DS1726 in PBP
Results 1 to 7 of 7
Thread: DS1726 in PBP
    Dec 2006
    Question DS1726 in PBP
    Hi!
    I'm working with a DS1726 (program same as a DS1626) trying to get this thing to read Fahrenheit temperatures.
    Does anyone have any code examples? I can't seem to find out a lot about this chip.
    I thought about changing over to the DS1820 via 1-wire, but I see it's obsolete now?
    Here's what I'm looking for:
    Temp sensor with 12-bit resolution (well, 11 plus sign bit), SPI or 1-wire, plus some sample code to help me get started.
    THANK YOU!!!
    Kris
    Quote Originally Posted by Hainkm View Post
    Hi!
    THANK YOU!!!
    Kris
    Plenty of DS1820 types still out there.
    Obsolete? Maybe only because the company has a 'new, improved' version. Nothing wrong with the old one...
    http://www.digikey.com/scripts/DkSea...S&Cat=33359008
    Hi Kris,
    Only the original DS1820 is obsolete.
    It was replaced with the DS18S20, which does the same thing, just in a better way.
    And there's still the DS18B20. (12 bits)
    Lot's of code in the forum for the DS18B20.
    Dec 2006
    Red face Ds18b20
    Thanks! I'll look into getting a few of those and hopefully will have some better luck!!
    Thank you!!
    Kris
    Great!
    And, for the DS18B20, see this link
    -- A Simple "High Precision" --
    -- 1-Wire Temperature Application --
    http://rentron.com/PicBasic/one-wire3.htm
    Bruce also sells the DS18B20, so you won't need to look too far.
    Dec 2006
    Talking Getting closer...
    Ok, I got myself a DS18B20 and used the code above, works like a champ!
    Now...does anyone have an easy way to get a 1-decimal point reading when we're below 32F? (when it goes below 0c, it truncates the F reading to whole numbers only)
    Thanks for all your help!!
    Kris
    Kris
    Look at Bruce's math expressions in the yikes sub directory, look at how he did it for degrees C using the DIG modifier, I think thats how it's done. Understand I'm still feeling stupid here so don't trust me, but I really think it is the DIG 3 or DIG 4 modifiers doing it, so check the manual 4.17.7 DIG page 33.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. Extensions to PBP variables
    By John_Mac in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2009, 05:21
  5. PBP / XP Crash
    By pondindustrial in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 03:16
