sites,articles, google,the manual, late nights, Dave's suggestions, Bruce's site, and Les Johnson's article oh yes and dome app note from microchip, and many cups of coffee.... I am slowly moving closer to some sort of understanding (or more confusion)....
    See, the big problem was trying to grasp the PULSIN command and the resolutions @ given oscillator rates which LES JOHNSON does extremely well in the article "Controlling the world from your armchair" , in the article Les says
    I hope that I’ve succeeded in illustrating
    that both, infrared decoding and
    PICmicro programming need not be the
    exclusive property of the whizz kids or
    rocket scientists among us.
    Well that certainly did start clearing up the a lot confusion I have had with the PULSIN command for so long, it is still a little confusing for me I must admit ..stupid human that I am !
    Anyway , with enough bashing away and peeking and poking I finally came up with something that seems to work , but only with a certain remote code typed into a universal remote. At the moment there must be at least 12 different remote controls scattered around the workbench.
    Here is the code :
    ' Philips RC5 IR decoder for 12F629 @ 4MHZ
    'set for samsung TV on universal rae-1000 (or similar??) remote - TV1 -code 189 most buttons work
            define OSC 4 '4MHz
            DEFINE OSCCAL_1K 1          ' Set OSCCAL for 1k -HELPS tuning the crystal for more accurate timing
            CMCON = 7
            'TRISIO = %76543210          ' port GPIO 0=output and 1=input
            TRISIO = %00000010          ' GPIO.1 is an input all the rest are outputs
            'OPTION_REG.7 = 0 ' Internal pull-ups = on
        'debug defines
        DEFINE DEBUG_MODE  0    ' Debug sending INVERTED serial data
        DEFINE DEBUG_REG GPIO   ' Debug Port = GPIO
        DEFINE DEBUG_BIT 2      ' Debug.bit = GPIO.2
        DEFINE DEBUG_BAUD 2400  ' Default baud rate = 2400
        'end of debug defines
        'Variables begin here
        RC5CODE VAR WORD ' Holds 12-bit RC5 code
        CYCLEX VAR BYTE ' used to hold the loop count for bit collection
        IRPIN VAR GPIO.1 ' GPIO.1 input pin reading data
        'end of variables
    'check for a valid header
    IF IRPIN = 1 THEN main 'Only start when PULSE is a LOW
        PAUSEUS 100 'Pause for 0.1mS
    IF IRPIN = 1 THEN main 'Could be junk so try again
        PAUSEUS 1350 'Pause for 1.350mS
    'header check is good so now continue
    rc5code.0[13] = IRPIN 'Setup array to read each pulse into Bits
        FOR CYCLEX = 12 to 0 STEP - 1 'read 13 Pulses/bits in reverse order
            RC5CODE.0[cyclex] = IRPIN 'build the array
        PAUSEUS 1800 ' PAUSE 1.8mS then start reading next BIT/pulse
        NEXT cyclex  'go back and do it again
    IF RC5CODE.LOWBYTE = $FF THEN main 'Check to see if it's junk we received $FF aka 255
    'OK now dow some AND-ing/bit-masking to get the codes right
    RC5CODE = ~RC5CODE & $003F ' Mask upper 10-bits to return 6-bit data
    ' in lower 6-bits of word result
    'Send it to the MAX232 or serial port for display
    debug "Key Pressed = ",DEC rc5code ' send the code to serial port/MAX @ 2400bps TRUE
    'for LCDOUT ALTER THE NEXT LINE
    'LCDOUT "kepress is", DEC RC5CODE
    RC5CODE=0 ' Clear the variable for next keypress
    PAUSE 500 ' a short DEBOUNCE -If you leave this out then expect duplicates -- !
    GOTO main 'start again from main
    The code behaves differently for most remotes and I'm sure only very well for those sending RC5 codes.
    Will post the circuit later on ..really simple but it works.
    I am busy playing around with Les Johnson's code (what I could make out in the article) and will post that later on too.
    Dave .. I will keep bashing away and post progress.
    Keep well
    Kind regards
    Dennis
    Default Schematic
    Here's a schematic as promised !
    Default Still battling along :-(
    Hi all
    The code in earlier posts works but produces some strange results and I'm sure it has to do with timing and the bit tests I'm doing.
    I have been reading up on the RC5 code at this sitehttp://www.sbprojects.com/knowledge/ir/rc5.htm
    I'm still not just not getting it right and would really appreciate some guidance from some kind soul here.
    Here's how I understand it so far (I have put comments in the code too):
    1.RC5 consists of 1.778ms pulses representing a bit
    2.Each bit consists of two halves and either half of the time may be filled with a 36Khz burst.
    If the burst occurs in the first half then a ZERO is represented.
    If the burst occurs in the second half then a ONE is represented.
    3.There are TWO(2) Start bits
    4.The third bit is a "toggle" bit - which tells us the button is pressed.
    Apparently it is up to the receiving device to 'sense' that the button is down/pressed.
    So in order to get the received pulses checked and decoded the first step is decide on the method of capture right ?
    I have chose to use a 12F629 and TSOP1736 IR receiver is on GPIO.2 for receiving the IR input (IRpin in the code)
    The methods I have been seeing in the forums and on the web seem to use either PULSIN or a PIN state test.
    I have chose the PIN state test because I still don't understand the PULSIN command (you can only read the manual and examples all over so many times) - the thing I don't get is the timing/numbers. the rising ,falling and duty cycle do make sense.
    So I chose to use the state of the PIN method.
    The pseudo code is as follows:
    1.Monitor a PIN (GPIO.2) and wait for it to go LOW - this means the start of a pulse/bit.
    2.We know that if the first half of the pulse/bit is LOW (889uS) then the next half should be HIGH (assuming this is indeed a start bit)
    3.So a quick check would help --- the idea is to delay/wait for a duration of under 889uS and then check to see if the pulse/bit is still low)
    If it is high then start over and keep waiting and checking for a pulse.
    If it is low then wait for a short time and check the next half time already spent +889uS/2
    4.if the next half is HIGH then we have the first start bit and it's time to check the second incoming start bit.
    So back to square one and do it again for the second start bit.
    5.After I have the 2 start bits , it's time to start collecting the rest of the bits into a word variable.
    6.Once we have collected the bits, they need to be separated/masked/divided into the a DEVICE/ADDRESS and COMMAND portion
    BITS 4 to 8 =ADDRESS code MSB first
    BITS 9 to 14 = COMMAND code MSB first.
    Well that's the order of things as I have it figured out so far.
    Please find my code below (It's not complete yet as I first need to understand the filtering correctly and then will begin (and finally post) the bit grabbing section.
    I have it running but the problem is my initial bit tests don't seem to work because when I press a button on any remote (RC5 and others) it activates a message on my screen.I only want to filter RC5 code.
    What am I doing wrong ? :-(
    Should I rather attempt to use PULSIN (If so, what figures should I be using)
    Kind regards
    Dennis
            define OSC 4 '4MHz
            CMCON = 7
            TRISIO = %00000100          ' GPIO.2 is an input all the rest are outputs
        'debug defines
        DEFINE DEBUG_BIT 0      ' Debug.bit = GPIO.0
    RC5 VAR WORD ' Holds 12-bit RC5 code
    Loopy VAR BYTE ' Loop variable
    IRpin VAR GPIO.2 ' RB.0 input pin reading data
    Startbit2 var  bit 'holds first synch bits
    Startbit1 var  bit 'holds synch bits
    Home:
    IF IRpin = 1 THEN Home ' Wait for low going pulse
    'if not then continue to read the pulse
    'RC5 has equal length pulses each ot 1.788ms
    'first two bits are START BITS for RC5 one bit = 889uS X2half bits = 17880ms/bit
    '0 = burst in first half of bit time,1=burst in 'second half of bit time
    ' half    half    half    half   half   half   half    half
    '________|||||||________||||||||_______|||||||________|||||||
    '  889     889     889    889
    'STARTbit1       Startbit2      Togglebit      First data MSB
    '--------------|---------------|-------------|---------------| ...12 others
    '                                             Bits 4to8 Addr Bits 8to12 Command
    '.......testfor|........testfor|
    '         HIGH            HIGH
    'send a message to serial port
    debug "got something YAY ",DEC Y,13,10
    PAUSEUS 200 ' Short delay to waste some time and test if pulse is still low
    'Some conditions
    IF IRpin = 1 and startbit1=0 THEN Home ' Must be noise so test again
    IF IRpin = 1 and startbit1=1 THEN getbits 'is startbit1=1
    PAUSEUS 1350 ' Pause to read 2nd half of 1st bit period is it 1 or 0 ?
    'send message to serial port
    Debug "looks like RC5 S1 bit..checking next bit"
    Startbit1=1 'set startbit to flag we got first start bit
    if IRpin = 1 and Startbit1 =0 then Startbit1 =1
    ' test conditions I may use
    'if IRpin=1 and Startbit1=1 and Startbit2=0 then Startbit2=1
    'if startbit1=1 and startbit2=1 then goto getbits
    While IRpin=1:Wend ' go home when pin goes low again
    goto home
    Default I think I got it now !!
    @ Dave Houston and @ Bruce
    Hi Guys
    I think I finally got it !!
    I decided to measure the incoming pulses with PULSIN and debug :-), next step is a scope :-)
    So for the PULSIN command
    @ 4 Mhz PULSIN returns a value with a 10uS resolution/increments.
    So for the SONY protocol header the returned PULSIN value should be around 240 not so ?
    So if testing a SONY remote I should be testing for an incoming PULSIN value of between say 190 and 290 not so ?
    Those figures are based on the debug tests I have done with ..get this..a Phillips remote.
    One question here:
    What tolerance value should I be using ? Is 20% ok or should I use 30% just to be safe ?
    So i figure the header test would be something like
    IRpulse_length var word(13)
    IRpin var GPIO.0
    getheader:
    PULSIN IRpin,0,IRpulse_length(0)
    if IRpulse_length <190 then getheader
    if IRpulse_length >290 then getheader
    goto getheader
    If the IR pulse passes the test , the next step is to collect the bits and then to possibly use an AND to mask the received data to split into device and commands .. not so ?
    Another question :
    How do I test the second pulse as in the case for the RC5 protocol ?
    Should I just grab all 13 bits following the initial header and then check the second bit once I have captured them all ?
    This would probably be the best idea since the second bit determines whether or not the code is RC5-X which only uses one start pulse.
    I would really appreciate your comments here. it's not a problem if you don't/can't reply since I'm sure you have been asked this a million times on these forums. I will still continue to experiment until I have it working though and will post back results along the way as always.
    Kind regards
    Dennis
    California, USA
    Quote Originally Posted by Dennis View Post
    Yes. About 240.
    I have some lighting devices here that "speak Sony" and use a 16F684 running @ 8MHz, and I have my "limits" set at 450 and 520.
    That seems to work reliably with all 3 remotes I use... RCA, Universal, and Phillips.
    One question here:
    Mine are more like 10% and that works fine with all 3 remotes I use.
    IRpin var GPIO.0
    getheader:
    goto getheader
    Yeah. I use this:
    IRIN:
        IR_Dev=255:IR_But=255 ' Preset the Return variables
        Pulsin IRinput,0,Header ' Measure the header length.
        If Header < 450 then Return' If the result is less than 450 toss it out
        If Header > 520 then Return' If the result is greater than 520 toss it out
    ' Receive the 12 data bits and convert them into a packet
        For Bitcnt=0 to 11 ' Create a loop of 12
        Pulsin IRinput,0,P_Val ' Receive the IR pulses
        If P_Val >= 190 then ' If >= 190 then we've received a 1
            Packet.0[Bitcnt]=1 ' So set the appropriate bit
            Else
            Packet.0[Bitcnt]=0 '...or clear the appropriate bit
            Endif
        Next
        IR_But=Packet & %01111111 'Extract the 7 BUTTON bits
        IR_Dev=(Packet >>7) & %00011111 'Right shift and extract the 5 DEVICE bits
    Another question :
    I haven't fooled with RC5 yet, only Sony.
    I'm hoping you'll become an expert soon.
    steve
    Default Awesome :-)
    @Steve ...Seems like I am finally making some headway ..YAY
    Hey I recognize that code ... it's from 'Controlling the world from your armchair' aka article.pdf by Les Johnson :-)
    I tried it and it didn't work at the time .. I'm sure it's 'cos I had the wrong pulsin resolution and timing.
    Now if you look carefully at the previous posts you'll see mention of the RC5 protocol and here for a more detailed tech dive [HTML]http://www.sbprojects.com/knowledge/ir/rc5.htm[/HTML]
    Expert ...pffft..there are so many remote controllers out there :-) and so many different codes :-)
    Thanks for the extra info regarding PULSIN header checks by the way :-)
    Kind regards
    Dennis
    California, USA
    Yep. Works great too.
    Thanks. I've read a bit about RC5... I just haven't used it for anything yet.
    Say, the other thing I'll mention is that if you use DT_interrupts (or probably any interrupts for that matter) you may want to turn them off just before the PULSIN command and turn 'em back on afterward. It took me an embarrassingly long amount of time to troubleshoot THAT problem...
    steve
    I posted an example here: http://www.picbasic.co.uk/forum/showthread.php?t=12555
    that makes learning IR button codes really easy. It uses a special capture module on the
    18F2431 that captures everything. High signal period, low signal period, and spits it all out
    to a serial terminal window. You can learn every button code on your remote in just a few
    minutes.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Default cool
    @Bruce - thanks for the cool tips nad the code there, I'm dying to try that as soon as I can source some 18F2431's..order placed but still waiting for them.
    Did you ever manage to get any reliable way prior to the CCP modules and the 18F2431 ?
    @Steve - thanks for the tip about interrupts I am not using any yet but weill heed the warning as soon as I do start with them :-)
    Kind regards
    Dennis
    California, USA
    minutes.
    Yeah... funny about that. Several days after you posted that some 18F2431's showed up in my mailbox. Just a coincidence? I think not.
    Haven't tried them yet. They're still sitting in their cute little black Microchip box.
    Thanks for all the good code Bruce!
    steve
    California, USA
    Last year I bought a device that plugs into a USB port and "reads" IR remotes.
    It shows quite a bit of info... carrier frequency, a visual of the code waveform with high and low times, how many carrier cycles, etc, as well as the button and device code numbers.
    It also has a pretty fair data base that recognizes various codes and tells you what format they are.
    Here's a screen shot of the output:
    http://www.weirdstuffwemake.com/swee...es/irscope.gif
    steve
    Yeah - I used a USBee SX PC logic analyzer...;o) The 2431 approach is a lot faster, and gives me data I can print to text. I fiddled with one version that would even write PBP code for me to re-generate the same IR signals.
    Steve,
    Looks like a handy gadget. Should be pretty easy to write code with the data that spits-out.
    -Bruce
    tech at rentron.com
    Quote Originally Posted by Byte_Butcher View Post
    steve
    Steve, here's something similiar one can roll on one's own; works only on 'real' serial ports though (NOT USB-to-serial), found it quite useful in a few situations.
    http://www.laser.com/dante/
    Anand
    Default The hard part about RC5....
    Steve - that does look like a nice gadget indeed :-)
    Bruce - sounds like you have been through a lot of work in efforts to decode the signals.
    @Anand ..that's a nice site :-)
    Unlike SONY protocol which has set pulse sizes for 1's and 0's ,
    I see the issue with decoding the RC5 protocol , it uses bi-phase encoding either a pulse on the first half of a total bit time (denoting a 0) OR the last half of a bit time (denoting a 1) so some code would be required to check the state of the pin.
    There must be some way to measure and capture this....back to the drawing boards I go :-(
    Any thoughts anyone ?
    Kind regards
    Dennis
    Default still trying
    So it seems to decode the RC5 code, after detecting the initial pulse, some sort of check must be done at a regular time interval at the mid-point of each half bit-time since a full bit-time is 1778us (2x889us).
    So after the initial pulse I would have to check midway between the first bit-time, roughly 440us.
    So in terms of the pulses and checks we have the following:
    Start1--Start2--1st BIT--2nd BIT--3rd BIT---...etc
    ____|-------|---------|---------|--------|--------
    1778| 1778 | 889, 889| 889,889 | 889,889|--
    hch__hch____ch__ch___ch__ch___ch__ch
    Header
    check =hch
    ch=bit check
    After initial header check, waste some time and then start testing and collecting.
    So now to find the right code.
    Dennis
    Default Still confused by PULSIN
    Could someone please explain PULSIN to me !
    First off here some code as a starter to test PULSIN
            define OSC 4 '4MHz
            CMCON = 7
        'debug defines
    'Variables here
    IRpulse_length var word(13) 'holds pulse length
    IRpin var GPIO.2 'IR module ..TSOP1736..check my schematic in earlier posts'
    LED var GPIO.1 'LED is connected here
    'end of variables
    debug "working = ",13,10  'send to hyperterminal replace this with serin or hserin if you like
    LOW led   'LED off
    Getstartbits: the incoming header test
        irpin =0 'set ir pin low
        irpulse_length = 0 'set irpulse_length low
        PuLSIN IRpin,0,IRpulse_length(0) 'start PULSIN on irpin state 0 store in irpulse_length
        debug "pulse length " ,dec irpulse_length ,10,13 ' send irpulse_length to hyperterminal
    irpulse_length = 0
     goto getstartbits: 'do it again
    So as per the manual :
    PULSIN Pin,State,Var
    So a question here is :
    Can the state be altered as execution takes place.
    For example if I have set STATE as 0 to measure the width of a low pulse, can I change the state of PULSIN to detect a high pulse just after , so that STATE is 1 and PULSIN measures a HIGH PULSE ?
    This statement is true I have noticed the irpulse_length value displayed in hyperterminal
    BUT.... is this only the value for the header pulse that is being displayed ?
    The reason I ask is because as per the code stub I only get one reading on each button press..is this because things are happening so fast that PULSIN has already picked-up (buffered ) all incoming pulse
    Given the following pulse :
    _____|--------|______|------|______
    low----high------low----high----low
    If both high and low pulses are the same size then the duty cyclye is 50% not so ?
    and as per the manual
    Is this where PULSIN_MAX comes into play ?
    so we could specify the max pulse size PULSIN should care to measure?
    It looks to me like the way to measure the RC5 signal is to use a combination of interrupts ,bit check for each pulse and a counter.
    Any help or clarity on this would be really appreciated.
    Kind regards
    Dennis
    Default Wouls SHIFTIN work for this ?
    Hi all
    Still no light !
    Now I am wondering if SHIFTIN would work for catching the incoming pulses.
    Has anyone tried capturing a pulse train using SHIFTIN ?
    Any info would be appreciated.
    Kind regards
    Dennis
    garryp's Avatar
    garryp Guest
    Red face Re: RC5 code for infrared receiver
    Hello, dhouston
    I tried to look for the link but 404 error is coming
    Can you another link so that I can adapt your code
    thanx
    Feb 2003
    Default Re: RC5 code for infrared receiver
    Try http://www.sbprojects.com/knowledge/ir/index.php and follow the instructions on "How to Navigate", there is a dropdown on the menu bar that lists all the different protocols.
    Keith
    www.diyha.co.uk
    www.kat5.tv
  1. PBP code to read R/C signal from receiver
    Last Post: - 28th October 2009, 21:51
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  4. Loop with two motor and 2 sensors
  5. Making Program Code Space your playground...
