Serial interface with RFID reader
Results 1 to 9 of 9
    Nov 2006
    Default Serial interface with RFID reader
    Dear Helpful People:
    I am trying to interface a PIC16F874A with an ID2 RFID reader (Mannings RFID; http://www.rfidshop.com), and am having no luck. The RD2 outputs a "start of text" code ($02) followed by 10 ASCII characters (an identification code) then a carriage return and a line feed. As a first step in a more in depth project, I want to read in those ten ascii characters and send them to a PC via another rs232 line. I have gotten all the components to work, but the whole thing won't come together.
    I can send and recieve data from the PIC to a PC, and when I hook the ID2 up directly to the computer, I can read in the 10 character codes no problem at 9600 baud. So why can't the PIC read the codes in as well??
    Here is some code I would like to use:
    Include "modedefs.bas" ' Include serial modes
    DEFINE OSC 20
    SO VAR portb.0 ' Define serial out pin
    SI VAR portb.1 ' Define serial in pin
    RI VAR portb.3 ' serial in from reader
    RR VAR portb.2 ' reader reset
    B0 VAR byte 'byte variable
    tag VAR BYTE[10] ' Creates a byte array of 10 bytes
    HIGH RR 'reset Reader
    loop: Serin SI,N9600,B0 ' B0 = input character
    PAUSE 1500 'wait a sec
    Serout SO,N9600,["ready", $0A, $0D] 'Send ready
    SERIN2 RI, N9600,[WAIT($02),STR tag\10] 'get tag code
    SEROUT SO,N9600,["got the code", $0A, $0D] 'acknowledge reciept
    print: Serout SO,N9600,[tag,$0A, $0D] 'send code
    Serout SO,N9600,[" done", $0A, $0D] 'send done
    Goto loop 'do it again
    I just can't get past the serin from the reader. I have tried T9600, and I've tried adding a pullup resistor to the line between the ID2 output and PIN B3. Also, I know that the reader is working because it has an LED indicator.
    Nov 2006
    Default Now what?
    OK. I have sort of solved my own problem. The following code works:
    DEFINE OSC 20
    SO var portb.0 ' Define serial out pin
    SI var portb.1 ' Define serial in pin
    B0 var byte 'byte variable
    B1 var byte 'byte variable
    B2 var byte 'byte variable
    B3 var byte 'byte variable
    B4 var byte 'byte variable
    B5 var byte 'byte variable
    B6 var byte 'byte variable
    B7 var byte 'byte variable
    B8 var byte 'byte variable
    B9 var byte 'byte variable
    B10 var byte 'byte variable
    Serout SO,N9600,["ready "] 'Send ready
    SERIn RI, N9600,B0 'useless input
    SERIn RI, N9600,B1 '1st real data
    SERIn RI, N9600,B2 '2nd character
    SERIn RI, N9600,B3
    SERIn RI, N9600,B4
    SERIn RI, N9600,B5
    SERIn RI, N9600,B6
    SERIn RI, N9600,B7
    SERIn RI, N9600,B8
    SERIn RI, N9600,B9
    SERIn RI, N9600,B10 'last character
    SEROUT SO,N9600,["got the code: "]
    print: Serout SO,N9600,[B1] 'output 1st character
    Serout SO,N9600,[B2] 'output 2nd character
    Serout SO,N9600,[B3]
    Serout SO,N9600,[B4]
    Serout SO,N9600,[B5]
    Serout SO,N9600,[B6]
    Serout SO,N9600,[B7]
    Serout SO,N9600,[B8]
    Serout SO,N9600,[B9]
    Serout SO,N9600,[B10] 'output last character
    Serout SO,N9600,[" done"]
    Goto loop
    The first two characters from the RFID reader are junk, so they are read in and then disregarded. the following 10 characters are the ones I want. As you more experienced PICers will note, the code above is not a very elegant program. Surely there is a way to do this without 11 byte variables. Here's a program that uses arrays that does not work:
    ' SERIN & SEROUT Commands
    ' Upper case serial filter.
    DEFINE OSC 20
    Define HSER_
    tag var BYTE[10] ' Creates a byte array of 10 bytes
    SERIN2 RI, N9600,[skip 2, STR tag\10]
    print: Serout2 SO,N9600,[STR tag]
    Goto loop
    This program just seems to skip the SERIN2 line altogether and just outputs "ready got the code: done" all at once. Anybody have any ideas about what I am doing wrong?.
    Quote Originally Posted by brid0030 View Post
    Goto loop
    Re-read page 132-136 of the PBP manual on the proper use of the SERIN2 statement, then you'll be good to go...
    Nov 2006
    Default Did that
    I've been pouring over those pages trying to figure out what is wrong. Do you see my mistake, skimask?
    Yes, place your SERIN2 statement over the one's in the book on pg's 132-136 and tell me what's wrong? Plain as day...piece of cake...
    Nov 2006
    Default Please help (do not taunt)
    My serin2 statement differs from the examples in the book in many ways. And I don't know which differences are important. I've tried lots of variations, and the error is not "plain as day" to me. Can I just get an answer? I promise I have not come the forum as a first resort.
    My point exactly: You're serin2 statement differs from the examples in the book in many ways.
    Does that tell you anything? Such as that if it differs, it probably won't work right.
    Try to make your serin2 statement look like something in the book. Compare the SERIN with the SERIN2 statement. What's different about the two? Specifically, the 3rd paragraph of Page 132 and the 2nd paragraph of Page 130.
    It's just that easy! Really it is.
    You could 'just get an answer', but you're not going to learn anything about learning anything.
    Nov 2006
    Default Success
    The following code works. Serin2 modes differ from serin modes, and I think the variables for serin and serout ports have to have numbers.
    DEFINE OSC 20
    S0 var portb.0 ' Define serial out pin
    S1 var portb.1 ' Define serial in pin
    RDR1 VAR portb.3 ' serial in from reader
    RST1 VAR portb.2 ' reader reset
    HIGH RST1 'reset Reader
    loop: Serin S1,6,B0 ' B0 = input character
    Serout S0,6,["ready "] 'Send ready
    SERIn2 RDR1, 16468,[skip 2, STR tag\10] 'read in tag ID
    SEROUT S0,6,["got the code: "] 'acknowledge
    print: Serout2 S0,16468,[STR tag] 'send out tag ID
    Serout S0,6,[" done"] 'print done
    Good game....That's what I was getting at the whole time.
    SERIN/SEROUT; use modes (t2400, n9600, etc)
    SERIN2/SEROUT2; you have to figure out the 'mode number' depending on what you want to do according to the manual (or towards the back somewhere there's a table with a lot of values already in it). But one of the advantages of the SERIN2/SEROUT2 over regular SERIN/SEROUT is that you can set it up to run at 4,578 baud if you want (I don't know if that works out in the math, but I think you get my point), that and the big one is the much better string/variable handling options.
  1. Parallax RFID Reader code example
    By dan-tron in forum Code Examples
    Last Post: - 19th April 2013, 22:16
  2. Replies: 33
    Last Post: - 19th March 2010, 03:02
  3. parallax rfid reader module interface with PC
    By jonil22 in forum Off Topic
    Last Post: - 3rd February 2008, 06:54
  4. Parallx rfid reader module interface with PC
    By jonil22 in forum mel PIC BASIC Pro
    Last Post: - 31st January 2008, 08:50
  5. PIC16F877 to RFID Module Serial Interface
    Last Post: - 17th May 2005, 06:03
