How can I do this (reversing high & low states depending on deployment & user need)
Results 1 to 6 of 6
    Mar 2009
    Default How can I do this (reversing high & low states depending on deployment & user need)
    Forgive the esoteric subject but it's hard to articulate what I'm trying to resolve.
    I have a MOSFET under PIC control.....a mosfet gate is normally low but when a tactile switch is pressed, a PIC interrupt happens & a PIC output pin goes high & switches the MOSFET on - no worries thus far.
    *but* occasionally, depending on the deployment (& I won't know in advance so it'll be down to the end user to establish) I will need the above scenario to reversed & this will then be the default .....therefore the MOSFET gate will normally be high & when a tactile switch is pressed an interrupt is triggered and a PIC output pin goes low & switches the MOSFET off.
    So what I'm thinking here is when the user deploys & it doesn't want the default...that he can change it.
    But what I don't want is a massive long program to cater for both scenarios...I'm thinking that if the user holds a switch prior to powering up, then the 'default' can be selected to the non default (in other words, a toggle).
    You following this at the back?
    in summary, this is what I'm trying to achieve....
    factory_default...
    mosfet_gate = low
    when switched pressed mosfet_gate = high
    user_selectable_new_default....
    mosfet_gate = high
    when switched pressed mosfet_gate = low
    How do I tackle this in an efficient way?
    Sep 2009
    Default Re: How can I do this (reversing high & low states depending on deployment & user nee
    Try something like this:
    IF factory_default THEN
    StateOn=1
    StateOff=0
    StateOn=0
    StateOff=1
    IF SwitchPressed THEN Gate=StateOn
    IF SomeThingElse THEN Gate=StateOff
    Aug 2008
    Portugal
    I probably do it like pedja089, but used the eeprom to save the setting!
    Thanks and Regards;
    Gadelhas
    EE_Polarity DATA 0            ; Factory Default
    SW1         VAR PORTB.0       ; Switch input pin
    mosfet_gate VAR PORTB.1       ; mosfet output
    Polarity    VAR BIT
    READ EE_Polarity, Polarity
    IF !SW1 THEN WRITE EE_Polarity, !Polarity
    mosfet_gate = 1 ^ Polarity    ; Turn OFF
    OUTPUT mosfet_gate
    mosfet_gate = 0 ^ Polarity    ; Turn ON
    Last edited by Darrel Taylor; - 17th May 2012 at 03:38. Reason: Oops, forgot to set the pin to output.
    Mar 2009
    Thanks to everyone...embarrasingly simple in the end! (hey, it was late!)
    Hi Darrel, I was with you up to this bit....
    OUTPUT mosfet_gate
    Can anyone shed a little light on what's going on there (never used a ^ before!)
    Sep 2009
    That is XOR.
    0^0=0
    0^1=1
    1^0=1
    1^1=0
    If Polarity is 1 or 0, depending on user settings. If Polarity is 0 then bit isn't inverted and result is same as:
    mosfet_gate = 0 ; Turn ON
    mosfet_gate = 1 ; Turn OFF
    If Polarity is 1 then then bit are inverted so result is
    mosfet_gate = 1 ; Turn ON
    mosfet_gate = 0 ; Turn OFF
